		stepinwolf
				 Posted: Mon Jan 03, 2011 8:51 am    Post subject: Zenith CH-750 engine choice |
				J.
  You might want to get in touch with another 750 builder by the name of  André Levesque, who was/is considering the same engine choice.  He can be  reached on the Zenith Aero website at the following address
  http://www.zenith.aero/profile/AndreLevesque?xg_source=profiles_memberList
  Good luck with your choices.
  regards
  Robert
  the 701 & 750 Scratch
  [quote]   ---
  |  | - The Matronics Zenith750-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  http://www.matronics.com/Navigator?Zenith750-List |
  _________________ Long wing + vga's, = lo & slo |
		jd(at)lawsonimaging.ca Guest
				 Posted: Tue Jan 04, 2011 2:32 pm    Post subject: Zenith CH-750 engine choice |
				On 01/03/2011 11:48 AM, Robert Pelland wrote:
 Thanks, Robert, hadn't found Andre yet. Seems his major issue with the Rotec is weight,
 which is true (224 lbs, all accessories included, as opposed to the Jab at 180 - I'm on a
 diet ;')). Same neighbourhood as the O200 and Corvair. But the lightweight all aluminum
 Jab may just come at a price. I'm currently flying behind one (so far, so good), and have
 been a member of the Jabiru engines list for well over a year, and I just can't help
 thinking that the 3300 is not really the strong, robust engine I want for my 750. Steel
 cylinders, heads, and crankcases are just plain *tougher*, IMHO. Not that I'm ruling it
 out by any means, but the R2800 is intriguing. I like the integral 3:2 planetary PSRU for
 the 750, allowing it to swing the longer prop that it deserves. I like the 900 -2100rpm
 cruise (vs 2900-3200+). And, of course, it's a *radial* ! Can it get any sexier than that? ;')
 Regards,  J.
 - flying Sonex #325 C-FJNJ, Jab 3300a, Prince P-Tip, Aerocarb
 - restoring the 'Johnston Special'
 - former C-IGGY CH701 owner/builder, starting CH750 build soon
 - http://cleco.ca
 | J. Davis, M.Sc. (comp sci)    |
 | email: jd at lawsonimaging.ca |
 | *NIX consulting, SysAdmin     |
 | http://cleco.ca               |
		stepinwolf
				 Posted: Tue Jan 04, 2011 5:26 pm    Post subject: Zenith CH-750 engine choice |
				J,
  Describing a radial as being " sexy " in an understatement.  In my  opinion, airplanes where invented to hang a radial engine on them.  )   However to be practical, my choice will be with the affordable, tried and  true.
  I was fortunate in being able to purchase a used 80 Hp Rotax for my 701,  that will need to be rebuilt.  As far as my 750, I have the latest version  2 of the Zenith plans, and since it will be registered as a " homebuilt " rather  then an LSA, I will benefit from the weight increase up 1440 lbs gross  weight.
  The engine will be a 0 time Lycoming that I will have built for me by the  local FBO, who also runs the engine rebuilding shop http://www.aero-atelier.com/visitez.htm at  the local airport.  I originally was planning on a 0230 at around 115 HP,  but since it will be used on amphi floats, I plan to get the maximum performance  out of the aircraft, and have decided to go with the 0320 at 150 to 160 HP,  depending on the compression ratio that will be chosen when it is  rebuilt.
  I prefer a regular aircraft engine not only because of the resale value,  but because it will be easy to find parts when needed, not to mention service at  any of the thousands of airfields that we find across both of our  nations.  I'm not knocking the Rotec, or any other exotic engine, but  you will be hard pressed to find any parts, or service for that matter at  any of the landing strips you will be flying to if you don't have a conventional  aircraft engine.  I would also like to add that rebuilt engines such as  those I mentioned above, can be purchased locally for about 40% of the cost of a  new engine. At O time, and with a good warranty, you can't beat that  for a great deal.
  A few of my friends have had what we could call, rather bad  experiences with their auto conversion engines, and one even had to disassemble  the aircraft and have it towed 300 miles back home because he couldn't have it  repaired where it landed.  This is not something I would be comfortable  with
  Just my two cents.
  regards
  Robert
  [quote]   ---
				 Posted: Wed Jan 05, 2011 6:25 am    Post subject: Zenith CH-750 engine choice |
				Thanks for this, Robert.
  	  | Quote: | 	 		   J,
 Ah, the voice of reason. Sexy can be a siren in disguise ;')
  	  | Quote: | 	 		   I was fortunate in being able to purchase a used 80 Hp Rotax for my 701, that will need to
  be rebuilt.
 I put about 300 hours on my 701 with a 912UL before selling it. And missing it somewhat
 ever since!
  	  | Quote: | 	 		   As far as my 750, I have the latest version 2 of the Zenith plans, and since
 Ditto. Although I'm not plans building this time around, been there, done that with my
 Sonex, I will also be building homebuilt, and able to take advantage of the 1440 g.w.
 Looks like I was close last summer when I flew in to Lachute on my way to Faucheurs.
 Beautiful part of the country (and *nice* little aerodrome!).
  	  | Quote: | 	 		   I originally was planning on a 0230 at around 115 HP, but since it will be used
 Interesting. Just out out curiosity, what would the dry weight of the O320 come in at?
  	  | Quote: | 	 		   I prefer a regular aircraft engine not only because of the resale value, but because it
 Wonder if aero-atelier would have an O200/230 (my initial thought for a power plant, for
 most of the reasons you state, before I got sidetracked by the beauty of the Rotec ;') for
 me? Or is it more that I find one and bring it to them?
  	  | Quote: | 	 		   A few of my friends have had what we could call, rather bad experiences with their auto
  Just my two cents.
  regards
  Robert
 Good points, all, thanks for taking time to respond!
 Regards,  J.
 - http://cleco.ca
 | http://cleco.ca               |
 I bought a house, on a one-way dead-end road.  I don't
 know how I got there.
 				--- Steven Wright
		stepinwolf
				 Posted: Wed Jan 05, 2011 5:43 pm    Post subject: Zenith CH-750 engine choice |
				[quote]   ---
