cristalclear13
Joined: 19 Sep 2007 Posts: 363 Location: Southeast Georgia
George Alexander
Posted: Wed Jan 05, 2011 1:32 pm Post subject: Re: Bing 54 jets - cleaning? |
| cristalclear13 wrote: | | I know it is not recommended to clean the idle and main jets, = = = snip= = = |
Cristal:
Do you have a source for that recommendation? I could understand that you would not want to use anything (tool/chemical/process) that would change (enlarge) the orifice(s), but don't know why cleaning otherwise wouldn't be OK.
_________________ George Alexander
FS II R503
E-LSA N709FS
http://www.oh2fly.net |
rickofudall
Posted: Wed Jan 05, 2011 2:01 pm Post subject: Bing 54 jets - cleaning? |
Cristal, Why wouldn't you clean them? As long as you don't use something that changes the jet size, no problemo. I used a small sewing needle to clean out the idle passages and the jets in the Bing 54's on my 582 last year after they gummed up during a protracted rebuild of the airplane. Soak in carb cleaner, work out the softened gum with the needle, repeat until clean. After the carbs were balanced they work as good as they ever have.
Rick Girard
On Wed, Jan 5, 2011 at 3:17 PM, cristalclear13 <cristalclearwaters(at)gmail.com (cristalclearwaters(at)gmail.com)> wrote:
| Quote: | --> Kolb-List message posted by: "cristalclear13" <cristalclearwaters(at)gmail.com (cristalclearwaters(at)gmail.com)>
I know it is not recommended to clean the idle and main jets, but was wondering if anyone has ever done it after they were gummed up and used them again (and lived to tell about it)?
Cristal Waters
Kolb Mark II Twinstar
Rotax 503 DCSI
http://forums.matronics.com/viewtopic.php?p=325709#325709
le, List Admin.
Zulu Delta
Kolb Mk IIIC
582 Gray head
4.00 C gearbox
3 blade WD
Thanks, Homer GBYM
It is not bigotry to be certain we are right; but it is bigotry to be unable to imagine how we might possibly have gone wrong.
- G.K. Chesterton
frank.goodnight(at)att.ne Guest
Posted: Wed Jan 05, 2011 2:38 pm Post subject: Bing 54 jets - cleaning? |
Hi,
If I thought I might damage the jet---( I don't think anything used with reasonable care would hurt them)--
I would use a jewlers ultrasonic cleaner, they are cheap and you can clean jewlery with them later. (multitask).
Frank
From: cristalclear13 <cristalclearwaters(at)gmail.com>
Sent: Wed, January 5, 2011 3:17:16 PM
Subject: Bing 54 jets - cleaning?
Cristal Waters
Rotax 503 DCSI
Posted: Wed Jan 05, 2011 2:39 pm Post subject: Bing 54 jets - cleaning? |
Somebody recently suggested using a copper wire, obtained from stripping some stranded wire (like a piece of 14 gauge automotive wire). Soft enough not to scratch the ports.
Bill Sullivan
Windsor Locks, Ct.
FS 447
--- On Wed, 1/5/11, cristalclear13 <cristalclearwaters(at)gmail.com> wrote:
Cristal Waters
Hi Cristal W/Gang:
I was always taught to use a piece of copper wire to clean carb jets.
Copper is softer than brass. Scrap multistrand copper wiring is a good
source for the right size.
Don't use anything that would scratch and enlarge the jet.
Along with some carb cleaner and a good air hose. Becareful with the air
hose though. It will launch a jet into never never land.
_________________ John Hauck
Titus, Alabama |
cristalclear13
Posted: Wed Jan 05, 2011 2:40 pm Post subject: Re: Bing 54 jets - cleaning? |
| rickofudall wrote: | Cristal, Why wouldn't you clean them? As long as you don't use something that changes the jet size, no problemo. I used a small sewing needle to clean out the idle passages and the jets in the Bing 54's on my 582 last year after they gummed up during a protracted rebuild of the airplane. Soak in carb cleaner, work out the softened gum with the needle, repeat until clean. After the carbs were balanced they work as good as they ever have.
Rick Girard
I was getting my information from
http://www.ultralightnews.ca/bing/bingjetchart.html
under the sections titled Bing Main Jets and Bing Idler Jets.
It says:
... jets on the Bing carb are replaceable. It is recommended that they be replaced if they are found to be plugged. This can happen when the carb is left with fuel in it for long periods of time. The fuel turns to sludge which plugs the jet. In this situation it is NOT recommended that the jet be cleaned and reused.
But on another page it talks about cleaning them with solution and air compressor.
http://www.ultralightnews.com/enginetroublshooting/techtips/techtips2.htm
_________________ Cristal Waters
Private Pilot Aug 2008
Rotax 2 stroke maintenance April 2009 |
zeprep251(at)aol.com Guest
Posted: Wed Jan 05, 2011 3:55 pm Post subject: Bing 54 jets - cleaning? |
Listers,
Compressed air cleans the important parts of your carb.
cristalclear13
209GS
Posted: Wed Jan 05, 2011 5:36 pm Post subject: Re: Bing 54 jets - cleaning? |
Cristal,
To avoid that problem next time, empty your carb bowls if its going to sit idle any length of time. It only takes a couple of minutes to do, and saves alot of time and effort cleaning up later. (talking from experience)
cristalclear13
Posted: Wed Jan 05, 2011 6:51 pm Post subject: Re: Bing 54 jets - cleaning? |
| 209GS wrote: | Cristal,
To avoid that problem next time, empty your carb bowls if its going to sit idle any length of time. It only takes a couple of minutes to do, and saves alot of time and effort cleaning up later. (talking from experience) |
Hi Gerard,
Welcome to the Kolb list. I've been out of commission for almost a year having a baby (she came too early which caused me to not get my plane ready for long storage like I should have).
Did you know you can place your information in your signature line of your profile so that we can always know who 209GS is and what he flies (or plans to fly)?
Frankd
Posted: Thu Jan 06, 2011 8:31 am Post subject: Re: Bing 54 jets - cleaning? |
Hi Cristal/Guys,
I like your thoughts about JET flying... I'd log it if it happens:)
On the topic, I just took apart my Bing 94/40 on my Jabiru 2200 due to fuel overflow during start after sitting for three years. Chris Ambrose had an issue with the float needle and I found I had the same "Pink" needle , which was recommended to be changed to the "Black" tipped one which has a stronger spring to facilitate a better seal. (Info for the Jab guys) I have one on order and my engine # is 902.
I had a friend who worked as a car maintenance manager and he brought along Pipe cleaners and used those to clean out the overflow conduit and fuel intake couduit. Worked great on these bigger bores. He also suggested standard car Carb cleaner in a can. We did not touch the jets but I'd not hesitate to clean those gently and using fine copper wire for the smaller bores is now in my bag of tricks for the future.
Just adding my 2 cents.
frankD
MX3, 0 Hrs
Started engine.
Learning about Carbs.
Holister, Ca
Trying to get to airworthy state.
PS, Congrats on your baby.
GeoB
Posted: Thu Jan 06, 2011 10:10 pm Post subject: Bing 54 jets - cleaning? |
| Quote: | I know it is not recommended to clean the idle and main jets
even with the fine copper strand, be careful.
| Quote: | but was wondering if anyone has ever done it after they were gummed up
Sometimes the motorcycle jets I work on are too blame small for carb cleaner
to do much. Plus idle jets seem to be the ones that plug up first, being the
smallest.
I use a propane torch on them, holding them lightly but firmly with
needle-nose vide-grips. After getting them very hot I can usually blow out a
small amount of ash and have a clean idle jet.
GeoB
_________________ GeoB
"Members of Congress should be compelled to wear uniforms like NASCAR drivers, so we could identify their corporate sponsors" |
captainron1(at)cox.net Guest
Posted: Fri Jan 07, 2011 10:08 am Post subject: Bing 54 jets - cleaning? |
I have been using an Ultrasonic cleaner for years, they are good for anything including the fuel injectors on my Beech. It works good. Instead of water you can fill it up with Kerosine or any potion that you want and they will do their magic. Strongly recommended as something that works. Besides once you remove your Kerosine you can put water and clean anything else that you want that fits there. I did a quick search and found a unit on amazon for about 36 bucks. Well, worth it.
------ http://www.amazon.com/Haier-HU335W-Ultrasonic-Cleaner/dp/B0000BVGNJ ------
I couldn't find the model I have but the above is pretty close in size to mine. It does not take long for the gizmo to get the shmutz out, if you look carefully you will see a little cloud come out when it first comes on vibrating. The injectors on an IO-360 are a bit bigger than the carb ones so they have more crap in them, I get a bigger visual effect than the Carb jets I would guess.
Ron (at) FHU
smallest.
GeoB
I have been cleaning the injectors on my Beech for a few years using a sonic cleaner. I did a quick G-search and here is a cheap one from Amazon ---
kugelair.com
209GS
Posted: Sat Jan 08, 2011 8:28 am Post subject: Re: Bing 54 jets - cleaning? |
Thanks for the info and link
_________________ Gerry Uebbing
Firestar II 503 b-box
(not flying yet) |
GeoB
dalewhelan
Joined: 11 Nov 2008 Posts: 105 Location: USA ARIZONA fountain hills
Posted: Sat Jan 08, 2011 12:06 pm Post subject: Re: Bing 54 jets - cleaning? |
While it is possible to damage jets I have found it easier to use wire to clean jets without damaging them then I have been able to clean my own rear with just toilet paper.
For those that don't want to clean your dirty jet, send them to me, I will pay postage
_________________ Dale Whelan
503 powered Firestar II, Luscombe 8A
Projection, A simple and interesting Psychological concept |
peridans Guest
Posted: Tue Jul 23, 2019 11:31 pm Post subject: Re: Bing 54 jets - cleaning? |
I accidentally dropped a piece of McDonald's Big Mac on the seat, after which a stain remained (I can't remove it with ordinary wet wipes). What products can remove this greasy stain or only dry cleaning will help? Please, advise the best car carpet cleaner that can remove any stains on the carpet in the car and the seat. Are there any? Or the only way out is to go to dry cleaning? I just would not like to spend so much money on a few stains.
