		flyadive(at)gmail.com Guest
				 Posted: Wed Jan 12, 2011 9:06 am    Post subject: FUEL TANK SEALANTS |
				Hello Gaggle:
 I have been fighting leaking fuel tans for a while.  The tanks are aluminum and sealed with PRO SEAL or the equivalent.
 Since my engine likes both AvGas and MoGas and MoGas has ethanol I would like a sealant that can stand up to both.
  Stop - I know about the trick of removing the ethanol from MoGas but that is only about 90% effective.
 I would like to run straight MoGas.
 Would anyone out there have any experience in this area?
 Thank you for the assistance.
 Barry
  |  | - The Matronics RotaxEngines-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		occom
				 Posted: Wed Jan 12, 2011 12:06 pm    Post subject: FUEL TANK SEALANTS |
				How about this ACS part  number 09-02566 . I have used it on fibreglass BSA tanks.
  From:  owner-rotaxengines-list-server(at)matronics.com  [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of  FLYaDIVE
 Sent: January-12-11 12:03 PM
 To:  rotaxengines-list(at)matronics.com
 Subject: FUEL TANK  SEALANTS
 Hello Gaggle:
				 Posted: Wed Jan 12, 2011 12:38 pm    Post subject: FUEL TANK SEALANTS |
				Hi Dave:
 I saw that one... (09-02566) Do you have any personal experience with that product?
 Barry
 On Wed, Jan 12, 2011 at 4:03 PM, Dave <occom(at)ns.sympatico.ca (occom(at)ns.sympatico.ca)> wrote:
 [quote]      How about this ACS part  number 09-02566 . I have used it on fibreglass BSA tanks.
  From:  owner-rotaxengines-list-server(at)matronics.com (owner-rotaxengines-list-server(at)matronics.com)  [mailto:owner-rotaxengines-list-server(at)matronics.com (owner-rotaxengines-list-server(at)matronics.com)] On Behalf Of  FLYaDIVE
 To:  rotaxengines-list(at)matronics.com (rotaxengines-list(at)matronics.com)
 Hello Gaggle:
 ist" target="_blank">http://www.matronics.com/Navigator?RotaxEngines-List
 tp://forums.matronics.com
		pchristensen10(at)austin. Guest
				 Posted: Wed Jan 12, 2011 12:45 pm    Post subject: FUEL TANK SEALANTS |
				Dave, I'm curious that you mentioned that removing ethanol from     mogas is only 90% effective.  Have you tried it?  I am experimenting     with removing ethanol from mogas and it works fine so far in my     Kitfox/912.  If there is a bit of ethanol left in my gas it has not     caused any problems.  There is little information out there about     washing gas.
      Pete
      On 1/12/2011 3:03 PM, Dave wrote:     [quote]                     How about this ACS part number                 09-02566 . I have used it on fibreglass BSA tanks.
        Hello Gaggle:
		Roger Lee
				 Posted: Wed Jan 12, 2011 2:04 pm    Post subject: Re: FUEL TANK SEALANTS |
				Kreem Weiss is a great tank coating. The entire 1500+ fleet of Flight Design CT's has it's tanks coated with Kreem and most of us use ethanol fuels. 325 of them here in the states. Never an ethanol issue. Some in Europe and South America use up to 18%-23% ethanol and never have any issues. It is pretty much impervious to anything, that's why so many people that coat tanks use it professionally.
  _________________ Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Home 520-574-1080  TRY HOME FIRST
Cell 520-349-7056 |
		hgmckay
				 Posted: Wed Jan 12, 2011 2:06 pm    Post subject: FUEL TANK SEALANTS |
				Dave,
  What is the root cause of your aluminum tanks leaking? How old are the  tanks? Are they leaking at fabricated joints? How long have you had this  problem? The reason I ask is, I have aluminum wing tanks in my Allegro 2000 and  have not had any problem with leaks since the first flight in 2007. I now have  almost 500 hours on the engine and I use 93 octane (ethanol free) fuel as well  as 87 octane (10% ethanol). Is your problem the fuel or poor fabrication of the  tanks?
  Hugh McKay
   From: Pete Christensen (pchristensen10(at)austin.rr.com)
  Sent: Wednesday, January 12, 2011 3:16 PM
  Subject: Re: FUEL TANK SEALANTS
 Pete
 Hello Gaggle:
 href="http://www.matronics.com/Navigator?RotaxEngines-List">http://www.matronics.com/Navigator?RotaxEngines-List
				 Posted: Wed Jan 12, 2011 2:50 pm    Post subject: FUEL TANK SEALANTS |
				Hi Roger:
 I have tried this sealant.  It worked GREAT on a stationary tank.  But FAILED quickly when used on a flexible aluminum (aviation) tank and on fiberglass tanks.  The stuff dries almost stiff, not really flexible.
 What might you know about:
 http://www.hirschauto.com/products.asp?dept=4
 Barry
  On Wed, Jan 12, 2011 at 5:04 PM, Roger Lee <ssadiver1(at)yahoo.com (ssadiver1(at)yahoo.com)> wrote:
 [quote] --> RotaxEngines-List message posted by: "Roger Lee" <ssadiver1(at)yahoo.com (ssadiver1(at)yahoo.com)>
  Roger Lee
  Tucson, Az.
  Light Sport Repairman - Maintenance Rated
  Rotax Repair Center
  Cell 520-349-7056
  http://forums.matronics.com/viewtopic.php?p=326739#326739
  -List" target="_blank">http://www.matronics.com/Navigator?RotaxEngines-List
  le, List Admin.
				 Posted: Wed Jan 12, 2011 2:51 pm    Post subject: FUEL TANK SEALANTS |
				Pete:
 You are correct.
 Yes, I have tried it for two years.  It does work pretty well, but if you religiously check your gas on a pre-flight you will find water in it.
 Barry
 On Wed, Jan 12, 2011 at 3:16 PM, Pete Christensen <pchristensen10(at)austin.rr.com (pchristensen10(at)austin.rr.com)> wrote:
 [quote]                     Dave, I'm curious that you mentioned that removing ethanol from     mogas is only 90% effective.  Have you tried it?  I am experimenting     with removing ethanol from mogas and it works fine so far in my     Kitfox/912.  If there is a bit of ethanol left in my gas it has not     caused any problems.  There is little information out there about     washing gas.
      Pete
		occom
				 Posted: Wed Jan 12, 2011 2:53 pm    Post subject: FUEL TANK SEALANTS |
				Only on motorcycle tanks. The fibreglass used on BSA tanks of  the sixties doesn't stand up well at all with the crap we call gas these days.  This stuff seems pretty much able to stand up to it, which is what they claim  for it. It's foul to work with but once hardened seems to stand up well.
 Sent: January-12-11 3:18 PM
 Hi Dave:
  Barry
 Hello Gaggle:
				 Posted: Wed Jan 12, 2011 2:56 pm    Post subject: FUEL TANK SEALANTS |
				Hugh:
 It is I, Barry that posted the question.
 The tanks are quite a few years old... About 30 years old.  And they are sealed with PRC, as I mentioned.  I resealed them with PRC put coatings on top of the PRC.  But it still leaks.  WAY too much work and expense to disassemble the tanks and start from the beginning.
 Barry
 On Wed, Jan 12, 2011 at 5:01 PM, Hugh McKay <hgmckay(at)bellsouth.net (hgmckay(at)bellsouth.net)> wrote:
 [quote]      Dave,
  Hugh McKay
				 Posted: Wed Jan 12, 2011 3:00 pm    Post subject: FUEL TANK SEALANTS |
				Barry,
      You got that right.  I do check.  I was thinking of "aging" my     washed gas in a clean empty glass carboy for a week or so then     siphoning the gas off to use.
      Pete
      On 1/12/2011 4:49 PM, FLYaDIVE wrote:     [quote]Pete:
        You are correct.
        Barry
             	  | Quote: | 	 		                Dave, I'm curious               that you mentioned that removing ethanol from mogas is               only 90% effective.  Have you tried it?  I am               experimenting with removing ethanol from mogas and it               works fine so far in my Kitfox/912.  If there is a bit of               ethanol left in my gas it has not caused any problems.                There is little information out there about washing gas.
                  Pete
  | 	       [b]
		occom
				 Posted: Wed Jan 12, 2011 3:01 pm    Post subject: FUEL TANK SEALANTS |
				HI, I think you might be confusing me with FlyDive. I  have no aluminum tanks. I am worried a little about my fibreglass Kitfox tanks  but so far no problems. I have used this product for vintage BSA fibreglass and  it appears to hold up, but I don't think we have alcohol in our gas here in the  Maritimes. I sold off all the old bikes, but all my experience with this has  been ok.
    From:  owner-rotaxengines-list-server(at)matronics.com  [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of Hugh  McKay
 Sent: January-12-11 5:02 PM
    Dave,
  Hugh McKay
		kitfox555(at)sbcglobal.ne Guest
				 Posted: Wed Jan 12, 2011 6:38 pm    Post subject: FUEL TANK SEALANTS |
				I have used KBS  coatings gas tank sealer work for me great go to the web site and check it out
  Jerry Evans
  KitfoxII
  Magalia Calif.
  N582'er'
  kitfox 555
 --- On Wed, 1/12/11, FLYaDIVE <flyadive(at)gmail.com> wrote:
 Date: Wednesday, January 12, 2011, 9:02 AM
  Hello Gaggle:
  Barry
 ist" rel=nofollow target=_blank>http://www.matronics.com/Navigator?RotaxEngines-List
 et=_blank>http://forums.matronics.com
  | 	   [quote][b]
		ruruny(at)aol.com Guest
				 Posted: Fri Jan 14, 2011 8:38 am    Post subject: FUEL TANK SEALANTS |
				Barry,
      I have aluminum fuel tanks in my Zenith 701 (4) 11.5 gallon tanks. They were welded at the factory and I haven't had a
      problem with leaks..... yet.
      Since you have been having this problem for awhile with leaking tanks, maybe a more permanent fix should be made.
      I'm sure it would be alot of work to get the tanks out, and they are full of old sealant that would make this impossible.
      My friend has been fixing tabs and threads on his harley engine for awhile
      now with great sucess. Watch this video and please post any comments.
      http://www.aluminumrepair.com/video_new.asp
      Brian
      http://www.701builder.com
    	  | Quote: | 	 		  Hello Gaggle:
 Barry
				 Posted: Fri Jan 14, 2011 10:53 am    Post subject: FUEL TANK SEALANTS |
				Brian:
 I would love to do that....
 Problem is the TANK is the WING.  It is know as a Wet Wing.
 And the material is only 0.020" thick.  And there is no access to the inside of the wing/tank for ANY type of welding.
 Some problems are really problems
 The main problem is that the sealing compound's chemistry has changed due to the EPA.  It is know to be cancer causing in California Rats.  WHO CARES!
  I'm not a California Rat and I don't plan on eating it!
 I just want a gas tank that does not leak.
 Barry
  On Fri, Jan 14, 2011 at 11:18 AM,  <ruruny(at)aol.com (ruruny(at)aol.com)> wrote:
   Barry,
      Brian
 Barry
  | 	  [b]
				 Posted: Fri Jan 14, 2011 4:13 pm    Post subject: FUEL TANK SEALANTS |
				When I did my kitfox 2 wing, I took off the wing and just rolled the wing  around up down side to side  to get all the KBS coating evenly inside the tank . I have a 13.5 gallon wing  tank.  I did the whole process they sell ya work for me very strong stuff
  Jerry Evans
  KitfoxII
  Magalia Calif.
  N582'er'
  kitfox 555
 --- On Fri, 1/14/11, FLYaDIVE <flyadive(at)gmail.com> wrote:
 Subject: Re: Re: FUEL TANK SEALANTS
 Date: Friday, January 14, 2011, 10:41 AM
  Brian:
  Barry
  Barry,
  Brian
 Barry
  | 	   [quote][b]
