sean(at)stephensville.com Guest
Posted: Wed Jan 12, 2011 5:40 pm Post subject: Finish Kit Wheel Replacement |
Getting ready to order the Finish Kit prior to the price increase. I am
substituting a few items for aftermarket versions, but am having some
trouble finding replacement part numbers for the wheels and tires. I
believe the following items are from the Finish Kit with regards to
wheels and tires that can be replaced?
2.00 U 15X6.0-6 MAIN TIRE 6 PLY RV-10
2.00 U 15X6.0-6IT INNER TUBE MAIN RV-10
1.00 U 5:00X5-6 6 PLY TIRE MAIN GEAR
1.00 U 5:00X5-6IT TUBE FOR 5:005-6
1.00 U CLEVELAND 199-104A 6" RV-10 WHEELS SETS
1.00 U NW501.25 NOSE WHEEL W/BEARINGS
1.00 U-1009 AXLE
I believe the nose wheel NW501.25is replaced by Matco WHLNW511.25 and
the U-1009 is replaced by the Matco Axle?
Can the tubes be kept and just replace the tires and wheels? Is it just
the nose wheel or the mains too? Is the CLEVELAND wheel sets part above
kept even with the replacements?
-Sean #40303
rleffler
Posted: Wed Jan 12, 2011 7:21 pm Post subject: Finish Kit Wheel Replacement |
I just replaced the nose wheel and axel. Be sure to get the spacers for the
axel too. I overlooked them initially.
The Cleveland wheel set also includes your brakes, so you'll need to take
that into consideration if you are planning on replacing those with Matco
wheels too.
I am having a problem with my nose wheel tube. It's only maintain air for
about two days. I don't know if it's defective or if I may have pinched or
punctured it myself. I guess I need to order a new tube. What do folks
recommend?
bob
_________________ Bob Leffler
N410BL - Phase I
Posted: Wed Jan 12, 2011 8:11 pm Post subject: Finish Kit Wheel Replacement |
Thanks guys. I'll probably just start out with replacing the nose wheel
and axle with a Matco WHLNW511.25 and Matco Axle and maybe getting the
leakguard tubes. Seems vansaircrafttires doesn't have a leakguard tube
for the 500-5 nose tire?
-Sean #40303
On 1/12/11 9:20 PM, Pascal wrote:
http://www.vansaircrafttires.com/categories/RV%252d10/
This site has the leakproof tubes and the tires. Vans gets the tires
from this source so you can get the Airtrac but it also gives the
option to take retread or new better tires as well.
Get the Matco wheels and axle, should be able to use the cleveland
set. Ask Matco when you call them.
Besides the tires get the windscreen and wingtips as well.
http://www.vansaircrafttires.com/categories/RV%252d10/Airframe-Parts/
Pascal
Posted: Wed Jan 12, 2011 8:54 pm Post subject: Finish Kit Wheel Replacement |
Replace the windscreen and wingtips, both the same price as Vans, but better
quality and less work to make them fit, as they are 1/8 off all around from
being a perfect fit as received.
Here are both tube links
http://www.vansaircrafttires.com/products/15%7B47%7D600%252d6-Aero-Classic-Leakguard-Tube.html
http://www.vansaircrafttires.com/products/Aero-Classic-500%252d5-Leakguard-Tube.html
Retreads are better and less expensive than the stock tires. core is
Goodyear FC III usually and weight is not much different than the stocks. I
will replace mie with the retreads when the time comes.. for more info check
out Tim's review and Aviation consumer news (articles tab of Desser home
page)
fritzsch(at)eskimo.com Guest
Posted: Wed Jan 12, 2011 10:25 pm Post subject: Finish Kit Wheel Replacement |
I am a little confused. I purchased a quick-build fuselage and it came
with the windscreen. The wingtips came with the self-build wing kit.
But I get the impression that these come with the finish kit from the
text below. Am I missing something? I guess it is too late for me to
consider these products from vanaircrafttires.
In a more confused state than usual.
Dave
Dave Fritzsche
40813
Puyallup, WA
Wings
better quality and less work to make them fit, as they are 1/8 off all
around from being a perfect fit as received.
stocks. I will replace mie with the retreads when the time comes.. for
more info check out Tim's review and Aviation consumer news (articles
tab of Desser home page)
glastar(at)gmx.net Guest
Posted: Wed Jan 12, 2011 11:40 pm Post subject: Finish Kit Wheel Replacement |
Sean,
for the nosewheel:
remove from Finishing Kit:
1x U NW501.25 NOSE WHEEL W/BEARINGS
1x U-1009 AXLE NOSE WHEEL
order from Matco:
http://www.matcomfg.com/AXLEASSEMBLYA24125INCH-idv-3657-1.html
http://www.matcomfg.com/SPACERAXLE24KIT-idv-3681-44.html
http://www.matcomfg.com/NOSEWHEEL5125-idv-2839-6.html
that is:
1x WHLAXLE24 56.24$
1x WHLA24SPKIT
1x WHLNW511.25
That is what I did, not yet mounted but should be the correct items,
maybe Michael did as I ordered also a set for him.
Werner
#41122 empenage (reserved HB-YPK)
#5794 flying (HB-YKP)
On 13.01.2011 02:28, Sean Stephens wrote:
1.00 U-1009 AXLE
-Sean #40303
rleffler
dlm34077(at)q.com Guest
Posted: Thu Jan 13, 2011 6:04 am Post subject: Finish Kit Wheel Replacement |
Try Desser Tire for tire and tube replacements. I have used them for 10+
years. They are a major player. They are also selling after market lens, etc
for RV10. Cleveland is the place for main wheels and matco is the supplier
for nose wheel (the correct one). Cleveland has a kit (199104) for the
wheels. Buy it from one of their dealers.
Posted: Thu Jan 13, 2011 6:36 am Post subject: Finish Kit Wheel Replacement |
cleveland kit 199104 for main wheels and brakes and revised matco for the
nose with the matco axle and spacers.
Posted: Thu Jan 13, 2011 6:55 am Post subject: Finish Kit Wheel Replacement |
Been so long I forgot what came with what..
I guess for others that haven't gotten the fusellage than the windscreen
applies.
Pascal
Posted: Thu Jan 13, 2011 8:25 am Post subject: Finish Kit Wheel Replacement |
Thanks Werner, that is perfect.
-Sean #40303
On 1/13/11 1:33 AM, Werner Schneider wrote:
Sean,
for the nosewheel:
order from Matco:
that is:
1x WHLAXLE24 56.24$
1x WHLA24SPKIT
1x WHLNW511.25
Werner
> 1.00 U-1009 AXLE
> Thanks,
> -Sean #40303
