		robert.eli(at)comcast.net Guest
				 Posted: Tue Jan 11, 2011 5:04 am    Post subject: Predrilling the short strut end 5/16 bolt holes - CH701 |
				Folks,
   I am predrilling the short strut ends (of the two  piece struts) for the 5/16 bolt that attaches it to the wing strut fittings  (reference drawing 7-V-10). The U-tab gap on the front strut end is reasonably  close to the thickness of the strut fitting assembly; however, the rear strut  end has a gap that is larger than what is specified on drawing 7-V-10 (which is  1/8 inch). My gap is closer to 3/16, and is about twice the thickness of the  rear strut fitting (which is 0.09 in). I am hesitant to rely on using the bolt  to draw-down this much of a gap. It seems to me that it would be better to use a  shim to take some of excess gap in the U-tab. Does anyone have a recommendation  on what works best to deal with this issue?
  Robert N. Eli
  CH701
  |  | - The Matronics Zenith701801-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		John Bolding
				 Posted: Tue Jan 11, 2011 5:38 am    Post subject: Predrilling the short strut end 5/16 bolt holes - CH701 |
				You are correct, don't draw it in, shim it to  fit.
  The wider the vacant space the more bending load  you place on the bolt, this is a shear loading application, think I might ask  Zenith if a shim is sufficient.
  John
  [quote]   ---
		dougsnash
				 Posted: Tue Jan 11, 2011 6:10 am    Post subject: Predrilling the short strut end 5/16 bolt holes - CH701 |
				Robert, this might be a silly question but are you sure that you don't have the front fitting for the other side?  Possibly Zenith sent the wrong one if this is a kit plane.  I scratch built mine so they fit really well.
  Also, is it possible to close the gap in the fork in a vise so that there is no bending load applied to the tabs when installed?
  Doug MacDonald
  CH-701 C-GBQX
  NW Ontario, Canada
 --- On Tue, 1/11/11, Robert N. Eli <robert.eli(at)comcast.net> wrote:
 Subject: Predrilling the short strut end 5/16 bolt holes - CH701
 To: Zenith701801-list(at)matronics.com
 Received: Tuesday, January 11, 2011, 7:01 AM
     Folks,
  Robert N. Eli
  CH701
 ist" target=_blank rel=nofollow>http://www.matronics.com/Navigator?Zenith701801-List
				 Posted: Tue Jan 11, 2011 11:57 am    Post subject: Predrilling the short strut end 5/16 bolt holes - CH701 |
				Doug,
  I do have the full set of front and rear strut ends  (thanks to Tommy Walker's generosity), with the individual part number stickers  in place on each part. The front and rear strut ends have the appropriate  different gap widths between the U flange. You are getting at one of the issues,  and that is that the U is fabricated out of one piece of 4130 and none  of my strut ends have the tab portions exactly parallel due to,  apparently, some spring-back during manufacturing. I did close the gap (make  them parallel) using the vice. There is considerable spring-back, so I had to  close the gap quite a bit in the vice so that they would spring-back  to a parallel condition. But, even with this process to help matters, I still  have a significant gap of 2 mm between the rear strut fitting and the strut end  tab. I don't want to depend on the bolt to pull the tabs down to the strut  fitting since this will pull things out of parallel in the other direction, and  not produce a good flat contact surface between the parts. I have tentively  decided to use a steel shim to fill the 2 mm gap, but will check with  Zenith to see if it sounds OK to them.
  Robert
  [quote]   ---
		dougsnash
				 Posted: Tue Jan 11, 2011 12:54 pm    Post subject: Predrilling the short strut end 5/16 bolt holes - CH701 |
				Sounds to me like the fittings were made incorrectly.  Zenith will likely replace them.  2mm is a pretty big gap.  While I'm sure a shim will fix your problem, you paid for a properly built part, Zenith should provide it.  It's been my experience that they are great to deal with so I am sure they will help you out.
  Doug MacDonald
 Subject: Re: Predrilling the short strut end 5/16 bolt holes - CH701
 Received: Tuesday, January 11, 2011, 1:54 PM
   Doug,
  Robert
