Tailwheel Dolly
occom
PostPosted: Sun Jan 02, 2011 8:36 am    Post subject: Tailwheel Dolly Reply with quote
My ability to pull/push the Kitfox over the gravel floor has diminished somewhat lately. I was thinking of a Dolly arrangement that may help. Surely some of you have devised or purchased something to help with this task. Ideas would be appreciated.
(New knees on order!)
Dave Goddard
KF IV 1050 / 582 / Warp
Tom Jones
PostPosted: Sun Jan 02, 2011 3:33 pm    Post subject: Re: Tailwheel Dolly Reply with quote
Dave, I can move my kitfox around on the gravel with the wings folded with my tail wheel scoop. I can even scoop up the tail after the wings are folded. The wheels are 10 in pneumatic from harbour freight.
http://www.harborfreight.com/10-inch-pneumatic-tire-30900.html
Feel free to copy and modify the design if you want. Wink
 Filesize:  83.69 KB
 Viewed:  11053 Time(s)
 Filesize:  97.24 KB
 Filesize:  67.64 KB
Tom Jones
Classic IV
Ellensburg, WA
Float Flyr
PostPosted: Sun Jan 02, 2011 7:00 pm    Post subject: Tailwheel Dolly Reply with quote
May i suggest attaching a carrying block to the bed of a Radio Flyer. Put
the tail wheel in the block and then fold the wings. Moving the plane
should then be very easy.
Noel
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
Dick Maddux
PostPosted: Mon Jan 03, 2011 5:37 am    Post subject: Tailwheel Dolly Reply with quote
Dave,
I use a commercial product called a "tail dragger dragger" I have used it for years and it works well. You might do an Internet search or spruce may have it.
        Dick Maddux
        Milton,Fl
Vic Baker
PostPosted: Mon Jan 03, 2011 6:46 am    Post subject: Tailwheel Dolly Reply with quote
This works well on solid surfaces provided wings are NOT folded. Don't know about your gravel floor.
http://www.aircraftspruce.com/catalog/pspages/taildragger.php
Vic Baker
S7 912S Warp
Carson City, Nv
Vic Baker
Series 7
Carson City, Nevada
Pat Reilly
PostPosted: Mon Jan 03, 2011 2:03 pm    Post subject: Tailwheel Dolly Reply with quote
Tom, Ingenious tailwheel scoop? Is it FAA certified? I will build one. Do not archive
Pat Reilly
Mod 3 Rebuilt
Rockford, IL
On Sun, Jan 2, 2011 at 5:33 PM, Tom Jones <nahsikhs(at)elltel.net (nahsikhs(at)elltel.net)> wrote:
--> Kitfox-List message posted by: "Tom Jones" <nahsikhs(at)elltel.net (nahsikhs(at)elltel.net)>
Feel free to copy and modify the design if you want. [Wink]
Tom Jones
Classic IV
Ellensburg, WA
http://forums.matronics.com/viewtopic.php?p=325355#325355
http://forums.matronics.com//files/tail_wheel_scoop1_105.jpg
http://forums.matronics.com//files/tail_wheel_scoop2_968.jpg
http://forums.matronics.com//files/tail_wheel_scoop3_143.jp===================
y Browse, Chat, FAQ,
="http://www.matronics.com/Navigator?Kitfox-List" target="_blank">http:=====
http://forums.mle, List Admin.
Pat Reilly
Mod 3 582 Rebuild
Rockford,IL
Tom Jones
PostPosted: Tue Jan 04, 2011 8:44 am    Post subject: Re: Tailwheel Dolly Reply with quote
This might work if the surface is packed down pretty good. I tried some narrow hard rubber wheels on my proto type but they would dig in with the wings folded on my gravel driveway. You could probably easily put a pair of the harbor freight pneumatic wheels on it for use on a soft surface.
Tom, Ingenious tailwheel scoop? Is it FAA�certified
I have an STC for use on Certified aircraft. You will have to send me $25 if you want to use it on a FAA certified aircraft. No permission required for use on a kitfox. Wink
Tom Jones
Classic IV
Ellensburg, WA
