CorvairEngines-Nickisil
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> CorvairEngines-List
John Bolding
PostPosted: Sun Jan 09, 2011 9:29 am    Post subject: CorvairEngines-Nickisil Reply with quote
Nickisil is pretty proven technology, Porsche has used it for 20-30?? yrs in the 911. LOTS of others
Got a buddy that has a 2 cyl VW with Nickies that he has flown almost wide open for over 600 hrs.
Don't think anyone has flown a Vair with them yet but several will.
They save you 18# and that is a LOT of weight, plus they are relatively cheap to replate if you ever wear them out or damage one.
Google LN Engineering
Here's a little homework for you if interested.
[quote] http://en.wikipedia.org/wiki/Nikasil
LO&SLO
JOHN
- The Matronics CorvairEngines-List Email Forum -
http://www.matronics.com/Navigator?CorvairEngines-List
craig(at)craigandjean.com
PostPosted: Sun Jan 09, 2011 10:51 am    Post subject: CorvairEngines-Nickisil Reply with quote
The Rotax 912 and 914 also use nikasil.
-- Craig
From: owner-corvairengines-list-server(at)matronics.com [mailto:owner-corvairengines-list-server(at)matronics.com] On Behalf Of John Bolding
Sent: Sunday, January 09, 2011 9:26 AM
To: corvairengines-list(at)matronics.com
Subject: Re: Re: CorvairEngines-Nickisil
LO&SLO
JOHN
----- Original Message -----
To: corvairengines-list(at)matronics.com (corvairengines-list(at)matronics.com)
Sent: Sunday, January 09, 2011 9:15 AM
Subject: CorvairEngines-List: Re: CorvairEngines-List Digest: 4 Msgs - 01/08/11
Not only are some of the items from MM unavailable, I don't like what I see about their coated aluminum cylinders. Almost all users of aluminum in engine blocks use cast iron inserts. When cast iron is properly honed, with the scratches running around in circles, they hold a slight film of oil, which both seals and lubricates the cylinder-to-ring contact.
In contrast, aluminum can gall very easily in such applications, so the user is dependent upon the durability of the coating to prevent this. I'd want to know a lot about the durability in empirical testing.
With the fifth bearing, WW's stuff is about as bullet-proof as you can get. If I were building the ideal, I'd go with WW specs, except for using primary and secondary electronic ignition. Others have done variants of this and can speak better to these mods.
Tim in central TX
<clip>
On Sun, Jan 9, 2011 at 1:55 AM, CorvairEngines-List Digest Server <corvairengines-list(at)matronics.com (corvairengines-list(at)matronics.com)> wrote:
Time: 11:35:01 AM PST US
From: "Steve Dixon" <dix39(at)charter.net (dix39(at)charter.net)>
Subject: Re: Corvair - where to get one?
I feel I have to respond to this post to clarify, as I understand it,
the positions Wynne and Magnificent Machine occupy with regard to
Corvair flight engines. I attended the Corvair College about a year ago
held at Magnificent Machine. I am a long time follower of William Wynne
who has devoted a very significant part of his life to the development
of a safe conversion of Corvair engines for use in aircraft. IMHO,
anyone planning to convert a Corvair engine for aircraft use should take
advantage of the testing and research he has done. His book, "Corvair
Flight Engines", contains a wealth of information about Corvair engines
and how to convert them. I wholeheartedly agree with all that has been
said about Magnificent Machine, but they, and others, are only building
on the decades of work that has been done by William Wynne.
Steve Dixon
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> CorvairEngines-List All times are GMT - 8 Hours
