				 Posted: Sun Jan 09, 2011 10:25 am    Post subject: Engine Monitor Range/Alarm settings |
				Does anyone have a list of engine monitor settings, like green-yellow-red settings for the engine parameters?  I have an IO-540 in a RV-10.  Just looking fir something to start with.  Thanks
 -Mike Kraus
				 Posted: Sun Jan 09, 2011 12:24 pm    Post subject: Engine Monitor Range/Alarm settings |
				oops sorry! wrong numbers!
 Look at the engine manual  or lycoming's site.. I saw it somewhere just don’t
 recall where.
				Vans has this on their site:
 http://www.vansaircraft.com/pdf/speeds.pdf
		Kelly McMullen
				 Posted: Sun Jan 09, 2011 1:01 pm    Post subject: Engine Monitor Range/Alarm settings |
				Here are some conservative numbers:
 CHT, 380 F yellow, 400 red, 200-380 green
 Oil pressure, 25-50 yellow, 55-75 green,75-90 yellow, above that red
 Oil temp 160-220 green 220-240 yellow 240 red.
 Fuel pressure 20-28 green, below 18 and above 28 red,
  Fuel flow, above 27 or so red.
 That should get you started. Keep in mind that Lycoming operator's handbook red lines are NOT conservative...like CHT redline 475-500 in climb and 425 in cruise...much too hot.
 On Sun, Jan 9, 2011 at 11:18 AM, Michael Kraus <n223rv(at)wolflakeairport.net (n223rv(at)wolflakeairport.net)> wrote:
  	  | Quote: | 	 		   --> RV10-List message posted by: Michael Kraus <n223rv(at)wolflakeairport.net (n223rv(at)wolflakeairport.net)>
  -Mike Kraus
  http://forums.matronics.com
  le, List Admin.
 #avg_ls_inline_popup{position: absolute;z-index: 9999;padding: 0px 0px;margin-left: 0px;margin-top: 0px;overflow: hidden;word-wrap: break-word;color: black;font-size: 10px;text-align: left;line-height: 130%;}  [quote][b]
A&P/IA, EAA Tech Counselor
KCHD |
		mregoan(at)hispeed.ch Guest
				 Posted: Sun Jan 09, 2011 10:36 pm    Post subject: Engine Monitor Range/Alarm settings |
				I just read Sonja Englert’s book last night claiming that for a good engine break-in, the CHT needs to be above 400°F.  No specifics or justification is given, but combined with Kelly’s numbers below that would put you in the red for your first few hours of flight which would not seem such a good idea.
 Just a head’s up.
 Gordon Anderson
 #41015 tailcone priming
 From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Kelly McMullen
  Sent: 09 January 2011 21:58
  Subject: Re: Engine Monitor Range/Alarm settings
  -Mike Kraus
  le, List Admin.
     	  | Quote: | 	 		  |   http://www.matronics.com/Navigator?RV10-List  | 	  0123456789
		dlm34077(at)q.com Guest
				 Posted: Mon Jan 10, 2011 3:25 am    Post subject: Engine Monitor Range/Alarm settings |
				My experience with a new certified engine from  Vans. Purchased in 4th quarter 2004 to buy before the $6k increase. ; first run  1st quarter 2008. Using GRT EIS, the initial 25 hour testing found that the CHTs  on takeoff occasionally would exceed 420 but would soon recede to 380-400 after  increased speed to 120 KIAS. First 5 hours I would see CHTs in low 400s on take  off and with minor leaning the temps would go to low 400s. Much flying was cross  country as my DAR gave me a run of about 90 miles as longest leg. Around 10  hours oil composition reduced  and temps also. Now at 379 hours, CHTs all  below 360 which is top of the green for my monitor setting. Typical LOP is  55-65%, fuel flow in the 9-12 range , CHTs high 200s/low 300s. EGTs highest  below 1420 where top of green is set for EGTs. Oil consumption is a quart for  about every 15 hours. I change oil every 35 hours, filter every other oil change  and consume about one quart between changes. I generally run LOP, low power  settings. This aircraft will climb at 65% at 800-1000 fpm so when asked "how  fast does it go?" My answer is "I don't know I have not been there yet.." When  the fuel flow indicates 24 gph at full throttle takeoff, one starts to reduce  power soon after takeoff. Be advised we reduced and then removed the air dams on  cylinders 1 and 2; but also keep in mind that I live and fly in Phoenix. If I  lived in IL, near my original home, my experience would be  different.
  [quote]   ---
		Kellym
				 Posted: Mon Jan 10, 2011 7:02 am    Post subject: Engine Monitor Range/Alarm settings |
				It is a question of whether you want to set alarms for what you want in
 the long run or if you are worried about having a few brief alarms on
 first few flights while the engine is breaking in.
 Myself, if the engine starts to go above 400, I want to be watching it
 like a hawk and taking action to limit the temperature increase, like
 nosing over for more airspeed, richening mixture, if not full rich, and
 possibly reducing power setting. 425 would be my absolute do not exceed
 red line, but that is why I want yellow and red line alarms below that
 value, so I can take action to prevent exceeding my real limit.
 John Deakin's Pelican's Perch articles on Avweb give some good
 background on temps and metallurgy to consider CHT limits lower than
 Lycoming's official numbers.
 As for a good break-in, temperature is a secondary consequence of what
 is needed for good ring seating. That is high pressure against the rings
 from high power settings. Temperatures limit how high a power you can
 use. Some advocate achieving a higher power setting by going very lean
 of peak, say 80 degrees, and using 80-85% power. The extreme leaness
 limits the CHT and gives a broader pressure peak during combustion,
 where rich of peak the engine runs hotter and each combustion peak is
 very sharp and brief.
 How you do your break-in is going to be based more on warranty
 considerations and instructions from your engine builder than anything
 else. If you choose to do other than those instructions, you are on your
 own if something bad happens.
 On 1/9/2011 11:22 PM, Gordon Anderson wrote:
  Just a head’s up.
  Gordon Anderson
  [mailto:owner-rv10-list-server(at)matronics.com] *On Behalf Of *Kelly
  McMullen
  *Sent:* 09 January 2011 21:58
  *To:* rv10-list(at)matronics.com
  *Subject:* Re: Engine Monitor Range/Alarm settings
  <n223rv(at)wolflakeairport.net <mailto:n223rv(at)wolflakeairport.net>> wrote:
  -Mike Kraus
  le, List Admin.
  *http://www.matronics.com/Navigator?RV10-List*
  *http://forums.matronics.com*
  *http://www.matronics.com/contribution*
KCHD |
				 Posted: Mon Jan 10, 2011 7:26 am    Post subject: Engine Monitor Range/Alarm settings |
				My CHTts are set as 200-360 green, 361-420 yellow  421-red
 EGTs are set as 1000-1420 green, 1420- yellow
				 Posted: Mon Jan 10, 2011 8:04 am    Post subject: Engine Monitor Range/Alarm settings |
				I mentioned looking at the Lycoming specs for the engine, I found the
 "Lycoming key operations" in there it states:
 For maximum service life, maintain the following recommended limits for
 continuous operation.
 Minimum in-flight CHT should be 150Ëš F (65Ëš C), and maximum in most
 direct-drive normally aspirated Lycoming engines is 500Ëš F (260Ëš C). Some of
 our higher-powered more complex
 engines have a maximum limit of 475Ëš F (245Ëš C). Although these are minimum
 and maximum limits, the pilot should operate his or her engine at more
 reasonable temperatures in order to achieve the expected overhaul life of
 the power plant. In our many years of building engines, the engines have
 benefited during continuous operation by keeping CHT below 400Ëš F in order
 to achieve best life and wear of the power plant. In general, it would be
 normal during all-year operations, in climb and cruise to see head
 temperatures in the range of 350Ëš F to 435Ëš F.
 I tend to believe this is a Lycoming "general", when the time comes I'll
 call my engine builder and get their thoughts on the temps as well.
		Jim Berry
				 Posted: Mon Jan 10, 2011 3:08 pm    Post subject: Re: Engine Monitor Range/Alarm settings |
				FWIW Mike Busch's webinar on cylinders states that cht's above 400* reduces the tensile strength of that head by 50%. I am not clear if he means reduced strength while the temp is elevated, or permanently. If the latter, that is scary.
 Jim Berry
 N15JB
