bruce1hwjohnson(at)yahoo. Guest
Posted: Wed Jan 12, 2011 7:52 pm Post subject: Leaking tanks |
Has anybody else had problems with the quick build tanks leaking. Mine seem to be leaking around the outlet port. The sealant they used is turning gummy and it is more of a seep than a leak.I cant believe they used rivets on that particular piece as there is no way to snug them a little.Any ideas on how to remedy this?
flysrv10(at)gmail.com Guest
Posted: Thu Jan 13, 2011 4:58 am Post subject: Leaking tanks |
Bruce, i did. After making major repairs without success, gave up and got a new tank. Van supplied the tank for free since it was QB tank.
Major reapir: removing the tank, cutting a hole on the back side of the tank and reaching inside. Vans supplied the repair kit.
If you need more detail, email me offline.
Do not archive.
Repairs from the outside do not work.
On Jan 12, 2011, at 8:48 PM, Bruce Johnson <bruce1hwjohnson(at)yahoo.com (bruce1hwjohnson(at)yahoo.com)> wrote:
[quote]Has anybody else had problems with the quick build tanks leaking. Mine seem to be leaking around the outlet port. The sealant they used is turning gummy and it is more of a seep than a leak.I cant believe they used rivets on that particular piece as there is no way to snug them a little.Any ideas on how to remedy this?
whadath(at)rogers.com Guest
Posted: Thu Jan 13, 2011 5:43 am Post subject: Leaking tanks |
Bruce
I had a leak on the right quick build tank and was finally able to determine it was seepage around the round head rivets on the flange which hold the outlet fitting. I used scotchbrite and alumiprep to clean and roughen the area. I then rinsed well and dried. I covered the area in proseal. It has held leak free so far. I was able to do this with the tank and wing installed.
Wayne
RV10 85 plus hrs
F1 Rocket 475 plus hrs
coop85(at)verizon.net Guest
Posted: Thu Jan 13, 2011 5:55 am Post subject: Leaking tanks |
I have 3 rivets that were seeping fuel on the QB tanks. Unfortunately it wasn’t apparent until I had the airplane painted (aaggghhh!) Previous posts here mentioned using the green Loctite which penetrates threads that are already assembled. It took a lot of applications but appears to be working. Not as good a fix as the major repair kit or sending the tanks back to Vans, but cheap and a lot less work if you want to give it a try.
Marcus
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bruce Johnson
Sent: Wednesday, January 12, 2011 10:48 PM
Subject: Leaking tanks
01234
bhughes(at)qnsi.net Guest
Posted: Thu Jan 13, 2011 6:36 am Post subject: Leaking tanks |
The late Mark Ritter had the same problem. He tried coating the outside with proseal and several other fixes. He finally was successful by pulling a small vacuum on the tank and sucking proseal into the leak. I don’t remember if it was deluted. I have a very small leak around the drain flange and have not been successful with the vacuum method.
Bobby Hughes
N416AS
Sent: Wednesday, January 12, 2011 9:48 PM
| Quote: | | http://www.matronics.com/Navigator?RV10-List | 0123456789
Posted: Thu Jan 13, 2011 9:08 am Post subject: Leaking tanks |
Thanks for the suggestions guys, I will give them a try. My concern is the gummyness of the proseal around the leaks, its like really tacky, like it was not mixed properly. I will attemp to remove and clean today and see where that gets me. It sucks that it is both tanks at exactly the same spot.
Sent: Thu, January 13, 2011 7:30:25 AM
Subject: RE: Leaking tanks
Bobby Hughes
N416AS
| Quote: | | http://www.matronics.com/Navigator?RV10-Listhttp://forums.matronics.com | 012
Posted: Thu Jan 13, 2011 9:49 am Post subject: Leaking tanks |
I've had leaking rivets in both wing walk areas, 4 in each side. It's
leaving a nasty brown stain that's been steadily growing on the one I
haven't repaired yet. Gets on your clothes if you sit on the wing,
too.
I tried loctite without any luck. I finally drilled out the leaking
rivets and installed some closed-end blind rivets. I put a lot of
proseal into the hole and all over the rivet before I popped it in.
The new rivets aren't quite as flush as a standard rivet but I can
live with that. It's been several months and so far the leaks are
fixed. Still needs to be repainted though.
Dave Saylor
AirCrafters
140 Aviation Way
Watsonville, CA 95076
831-722-9141 Shop
831-750-0284 Cell
On Thu, Jan 13, 2011 at 9:05 AM, Bruce Johnson
<bruce1hwjohnson(at)yahoo.com> wrote:
| Quote: | Thanks for the suggestions guys, I will give them a try. My concern is the
Bobby Hughes
N416AS
to remedy this?
http://www.matronics.com/cont================
Posted: Thu Jan 13, 2011 10:23 am Post subject: Leaking tanks |
David,
Did you use 3/32" or 1/8" closed-end rivets? I have been unable to locate any less than 1/8". If you have a source for 3/32 I would appreciate the information.
Bobby Hughes
N416AS
Posted: Thu Jan 13, 2011 10:27 am Post subject: Leaking tanks |
How did you drill out the rivets without anything falling into the tanks? I
would think a vacuum would pick up the small pieces but usually I punch out
the drilled rivet and need access from the inside.
Thanks!
dlm34077(at)q.com Guest
Posted: Thu Jan 13, 2011 11:38 am Post subject: Leaking tanks |
Try access by removing the fuel float sensor.
Posted: Thu Jan 13, 2011 11:49 am Post subject: Leaking tanks |
I used 1/8" rivets from McMaster: 97524A050
Dave Saylor
AirCrafters
140 Aviation Way
831-722-9141 Shop
831-750-0284 Cell
On Thu, Jan 13, 2011 at 10:20 AM, Bobby J. Hughes <bhughes(at)qnsi.net> wrote:
David,
Bobby Hughes
N416AS
Posted: Thu Jan 13, 2011 11:51 am Post subject: Leaking tanks |
Grease on the drill bit helps alot to capture chips. Other than that,
you just have to be pretty vigilant about getting all the pieces out.
We have a boroscope that fits into the screen outlet. A small piece
of sticky tape on the end of the scope grabs the rivet. Tap on the
bottom of the tank and they sort of migrate towards the screen by
gravity. By finding one tail at a time you can keep track. I only
changed a few, a whole bunch would be too tedious this way.
Dave Saylor
AirCrafters
140 Aviation Way
831-722-9141 Shop
831-750-0284 Cell
Thanks!
rv10rob(at)gmail.com Guest
Posted: Thu Jan 13, 2011 12:25 pm Post subject: Leaking tanks |
One of my QB tanks leaked in exactly the same place (seemed to be leaking between the riveted fitting and the rib). There's no visible proseal in that area, though the proseal on the areas of the tank I can see looks fine (not gummy as you describe). I put the finger strainer in and put new seal around it. Now no air leak in testing, but I haven't filled with fuel yet.
-Rob
On Wed, Jan 12, 2011 at 7:48 PM, Bruce Johnson <bruce1hwjohnson(at)yahoo.com (bruce1hwjohnson(at)yahoo.com)> wrote:
| Quote: | Has anybody else had problems with the quick build tanks leaking. Mine seem to be leaking around the outlet port. The sealant they used is turning gummy and it is more of a seep than a leak.I cant believe they used rivets on that particular piece as there is no way to snug them a little.Any ideas on how to remedy this?
Rob Kochman
RV-10 "Finishing" Kit
Woodinville, WA (near Seattle)
http://kochman.net/N819K
Posted: Thu Jan 13, 2011 8:30 pm Post subject: Leaking tanks |
OK I cleaned all the gummy sealant out of the way and did an air test and found it was leaking between the rivets. I thought maybe it was the fitting but after changing them out my conclusion is between the rivets. I put the fittings back in place and put a vacuum on the tank and tried some green loc tite. I am letting it dry over night and then will air test again tomorrow. I might even try some epoxy around the edges of the fitting before air tests. By the way the tanks can take quite a bit of pressure, my plan was around 3 lbs but the valve got kicked and it went up to 20lbs, really made the leaks standout though. The tank came out with no visible problems. After I get the left one one stopped on to the right. Seems there was a problem on the day my tanks were assembled in the Philippines.
Sent: Thu, January 13, 2011 1:21:22 PM
Subject: Re: Leaking tanks
-Rob
| Quote: | | get="_blank">http://www.matronics.com/Navigator?RV10-List ttp://forums.matronics.com _blank">http://www.matronics.com/contribution |
Rob Kochman
| Quote: | http://www.matronics.com/Navigator?RV10-Lnics.com/contribution" rel=nofollow target=_blank>http://www.matronics.==================
n801bh(at)netzero.com Guest
Posted: Fri Jan 14, 2011 1:47 am Post subject: Leaking tanks |
Hard to believe 20 lbs didn't distort/deform/ destroy the tank... You must be one lucky guy.
IMHO.
Ben Haas
N801BH
www.haaspowerair.com
Posted: Fri Jan 14, 2011 6:41 am Post subject: Leaking tanks |
Thats what they tell me.
From: "n801bh(at)netzero.com" <n801bh(at)netzero.com>
Sent: Fri, January 14, 2011 2:39:50 AM
Subject: Re: RV10-List: Leaking tanks
Hard to believe 20 lbs didn't distort/deform/ destroy the tank.... You must be one lucky guy.
IMHO.
Ben Haas
N801BH
