william(at)gbta.net Guest
Posted: Mon Jan 03, 2011 10:50 am Post subject: Riveting leading edges to wings |
I'm almost ready to rivet the leading edges to the main wing spar. We are given the option of using LP4-3's on the outboard two ribs. It looks like this will be quite a bit easier than using the AN470AD4-5's. Has anybody used the LP4-3's? If so, are you satisfied with the results. Are there any drawbacks to using the pulled vs. the driven rivets.
Also, on Tim's site he mentions that the LP4-3's seemed a bit short. Do I need to get longer rivets or do the -3's work good?
Thanks in advance,
Bill
tsts4
Posted: Mon Jan 03, 2011 11:40 am Post subject: Re: Riveting leading edges to wings |
I went the LP4-3 route and they turned out fine. I wasn't originally but when the time came I just felt shooting the solid rivets was an aggravation fest waiting to happen and chose the easier method. No regrets whatsoever.
_________________ Todd Stovall
aka "Auburntsts" on EAA and VAF
RV-10 N728TT -- Flying |
rv10flyer
Posted: Mon Jan 03, 2011 6:57 pm Post subject: Re: Riveting leading edges to wings |
LP4-3's for mine. If Van's engineers give me the option and the chances of making a mistake with an offset rivet set are high, I will go with pop rivets. I keep several CherryMax rivets of every size from 1-5(univ & csk) for those most likely places to screw up. I would not want to build the entire plane with LP4-3, CS4-4, or CherryMax because it would probably weigh 50 lbs more and cost several thousand more.
_________________ Wayne G. |
