Matronics Email Lists BBS Forum Interface to the Matronics Email Lists
rickofudall
Posted: Sun Jan 09, 2011 7:39 pm Post subject: Interesting video |
If you remember when one of the boys from the A/V dept brought the projector to class and set it up to run, you'll love this.
Rick Girard
Zulu Delta
Kolb Mk IIIC
582 Gray head
4.00 C gearbox
3 blade WD
Thanks, Homer GBYM
It is not bigotry to be certain we are right; but it is bigotry to be unable to imagine how we might possibly have gone wrong.
- G.K. Chesterton
ulflyer(at)verizon.net Guest
Posted: Mon Jan 10, 2011 7:51 am Post subject: Interesting video |
Did I miss something here?
At 09:25 PM 1/9/2011, you wrote:
| Quote: | If you remember when one of the boys from the A/V dept brought the
Rick Girard
Zulu Delta
Kolb Mk IIIC
582 Gray head
4.00 C gearbox
3 blade WD
Thanks, Homer GBYM
- G.K. Chesterton
rickofudall
Posted: Mon Jan 10, 2011 8:39 am Post subject: Interesting video |
No, but I did.
http://www.youtube.com/watch?v=ftq8jTQ8ANE
[url=http://www.youtube.com/watch?v=ftq8jTQ8ANE][/url]Rick
On Sun, Jan 9, 2011 at 9:25 PM, Richard Girard <aslsa.rng(at)gmail.com (aslsa.rng(at)gmail.com)> wrote:
| Quote: | If you remember when one of the boys from the A/V dept brought the projector to class and set it up to run, you'll love this.
Rick Girard
Zulu Delta
Kolb Mk IIIC
582 Gray head
4.00 C gearbox
3 blade WD
Thanks, Homer GBYM
- G.K. Chesterton
tp://forums.matronics.com
Zulu Delta
Kolb Mk IIIC
582 Gray head
4.00 C gearbox
3 blade WD
Thanks, Homer GBYM
- G.K. Chesterton
Posted: Mon Jan 10, 2011 8:51 am Post subject: Interesting video |
Rick- That was great! Thanks.
Bill Sullivan
--- On Mon, 1/10/11, Richard Girard <aslsa.rng(at)gmail.com> wrote:
Dennis Thate
capedavis(at)yahoo.com Guest
Posted: Mon Jan 10, 2011 11:39 am Post subject: Interesting video |
Richard , I am amazed at how much difference there is , I built my KXP with streamlined wing struts but didnt realize how munch difference it mad ! Thanks for that link and I think there is more to learn on that same Youtube page
Chris Davis
KXP 503 492 hrs
Glider Pilot
Disabled from crash building Firefly
Sent: Mon, January 10, 2011 11:35:05 AM
Subject: Re: Interesting video
No, but I did.
Rick Girard
Zulu Delta
Kolb Mk IIIC
582 Gray head
4.00 C gearbox
3 blade WD
Thanks, Homer GBYM
- G.K. Chesterton
| Quote: | | get="_blank">http://www.matronics.com/Navigator?Kolb-List tp://forums.matronics.com _blank">http://www.matronics.com/contribution |
Zulu Delta
Kolb Mk IIIC
582 Gray head
4.00 C gearbox
3 blade WD
Thanks, Homer GBYM
- G.K. Chesterton
http://www.matronics.com/Navigator?Kolb-Li nics.com/contribution" rel=nofollow target=_blank>http://www.matronics.================== [/b][b]
Joined: 09 Jan 2006 Posts: 3697 Location: Titus, Alabama (hauck's holler)
Posted: Mon Jan 10, 2011 12:25 pm Post subject: Interesting video |
Chris
Davis
Chris D/Gang:
1987, I was flying my brand new FS without brakes and with standard round
lift struts out of Gantt IAP, all 600 feet of it.
I finally saved up enough money to buy 4130 streamlined tubing for new lift
struts. Brother Jim welded them up for me, I got them prepped, painted, and
installed.
On my first test flight I was amazed at how stable and solid the FS felt.
The round aluminum struts were constantly dancing in flight. On my first
landing I had to go around. I ran out of airstrip. With no brakes to slow
me down, and a hefty increase in glide and reduction in drag, I had to
rethink my landings. Was time for brakes. ;-( By Spring 1988, I had
brakes and longer heat treated 4130 gear legs, 35.5" long. I chose that
length because Lindberg Heat Treating in Orlando, FL, could only go 36". By
being able to get the nose higher during landing and roll out I was able to
use the bottom of the wing to help slow me down, plus my new Hegar Brakes.
_________________ John Hauck
hauck's holler, alabama |
Posted: Mon Jan 10, 2011 12:39 pm Post subject: Interesting video |
John- Very interesting info about your Firestar. I have a set of steel (!) streamlined struts, almost 10 pounds for the pair. I intended to swap them out for round aluminum to cut some weight. Once they are off, I will probably put them up for grabs. Your comment about your 600 foot field got my attention. My spot for a field at my place in Vt. is about 600 to 700 feet long. It's on top of a small hill, with the ground being lower at both ends. The prevailing wind is aligned with the runway. I was wondering about the necessity of brakes, and now I know. I wonder if Richard Pike still has the old FS brakes he mentioned.
Bill Sullivan
Windsor Locks, Ct.
FS 447
Posted: Mon Jan 10, 2011 12:54 pm Post subject: Interesting video |
Bill Sullivan
Windsor Locks, CT.
FS 447
Bill S/Gang:
I think the reduction in drag, absence of vibration, and good solid feel of
the steel streamlined struts will far outweigh the difference in weight,
which probably will not be that much. Definitely not progressing going
round aluminum.
mkIIUI
Richard Pike
Joined: 09 Jan 2006 Posts: 1006 Location: Blountville, Tennessee
Posted: Tue Jan 11, 2011 5:51 am Post subject: Re: Interesting video |
[quote="williamtsullivan(at)att.n"]
<snip>
Bill Sullivan
Windsor Locks, Ct.
FS 447
Sitting in the hangar, give me a call, 423-323-9441 or richard (at) bcchapel.org
Richard Pike
MKIII N420P (420ldPoops)
Rex Rodebush
Joined: 10 Jan 2006 Posts: 67 Location: Galena, Missouri
Posted: Wed Jan 12, 2011 9:50 am Post subject: Re: Interesting video |
The experiment we saw on the video and many others are explained in the book "Shape and Flow, the Fluid Dynamics of Drag" by Ascher H. Shapiro, published by Doubleday Anchor. It's out of print but I got a copy via the internet.
Rex
