HKS and 701 ?
frank.goodnight(at)att.ne
PostPosted: Tue Jan 04, 2011 8:00 am    Post subject: HKS and 701 ? Reply with quote
Hi All,
I'm new to this list. I now fly a kolb firestar2 with the HKS 700e engine. Plan to purchase a 701 or a 750 kit
in the near future. Will someone on this list help me with information so I can make the best decision?
If someone has put a HKS engine on a 701 and it is a good preformer and they are happy with it, that is
the way I would prefer to go, simply because I already have the engine ( read economics). However if it
would be a poor preformer. I would bite the bullet and go with the 750 even at a cost of 15 to 20 k more.
I have heard that the newer models of the 701 are quite a bit heaver than the original 65hp mod. also
I am a large person --6ft 250lb. Please put your heads togeather and share the knowledge that will save
me the time,energy ,money and frustation that will be wasted if I make the wrong choice. I will be going to the factory in the next month or so and get a ride in oth planes ,but I think they both have 100 hp engines so don"t
know how much that will help. They say the HKS is doable as the 701was designed for 50 to 100 hp, but don"t encourage -discourage-or support it.
Frank Goodnight
dougsnash
PostPosted: Tue Jan 04, 2011 11:50 am    Post subject: HKS and 701 ? Reply with quote
Frank, I have a 701 with a 912ul. While the 701 might work with a HKS, I think you will find the 701 pretty tight. Given your dimensions, I think you'll find the 750 a much better fit.
Doug MacDonald
CH-701 C-GBQX
Northwestern Ontario, Canada
Phase one
Sent from my iPad
On 2011-01-04, at 9:55 AM, frank goodnight <frank.goodnight(at)att.net (frank.goodnight(at)att.net)> wrote:
[quote]Hi All,
Frank Goodnight
PostPosted: Tue Jan 04, 2011 1:15 pm    Post subject: HKS and 701 ? Reply with quote
Hi Doug,
Thanks for your thoughts, Useful info.
Frank
To: "zenith701801-list(at)matronics.com" <zenith701801-list(at)matronics.com>
Sent: Tue, January 4, 2011 1:49:03 PM
Subject: Re: HKS and 701 ?
Doug MacDonald
CH-701 C-GBQX
Phase one
Sent from my iPad
[quote] Hi All,
Frank Goodnight
[b][b]
tclongo(at)att.net
PostPosted: Tue Jan 04, 2011 5:36 pm    Post subject: HKS and 701 ? Reply with quote
On 1/4/2011 10:55 AM, frank goodnight wrote:
Hi All,
Frank Goodnight
Hi Frank, I remember you from the Kolb list. I had an MK III with a 582 that I sold to Ellery and built the 701 with 912uls which I like very well, I would go with the 750 in your case.
Tom
kmccune
PostPosted: Sun Jan 09, 2011 5:17 am    Post subject: Re: HKS and 701 ? Reply with quote
Frank,
I weight 170 and my wife.. well quite a bit less Wink We fit fine in the 701, but even at our size I wish the 750 had been released 6 mo earlier.
think about your 250 lbs, the 120 lbs of fuel, the 40 lbs of cargo, can you still carry another person? The thing would weigh less with the HKS then with a 912 so there is some room there. I struggled with this for 1 1/2 years and the only thing that saved the 701 is all my time and the fact that we are not large people. But I'd rather be building a 750.
My $.02 ...my Dad could rub these together and make change!
Kevin
R.W. Emerson (1803-1882)
Dorothy McCune
PostPosted: Sun Jan 09, 2011 6:50 am    Post subject: HKS and 701 ? Reply with quote
Hi Kevin,
Thanks for your thoughts. I have had several responses and the opinions vary.But each one is valuable to me.
Thanks again.
Frank
Sent: Sun, January 9, 2011 7:17:12 AM
Subject: Zenith701801-List: Re: HKS and 701 ?
--> Zenith701801-List message posted by: "kmccune" <kmccune(at)somtel.net (kmccune(at)somtel.net)>
Frank,
I weight 170 and my wife.. well quite a bit less [Wink] We fit fine in the 701, but even at our size I wish the 750 had been released 6 mo earlier.
Kevin
&quot;Real freedom is the sustained act of being an individual.&quot; WW - 2009
&quot;Life is a good deal...it's worth it&quot;
Dorothy McCune
http://forums.matronics.com/viewtopic.php?p=326087#326087
