Kelly McMullen
Posted: Mon Jan 10, 2011 7:49 am Post subject: Fwd: Prop Governor revisited |
| Quote: | From an old thread. One other message in the thread indicated that Rev F and up governor governors would work fine. I'm kind of on the fence between ordering the correct MT from source other than Vans, or ordering a PCU5000.
---------- Forwarded message ----------
From: <lessdragprod(at)aol.com (lessdragprod(at)aol.com)>
Date: Sat, Aug 14, 2010 at 3:45 AM
Subject: Re: Prop Governor revisited
I believe the question being asked is "Is only getting 2550 RPM maximum acceptable when a (I)O-540 narrow deck governor is installed on a (I)O-540 wide deck engine".
I wouldn't think so.
Especially when Van's Aircraft could provide the correct governor. I am aware of them knowing about this for at least three years.
Just my opinion.
Jim Ayers
RV-3 sn 10050 650 hours - LOM M332A engine - 3 blade electric CS MT Propeller & Warne fixed pitch propeller
RV-6A sn 21873 150 hours - Lyc. O-360 engine - metal 2 blade CS MT Propeller & 3 blade CS MT Propeller
RV-4/HR2/modified sn 001 28 hiours - IO-540 narrow deck engine - counterweighted 4 blade CS MT Propeller & counterweighted 3 blade CS Propeller in process.
A&P/IA, EAA Tech Counselor
KCHD |
