DanM
Joined: 16 Nov 2006 Posts: 64 Location: Kingsburg, Calif.
Posted: Sat Jan 01, 2011 11:34 am Post subject: Wing tank fuel filters |
I'm right in the middle of changing out all my fuel lines, getting rid of the original factory stuff. Is it over kill or a good idea to have fuel filters from the wing tanks to just before the header tank and one filter just before the carb inlet. Opinions and thoughts on this appreciated.
_________________ Dan Mc Intyre
Kitfox IV
Jabiru 2200 SN 1311 , 59.7 hours
Sensenich 62x46
N443DM |
Av8r3400
Joined: 22 Sep 2008 Posts: 83 Location: North Central Wisconsin (KRRL)
Posted: Sat Jan 01, 2011 12:16 pm Post subject: Re: Wing tank fuel filters |
(Same as I posted on the other board)
My opinion and its only one man's opinion:
I do not like the idea of a filter between the wing and header tanks. The only flow there is via gravity. A small amount of water contamination could block the flow through these filters. Personally, I only like a filter where a pump provides positive flow through it.
_________________ Thanks,
Av8r3400
Kitfox Model IV-1200 W/912UL & IVO
Kitfox Model IV-1050 W/912UL & Warp
YouTube Videos |
kitfox555(at)sbcglobal.ne Guest
Posted: Sat Jan 01, 2011 12:21 pm Post subject: Wing tank fuel filters |
[quote][b] [quote][b]
Lynn Matteson
Posted: Sat Jan 01, 2011 1:12 pm Post subject: Wing tank fuel filters |
Dan-
That is exactly what I have on my plane right now, and ever since I
first built it....Purolator see-through glass filters between both
tanks (3/8" lines) and header tank, and another one before the fuel
flow meter/TBI inlet. In fact, I have added front ports to my wing
tanks, and I also use the same filters in those down-lines. So a
total of 5 filters in the system...maybe overkill, but nothing gets
into the TBI but fuel....oops, I forgot that the TBI also has what
they call a "last chance filter" which is inside the body of the
TBI...call it 6 filters. : )
Lynn Matteson
Jabiru 2200, #2062
Sensenich 62"x 55.5 Wood (winter) until the Prince prop arrives
Rotec TBI-40 injection
Status: flying...1075+ hrs (since 3-27-2006)
On Jan 1, 2011, at 2:34 PM, DanM wrote:
<danm(at)powerdesignelectric.com>
Dan Mc Intyre
Kitfox IV
Sensenich 62x46
N443DM
http://forums.matronics.com/viewtopic.php?p=325207#325207
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
Guy Buchanan
Posted: Sat Jan 01, 2011 1:36 pm Post subject: Wing tank fuel filters |
On 1/1/2011 11:34 AM, DanM wrote:
| Quote: | I'm right in the middle of changing out all my fuel lines, getting rid of the original factory stuff. Is it over kill or a good idea to have fuel filters from the wing tanks to just before the header tank and one filter just before the carb inlet. Opinions and thoughts on this appreciated.
Personally I run big 3/8" lines with no filters down to the header tank.
(I do have the finger strainers in the tank, though.) I then have one
big race-car filter just outside the header tank on the way to the fuel
pump. The idea is to get all the crud down to the header tank so I can
sump it. If I'm getting floaties then I'll see them when I sump the
header, and the filter will stop them. (It's a huge filter, probably
12si of area so it should take a long time to clog.) I've personally
experienced too many flow-limitation problems with the small glass
filters typically seen between the tank and the header.
Guy Buchanan
Kitfox IV-1200 / 592-C / Warp 3cs / 500 hrs and not counting.
Deceased K-IV 1200
A glider pilot too. |
DanM
Posted: Sat Jan 01, 2011 4:16 pm Post subject: Re: Wing tank fuel filters |
I currently have a clear filter on each down line and one just before the carb. I have been experiencing unequal flow especially from the left tank it seems to draw down much faster than the right take. I think it may have something to do with filters the filters I'm using.
I'm changing the tank hose to header to 3/8 I.D, I have 5/16 aluminum tube to the firewall. Then I will install either 5/16 or 1/4 I.D line from the firewall to the carb. The carb inlet is 1/4" I think.
Kitfox IV
Sensenich 62x46
N443DM |
lcfitt(at)sbcglobal.net Guest
Posted: Sat Jan 01, 2011 5:51 pm Post subject: Wing tank fuel filters |
Dan,
I see that there are lots of opinions on this one. I have one as well. I
used the auto fuel lines from the wing tanks to the header tanks, and like a
couple of guys I liked to see the fuel running to the header tank so used
the glass filters just above the seat back. I am about to run the fuel
lines on my new project and will do the same. On one trip down the Sierras
to home, I was in a fairly steep descent for a bit over half an hour and
wanted to see the fuel as the rearward ports on the wing tank started
sucking air. It did and I was able to see it and liked to be able to see
it.
Lowell
Sent: Saturday, January 01, 2011 11:34 AM
Subject: Wing tank fuel filters
Dan Mc Intyre
Kitfox IV
Sensenich 62x46
N443DM
thesupe(at)hotmail.com Guest
To each his own, but I will never have the filters between the wing tanks and header tank. My only off field landing to date has been because of a plugged filter between the wing tank and header. That was after about 300 hrs of flying 9 different 2 stroke engined ultralights. My thinking is let the header tank catch whatever gets past the finger strainers, it is actually a large gascolator and so that's what it's made to do. It doesn't take much to slow up the flow in a gravity feed situation and that is what you have between the wings and header tank. I now have a filter after the header tank and have not had similar problems in the last 300+ hrs. Take care,
Jim Chuk
Avid MK IV (flying)
Kitfox 4 (building)
northern Mn
> Subject: Re: Wing tank fuel filters
| Quote: | From: danm(at)powerdesignelectric.com
Date: Sat, 1 Jan 2011 16:16:09 -0800
--> Kitfox-List message posted by: "DanM" <danm(at)powerdesignelectric.com>
Dan Mc Intyre
Kitfox IV
Sensenich 62x46
N443DM
http://forums.matronics.com/viewtopic.php?p=325235#325235
&g==================
Fox5flyer Guest
Posted: Sun Jan 02, 2011 3:39 am Post subject: Re: Wing tank fuel filters |
Fortunately for the experimental movement, there is no "right way or wrong way" to do anything and the best thing about it is that it has brought the visionaries out of the woodwork and given them the authority and opportunity to put their ideas into operation. Some ways are better than others and hopefully all of these different methods will lead most of us into making a choice that is efficient, prudent, and safe.
Like, Jim, I do not use the wing tank filters for the same reasons. And like Guy, I use 3/8" fuel lines throughout. The header tank is a huge gascolator that does the job nicely. At the end of the line I have a large racing fuel filter (last chance). My philosophy is keep the fuel flowing with as few restrictions as possible. I minimized the use of any unnecessary fittings where I could and when I did use them I ensured they were good ones. I always tried to make gentle flowing bends in the piping wherever possible. Keep in mind that every fitting creates a flow restriction as well as a potential leak point. I also use a good quality full flow 3/8" shutoff on the console. No fuel related problems in close to 500 hours.
Deke Morisse
S5 Subaru
NE Michigan
[quote="thesupe(at)hotmail.com"]To each his own, but I will� never have the filters�between the�wing tanks and header tank.� My only off field landing to date has been because of a plugged filter between�the wing tank and header.� That was after about 300 hrs of flying�9 different 2 stroke engined ultralights.� �My thinking is let the header tank catch whatever gets past the finger strainers,�it is actually a large gascolator and so that's what it's made to do.� It doesn't take much to slow up the flow in a gravity feed situation and that is what you have between the wings and header tank.�� I now have a filter after the header tank and have not had similar problems in the last 300+ hrs.� Take care,�
Jim Chuk
Avid MK IV� (flying)
Kitfox 4 (building)
northern Mn
[quote] From: danm(at)powerdesignelectric.com
--> Kitfox-List message posted by: "DanM" <danm>
Dan Mc Intyre
Kitfox IV
Sensenich 62x46
N443DM
Lynn Matteson
Posted: Sun Jan 02, 2011 7:13 am Post subject: Wing tank fuel filters |
Yes, the Bing inlet is 1/4".
Lynn Matteson
Jabiru 2200, #2062
On Jan 1, 2011, at 7:16 PM, DanM wrote:
I'm using.
I think.
Dan Mc Intyre
Kitfox IV
Sensenich 62x46
N443DM
N369LM |
pwmac(at)sisna.com Guest
Posted: Mon Jan 03, 2011 10:36 am Post subject: Wing tank fuel filters |
.Totally agree
If one must see fuel take the element out of the glass filter. Any
restriction or pressure drop in those lines is very bad news and that
is exactly what fittings and filters create.
Why one must see fuel in a line is way beyond my thought process. I
have never heard of any vehicle except Kitfoxes that have fuel
visible in the lines.
Nice fat lines (3/8") are overkill, use them and let the junk travel
to the low point so it can be purged.
Paul
At 05:49 PM 1/1/2011, Jim_and_Lucy Chuk wrote:
| Quote: | To each his own, but I will never have the filters between the wing
hrs. Take care,
Jim Chuk
Avid MK IV (flying)
Kitfox 4 (building)
northern Mn
