is battery filter or dead weight?
jan_de_jong(at)casema.nl
PostPosted: Sun Jan 02, 2011 9:31 am    Post subject: is battery filter or dead weight? Reply with quote
A question.
Is a fully charged 12V lead-acid battery held at 14V a voltage stabiliser?
People seem to think so but I doubt it.
If you disconnect the battery while the alternator consistently puts out
over 13V will there be much difference in AC components on the bus?
Is there an AC on top of DC internal impedance measurement out there
somewhere that I can't find a reference to?
I hope somebody knows more.
Thank you.
Jan de Jong
Float Flyr
PostPosted: Sun Jan 02, 2011 2:37 pm    Post subject: is battery filter or dead weight? Reply with quote
The battery in the circuit will help dissipate voltage spikes. If your
generator goes into an overvoltage charge situation it won't take long to
boil the battery. Once that happens the buss will go overvoltage too,
Noel
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
PostPosted: Mon Jan 03, 2011 4:34 am    Post subject: is battery filter or dead weight? Reply with quote
At 11:23 AM 1/2/2011, you wrote:
--> AeroElectric-List message posted by: Jan de Jong <jan_de_jong(at)casema.nl>
A question.
If you disconnect the battery while the alternator consistently puts out over 13V will there be much difference in AC components on the bus?
Is there an AC on top of DC internal impedance measurement out there somewhere that I can't find a reference to?
I think you've already identified the battery
filter myth . . . a myth I once propagated.
There was a sort of "giant capacitor" quality
ascribed to batteries that kind of made sense.
Batteries are indeed a huge energy source/sink
for their size.
If you study battery behavior you'll discover
that they are very non-linear devices. The term
"internal impedance" does not describe a simple
resistive or reactive loss. While a battery
is being heavily discharged (say 12.0v and below)
it can be said to have a very low internal impedance
on the order of tens of milliohms. But while
being charged at 14.0 volts and above, that
impedance value rises. Worse yet, when
the battery is fully charged, it's internal impedance
goes waaayyyy up.
This is why Mil-Std-704 tells us to EXPECT bus voltage
excursions of 3v pk-pk over the range of
1000 to 5000 Hz on a 28v system (1/2 that
on a 14 volt system). The expected/permissible
levels drop off on either side of that band:
[img]cid:.0[/img]
Further, 704 is silent as to whether or not there is a battery
present. And it makes sense. A fully charge battery floating
on a normal bus is electrically 'transparent'.
If you experience an alternator runaway, the battery will offer
a significant mitigating load that joins with system loads to
drive the alternator into a current limited mode. This is helpful
in holding down bus voltage while the ov protection system
takes a few tens of milliseconds to shut it down.
Obviously, when the alternator fails, the battery can be
expected to provide the alternate source of energy albeit at
reduced voltage. But as a "filter" small transients that we
call noise, the battery is of no practical value. Dead weight?
Hope not. The thoughtfully maintained battery is the most
reliable source of energy on the airplane.
 Filesize:  115.17 KB
 Viewed:  11293 Time(s)
PostPosted: Mon Jan 03, 2011 4:45 am    Post subject: is battery filter or dead weight? Reply with quote
Thanks.
I realise that the battery will not allow excursion below 12.5V and will
be an increasing load above 15.5V as long as it lives.
I wonder about its filtering role around 14V when it's neither drawing
or supplying current which is the standard situation.
What might be an equivalent load of capacitor, resistor and inductor
combination?
Jan
The question is not urgent
[quote] Time: 02:37:38 PM PST US
Subject: RE: is battery filter or dead weight?
Noel
PostPosted: Mon Jan 03, 2011 6:38 am    Post subject: is battery filter or dead weight? Reply with quote
At 06:42 AM 1/3/2011, you wrote:
Thanks.
will be an increasing load above 15.5V as long as it lives.
drawing or supplying current which is the standard situation.
combination?
I've never considered researching an "equivalency" . . .
It would depend heavily both on size of the battery
and its physical condition. Given that noise values
for battery-in versus battery-out are indistinguishable
from each other says that noise mitigation benefits,
if any, are insignificantly small.
Eric M. Jones
PostPosted: Mon Jan 03, 2011 6:40 am    Post subject: Re: is battery filter or dead weight? Reply with quote
It is a little hard to discover if big commercial aircraft have batteries at all. My guess is that they have some efficient small battery to start the APU, and not much more. Can an airplane be built without a battery? Sure. There is a large Russian airplane that can be parked all Winter, then started with the compressed air stored from a previous flight. If it doesn't start, you have your prisoners hand-pump in more compressed air.
So having a battery is convenient for starting the airplane, and seems to be a stabilizing load for the alternator. If the battery is disconnected, plan on some other stabilization for the alternator, because what comes out of the alternator is a bumpy DC whose bumps are proportional the the alternator RPM. Modern electronics are perfectly capable of doing this as well as a big battery, but modern electronics are going to POL (Point-of-Load), where the "main" power supply is no longer forced to provide various voltages at various currents and various stabilities. Instead a single (and perhaps higher voltage) power line runs around the aircraft, and is then changed at the load to whatever the load needs by tiny little ICs. This has advantages from several angles, perhaps the main one being that the system supply and buses don't easily become obsolete.
In my little airplane a-building, I plan an internally-regulated ND alternator and a power filter using a capacitor, and inductor, Zener and just a few other parts to give far better filtering than standard Cessnas. Why this is not routine practice mystifies me.
I might also find a reason to put in a 1.0 F supercapacitor sitting on my shelf. Such a reason might be that it would reduce the wire size between my battery and the starter, while (it has been shown) cause the battery life to soar.
Eric M. Jones
www.PerihelionDesign.com
113 Brentwood Drive
Southbridge, MA 01550
(508) 764-2072
emjones(at)charter.net
PostPosted: Mon Jan 03, 2011 2:13 pm    Post subject: is battery filter or dead weight? Reply with quote
The first time I saw the B-57 Canberra,
it was preparing to leave an air show at
McConnell AFB
http://www.b-57canberra.org/b-57sounds.htm
Those were late 40s engines too. It was
amazing to think that a thing which made so
much smoke and noise was doing all that
because it was the best-they-knew-how-to-
do at the time.
Other airplanes have used a variety of
energy sources for engine cranking. I
was once invited to crank up the flywheel
on the engine for getting it started without
success. It's not mean task.
Our J-3 at 1K1 would start on the first
pull of a blade . . . IF you carried out
the right combination of preparation (and
had the prop clocked right on the hub).
Each system left the factory having met certain
design goals. Those goals might be driven by
some combination of customer specs, weight,
costs, space, etc. Some of them caught on in
the consumer markets, others were relegated to
the annals of historical curiosities.
I think we've discussed and demonstrated that
batteries are not "stabilizers" in the common
sense of the word. The battery will assist a
wound field alternator in getting started.
However, the alternator doesn't need the battery
to provide useful output. They will run self-excited
as long as you don't hit the machine with a
hi inrush load that exceeds it's output
current rating thus stalling it.
At Cessna in 1967 or so, we fiddled with ways
to kick start alternators on the 337 should the
battery become unavailable. Ideas included (1) array
of D-cells OR (2) a 3-phase rectifier off the tach
generator. These small energy sources could be
tapped by means of a panel mounted push button
to get the alternators on-line. They were operated
in parallel with one regulator.
Neither idea made it to production as I recall.
We were sandbagging a failure that was very low
on the ladder of probability. That was about
20 years before the idea of a dual feed e-bus
blossomed. THAT would have been a very simple,
low cost alternative to the dragons of the day.
Have you ever put a 'scope on the bus of
your car, started the engine, and taken trace
pictures of the battery-connected versus
battery disconnected? I was hard pressed
to see any differences. System load had more
effect on noise than the presence of a battery.
I'd like to put a spectrum analyzer on the system
sometime and get some real numbers.
What supplies and busses have or are becoming
obsolete? Especially those which have or currently
find favor in small airplanes? What are the design
goals driving that "obsolescence"? Do these proposed
technologies portend lower cost, higher reliability,
less weight, increased performance?
I recall visiting a booth at OSH about 15 years ago
where the proprietor was demonstrating an advanced
power distribution and control system. He had a control
box with switches on it for nav, strobe, landing and
taxi lights. One power/data wire came out of the box
and ran to each of those fixtures. Digital data was
transmitted to smart controllers over the power wire
to turn them on/off. What could be simpler? One wire
does it all.
The implications for single points of failure, increased
parts count, increased cost of ownership, etc were
profound. I didn't see him there the next year.
I have perhaps a dozen tools that will set a nail or
stable style fastener. Some electric, some air driven.
But sometimes the best way to drive a nail is with a
hammer. Hammers have been around for a long time.
In what way? Cars, trucks and all manner of ground
based vehicle have been doing these things for over
100 years to the tunes of hundreds of millions of
examples. Airplanes to hundreds of thousands of
examples. Is it your assertion that the designers
of these vehicles have stubbed their intellectual
toes and failed to exploit some process that
promises improved performance at lower costs of
ownership? As you fly along in any airplane of
any age, are you painfully aware of some deficiency
of performance that cries out for a quieter bus.
Haven't heard of that one. Can you enlighten us
as to the simple-ideas in physics that support
these assertions? 1 Farad hit with a 100A load
discharges at 100 volts per second. This means
that the capacitor will support the battery for
something on the order of 30 milliseconds after
onset of a start cycle. How is this beneficial
to battery life?
Eric M. Jones
PostPosted: Mon Jan 03, 2011 4:30 pm    Post subject: Re: is battery filter or dead weight? Reply with quote
to battery life?
Batteries are electrochemical are are thus affected by temperature. SuperCaps, being electrostatic have no such problem. Thus they are fastened near the starter and help immensely starting engines in cold climates, or with weak batteries one might suppose.
Starting an engine is usually separated into three phases: Breakaway, takes the greatest current as the starter overcomes the static friction of the cold engine. A SuperCap helps enormously in this breakaway and load shares with current from the battery, albiet for a short time. Nobody said the initial current was 100A. In fact the SuperCap has the ability to discharge much faster than the battery--they are very low ESR.
In my earlier life a problematic solenoid attached to a limited supply would just have a capacitor attached to it (and a diode and a resistor to discharge it fast and recharge it slowly) so that the capacitor would dump current through the coil. The plan I mentioned is similar.
But hey, nobody said I suggest this for everyone. But I just might do it.
Eric M. Jones
113 Brentwood Drive
(508) 764-2072
PostPosted: Mon Jan 03, 2011 7:27 pm    Post subject: is battery filter or dead weight? Reply with quote
Batteries are electrochemical and thus affected by temperature.
I'm having trouble calibrating "immensely" . . .
Absolutely . . . but while capacitors have a greater ability
to deliver CURRENT, their ability to deliver ENERGY is
the fact I'm wrestling with. Total energy stored on a
1F capacitor at 12v is CE(squared)/2 or 72 watt-seconds.
The capacitor can deliver energy into the cranking task
only until its terminal voltage drops to some value equal
to the battery terminal voltage . . . lets assume a cold
weather worst case of 8v whereupon the capacitor still
contains 1*8^2/2 or 32 watt-seconds. Hence, the paralleled
capacitor can offer 40 watt-seconds of stored energy to the
task of getting the engine started for about 50 milliseconds
topes . . . . Assume 100A (small engine) and 9 volts average
for 10 seconds gives 100 * 9 * 10 = 9000 watt-seconds. So
perhaps we see the capacitor contributing less than 1/2 of
1% into the first 1/20 of a second of a cranking scenario.
Does this agree with your calibration of "immensely"?
But of course . . . you're getting a boost for the
purposes of aiding an event that takes perhaps 10
milliseconds total and a current level on the order
of tens of amps . . . not ten seconds for hundreds of
amps. These are not similar energy transfer
scenarios.
Understand. You brought forth an idea that suggested
"soaring battery life" . . . I'm just making sure
I've not overlooked some new discovery.
PostPosted: Tue Jan 04, 2011 8:39 am    Post subject: is battery filter or dead weight? Reply with quote
Thank you very much for confirming my model of lead-acid battery.
So battery is:
- backup energy source
- engine starting energy source
- overvoltage slowdown load
- negligible filter
Ultracap is fascinating but it is hard to find a compelling use.
With http://www.maxwell.com/docs/DATASHEET_K2_SERIES_1015370.PDF
one could make a 100F, 16.2V, 5mOhm capacitor weighing 1 kg for $500 or so.
Multiple seconds of starting amps.
Leakage 1.5 mA or more than 1Ah per month though.
And would need six 2.75V 0.5A or so power zeners made and very reliable OVP.
For $150 or so one could make a 8Ah, 13.2V, 8mOhm LiFePO4 battery
weighing 1.5 kg or so:
http://www.evassemble.com/index.php?main_page=index&cPath=2&zenid=s0l174nirkm5s4ltndf75rt9f2
Minutes of starting amps.
Leakage 0.3 mA or so.
Would need four 3.75V full charging current power zeners made and a
heatsink temperature controlled alternator switch.
Function then automatically includes 15V OVP.
Alternator needs set at 14.6V.
And not very good at low temperatures:
http://www.lifebatt.com/sandiareport.pdf
Jan de Jong
PostPosted: Tue Jan 04, 2011 10:11 am    Post subject: is battery filter or dead weight? Reply with quote
So battery is:
- negligible filter
<snip>
What you have discovered is that not every
"problem" is begging to be solved. A proposed
advancement to the state of our art needs to be
evaluated for a host of unknowns . . .
What's the impetus for 'solving' this 'problem'?
Will anything on the airplane work better if the
bus noise is reduced? What is the probability
that making this change will add any observable
or measurable value for the way I use my airplane?
What does it cost to own this feature over the next
10 years?
Burt Rutan beat us up for grams of weight savings
but didn't care if the system was any quieter than
what you might find in a C-172. I don't know what
size batteries he ended up with . . . but you can
bet it was a carefully considered decision. When
I was asked to convert a LongEz into a spook airplane
loaded with sensitive receivers, noise became the
paramount issue. Whole different mission.
The point is that latching onto the latest and
greatest electro-whizzy may or may not have a
return on investment. Throughout our culture,
there's an almost primal urge to step up to
the new and improved but without regard to
whether or not the thing being replaced really
needs to be replaced.
If I were to rent an airplane tomorrow, I'd be
just as comfortable navigating to intended
destination using the Wallmart Magellan
GPS I introduced to The OBAM aircraft industry
13 years ago.
http://aeroelectric.com/articles/nailgun.pdf
But MOST important, make sure that the proposed
change is integrated into the system with thoughtful
understanding of all the simple-ideas that makes
the thing work. It will reduce if not eliminate those
"Aw #$#%" moments in the cockpit.
Eric M. Jones
PostPosted: Wed Jan 05, 2011 6:21 am    Post subject: Re: is battery filter or dead weight? Reply with quote
The 1 Farad cap I mentioned is pitifully small (Hell, it shows my age that I was impressed). Here is a 3000F (-0/+20%!) Cap:
maxwell.interconnectnet.com/ultracapacitors/datasheets/DATASHEET_K2_SERIES_1015370.pdf
On Ebay a guy is selling five cases of these (2.7V) 15 per case, for $775/case OBO. You'd need 5-6 of these to make a proper cell. (In series total capacitance is 1/(n/C), but you'd still get 500 F at 14V or so)
A few years ago the caps were used more for starting purposes, now they are advertised more for "energy saving" applications, like stop-start engines, and providing a boost when starting hybrid cars from a standstill.
See also: maxwell.com/products/ultracapacitors/applications/cold_starting.aspx
Eric M. Jones
113 Brentwood Drive
(508) 764-2072
PostPosted: Wed Jan 05, 2011 2:18 pm    Post subject: is battery filter or dead weight? Reply with quote
Okay, that's a whole new paradigm.
http://www.greencar.com/articles/ultrabattery-combines-battery-supercapacitor-power.php
http://www.technologyreview.com/biztech/18086/
from a standstill.
Ultracaps been proposed and even advertised for a host
of "new and improved" performance . . . but compared
to what product and for what purpose?
I think it was Mallory that proposed a capacitor
replacement for a lead-acid battery a few years ago
for cranking over the road truck engines. I think
I saw some catalog sheets on product. Maxwell is offering
catalog items with interesting specs . . .
http://www.aeroelectric.com/Mfgr_Data/Capacitors-UltraCaps/Maxwell_BMOD-Series_Ultracaps.pdf
These or similar products may very well be the
solution to engine cranking design goals. Right
now, an OBAM airplane using a $75, 17 a.h. lead
acid battery can plan to support a 4 a load for
3 hours when new, 2.4 hours at end of life. 2.4
hours at 11 volts average and 4 amps is 380KJ of
standby energy.
A capacitor being discharged from 14 to 10.5 volts
delivers 47 Joules/Farad. The equivalent storage
for a lead-acid replacement is something on the
order of 8000 Farads or 16 of the Maxwell modules
connected in parallel for about 800 cubic inches.
Methinks 16 of these critters is larger and a lot
more expensive than the 17 a.h. battery.
I worked lead-acid battery project for HBC a couple
years ago that proposed to used lead-plated carbon
fibers . . . MUCH lighter. Thinner plates with really
good performance numbers. That product turned
out to be made mostly of smoke, mirrors, and computer
models that 'neglected' a few important variables.
I have no doubt that somebody will replace or even
augment the SVLA battery somewhere sometime. If a sense
of history serves us well, it will be years after
Honda, Kia or Chrysler puts a few millions of
consumer road-miles on them before they become
an economic practicality for the OBAM aircraft.
I don't expect to live to see it . . . but I'd be
tickled pink to be proven wrong.
