		garrys(at)tampabay.rr.com Guest
				 Posted: Tue Dec 28, 2010 7:36 am    Post subject: phones for flying |
				Ira, I believe that the Foreflight folks are working on geo referenced
 approach plates, and plan to release soon.  Won't that be something!
 Garry Stout
  |  | - The Matronics Europa-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		kevinmarie(at)blueyonder. Guest
				 Posted: Tue Dec 28, 2010 8:39 am    Post subject: phones for flying |
				I have a cigar socket on the panel. I connect a 4 way connector and power two iphones, backup gps, and sometimes a video camera! It works fine the iphone connectors are quite robust.
 Kevin
 On 28 Dec 2010, at 12:28, GRAHAM SINGLETON <grahamsingleton(at)btinternet.com> wrote:
 [quote] Gerry
  I used to use my old PDA as a navigation device using PocketFMS. (good software that was)
  Trouble is the connection for recharging and data updates has worn out so it won't recharge or update any more. Is the i Phone connector equally fragile?
  Graham
  From: Gerry Holland <gholland(at)content-stream.co.uk>
  Sent: Tuesday, 28 December, 2010 7:31:36
  Subject: Re: phones for flying
  Fred Hi!
  Not being flippant but everything has a limited battery life. You are quite
  right when you say the iPhone battery charge can dissipate fairly quickly
  when using something like Memory Map as a navigational back up.
  Possibly as low as 4 hours or less. I do have a 12V Auxiliary connection to
  mine from a 7Amp Hour Battery Box as I have no electrics from the Aircraft
		fklein(at)orcasonline.com Guest
				 Posted: Tue Dec 28, 2010 10:27 am    Post subject: phones for flying |
				Gerry, David, and Paul,
 Thanks for your replies...I own neither an iPhone nor and iPad at present; if fact, I remain "cell-free", and my ignorance must be apparent. However, I've heard nothing but wonderful things about apps related to flight planning, and, I gather that additional apps are earning these iP's a place in the cockpit...hence...as I'm just beginning to cut my subpanels, it seemed like a good idea to locate a receptacle to be able to power them up.
 I initially resisted using a cigar lighter socket...it seems so archaic...but hey, how much simpler could it be?
 Rest assured, I will be relying on Mr. Garmin and Mr. Dynon for navigation...not Mr. Jobs (cool as that might be).
 Fred
 On Dec 28, 2010, at 4:19 AM, Paul Atkinson wrote:
  	  | Quote: | 	 		  I have  a cigar lighter socket on the panel into which I plug a usb car charger. You will find dozens on Amazon, I think mine was made by Griffin.
 Cheers
 Paul
 On 28 December 2010 04:50, Fred Klein <fklein(at)orcasonline.com (fklein(at)orcasonline.com)> wrote:
  	  | Quote: | 	 		  --> Europa-List message posted by: Fred Klein <fklein(at)orcasonline.com (fklein(at)orcasonline.com)>
 Given limited battery life of iPad/iPhone, has anyone found a cord which can plug directly into a 12v power source, and a receptacle which could be wired into and located on the instrument panel? |
		gholland(at)content-strea Guest
				 Posted: Tue Dec 28, 2010 10:40 am    Post subject: phones for flying |
				Fred
  Mr Jobs could supply you with a great phone and a ‘back up’ GPS facility + weather reports.
  Mr Dynon is another great player so your choice is lot easier than it was 5 or 10 years ago.
  Get building now!
  Kind Regards and finish building in 2011!!!!
  Gerry
		n100rh(at)sbcglobal.net Guest
				 Posted: Tue Dec 28, 2010 1:51 pm    Post subject: phones for flying |
				At the risk of beating a dead horse...
      Be sure and not use your polarized sun glassed with the iPad, scared     the poo out of me the first time I used it. Looked at iPad for chart     and it was BLACK, I thought the battery was dead! Nope, just the     bone head using the sun glasses.
      Ralph
      On 12/28/2010 10:36 AM, Gerry Holland wrote:     [quote]       Re: phones for flying       Fred
            Get building now!
            Gerry
		rampil
				 Posted: Tue Dec 28, 2010 4:27 pm    Post subject: Re: phones for flying |
				Hi David,
 Try the company website at http://www.xample.ch/
 The official name is Air Navigation Pro.
 Check it out, you might be pleased.
 Hi Garry,
 The georef plates are an interesting issue. It would make sense
 That the necessary data is within the compressed PDF. However,
 In a burst curiosity, I disassembled and decompressed some
 Plates straight from NACO.  Amazingly, it is not there, not in
 the standard public release. Amazingly, the PDFs actually contain
 a vectorized version of the all the tiny little strokes on the page, not
 the geometry. Secure I suppose, but extremely inefficient, space wise.
 There is a single company in Seattle that apparently gets better PDFs or
 additional information from NACO.  Those that do georeferenced plates
 at the moment, all use this company's product.  If Foreflight is going
 With them, we can expect to pay more ;(
 Stay warm Garry!
				 Posted: Tue Dec 28, 2010 4:34 pm    Post subject: phones for flying |
				Fred
 You can buy a cheap cigar lighter power supply cable, cut the plug off and wire it in directly. Be careful though, the output won't be 12 volts so you need the one for the device you want to use.
 regards
 Graham.
 Sent: Tuesday, 28 December, 2010 18:23:58
 Fred
 [quote]der's Bookstore a rel="nofollow" target="_blank" href="http://www.matronics.com/Navigblank" href="http://forums.matronics.com">http://forums.matronics.com===============[b]
				 Posted: Thu Dec 30, 2010 7:54 am    Post subject: phones for flying |
				Ira, Thanks. Air navigation Pro is a totally different animal from NavPro
 and looks to have real potential. Happy New Year, David
				 Posted: Thu Dec 30, 2010 9:14 am    Post subject: phones for flying |
				Steve
 Iphone 4 loads of apps for flying and finding a hotel, car etc when you get there.
 Kevin
 On 26 Dec 2010, at 17:15, "Steven Pitt" <steven.pitt2(at)ntlworld.com (steven.pitt2(at)ntlworld.com)> wrote:
 [quote]  My mobile is coming to the end of its life so I am  looking for a new one. Can anyone give recommendations especially with flying  apps availability.
  Steve Pitt
