model airplane servo
Goto page Previous  1, 2
Flydad57(at)neo.rr.com
PostPosted: Sat Jan 15, 2011 9:44 pm    Post subject: model airplane servo Reply with quote
Thanks, Bob. That's some of the input that I am looking for. I would also like to hear about some successful installations and how they are controlled.
Bob Taylor
TigerCub N657RT
From: Robert L. Nuckolls, III (nuckolls.bob(at)aeroelectric.com)
Sent: Sunday, January 16, 2011 12:11 AM
Subject: Re: model airplane servo
On Sat, Jan 15, 2011 at 8:55 PM, Robert Taylor <Flydad57(at)neo.rr.com (Flydad57(at)neo.rr.com)> wrote:
--> AeroElectric-List message posted by: "Robert Taylor" <Flydad57(at)neo.rr.com (Flydad57(at)neo.rr.com)>
I am interested in the possibilities of using an R/C servo for the pitch trim on my TigerCub. Any and ALL details very welcomed!
I know that there are many success stories that
cite the use of R/C servos for moving things on
airplanes. Just be aware that there ARE failure
modes in these little guys that can cause a fast
and total "hard over" motion to the mechanical
limits of the system.
I would not be able to get these products blessed
for use on TC aircraft without some very convincing
analysis and safeguards against such behaviors.
Having your trim system drive to a limit in
a few hundred milliseconds can really put some
excitement into an otherwise boring day.
  (o o)
===========o00o=(_)=o00o=========
< Go ahead, make my day . . . >
< show me where I'm wrong. >
dalamphere(at)comcast.net
PostPosted: Sun Jan 16, 2011 6:18 am    Post subject: model airplane servo Reply with quote
What about using what I remember as retractable landing gear servos? They were slow and powerful and perhaps could be controlled by a 3-pos toggle switch. Please understand, I got out of RC 14yrs ago, so the current technology may be quite different. I think these servos were not proportional, just on/off, supply power polarity reversing.
Just momentarily move the toggle several times until you have the desired trim effect.
A caveat: I don't have one, nor any plans to use one so I have no stock in this, just contributing to the discussion.
Dave
jcorner(at)shaw.ca
PostPosted: Sun Jan 16, 2011 10:53 am    Post subject: model airplane servo Reply with quote
I agree with Bob's comments on this. I get around this problem by early testing to make sure that the "hard over failure" is easily controlled by manual override.
Since we are controlling a almost balanced airplane it does not take much servo deflection to correct minor trim or to control heading and altitude.
With this approach the "failure event" is similar but no more dramatic than hitting that invisible air pocket.
Pitch trim for landing for example is a separate system.
I have encountered that sustained "hard over" electrical failure of a servo but have found that when the power was switched off the servo will re-center itself
reducing the in-flight control loads, something that does not happen with other trim methods.
Jim
Bob Taylor
TigerCub N657RT
  (o o)
PostPosted: Mon Jan 17, 2011 6:44 am    Post subject: model airplane servo Reply with quote
Good for you.
Nothing can replace the value of doing failure modes
effects analysis and/or demonstrations on a motor driven
flight control surface. See:
http://www.aeroelectric.com/articles/Trim_System_Failures.pdf
(o o)
PostPosted: Mon Jan 17, 2011 7:49 am    Post subject: model airplane servo Reply with quote
I'd add that, in my application, I have already done the hard over failure
analysis. My TigerCub is safely controllable with the trim tab at either
limit.
Bob Taylor
TigerCub N657RT
Sent: Monday, January 17, 2011 9:41 AM
To: <aeroelectric-list(at)matronics.com>
>manual override.
Good for you.
(o o)
Eric M. Jones
PostPosted: Mon Jan 17, 2011 7:53 am    Post subject: Re: model airplane servo Reply with quote
It is amazing how many neat devices the "Nonman-carrying" quadrant of the flight universe comes up with.
For those looking for more powerful servos and other neat devices, Google:
Robot Zone or Servo City.
Here's a great example: "the Magic Box" http://www.circuitcellar.com/psoc2002/winners/297.pdf It's hard not to want one of these. Complete info is back up a \level.
I sell two distinctly different servo controllers: the EGPNMSC that drives Futaba and other servos, and the TSCMR, that turns the MAC/RAC "sort-of-servo" into a real servo. (Some glitch on my website is being worked on... so you might not be able to see them now).
The Ray Allen trim box is really a nice piece of hardware. For those who want to improve it a tiny bit, read the attached.
TSCMR Installation Manual.pdf
 Filename:  TSCMR Installation Manual.pdf
 Filesize:  100.95 KB
 Downloaded:  485 Time(s)
EGPNMSC.pdf
 Filename:  EGPNMSC.pdf
 Filesize:  81.84 KB
 Downloaded:  656 Time(s)
RAC Trim and Trim Indicator Schematics.pdf
 Filename:  RAC Trim and Trim Indicator Schematics.pdf
 Filesize:  16.84 KB
 Downloaded:  623 Time(s)
Eric M. Jones
www.PerihelionDesign.com
113 Brentwood Drive
Southbridge, MA 01550
(508) 764-2072
emjones(at)charter.net
PostPosted: Wed Apr 06, 2011 6:17 am    Post subject: Re: model airplane servo Reply with quote
There is an article by Paul Dye on page 63 of the May 2011 issue of Kitplanes Magazine about using a Firgelli PQ12 linear actuator for aileron trim on an RV-3. The data sheet for this actuator is located here:
http://www.firgelli.com/pdf/PQ12_datasheet.pdf
It can be purchased here:
http://store.firgelli.com/pq12-linear-actuato12.html
It seems that it is available with either limit switches or a feedback pot but not both. Although the limit switch model does have an output that will light an LED when the limits are reached. Weight of the actuator is 15 grams.
Joe
Joe Gores
tim2542(at)sbcglobal.net
PostPosted: Wed Apr 06, 2011 7:26 am    Post subject: model airplane servo Reply with quote
Joe
Joe Gores
Hi Joe; I'm using the Figelli L12-30-210-12-S actuator for the roll trim on my Cozy. Have not installed it yet, but it looks like it will do the job just fine although it looks a bit bigger than the one Paul used. It's small enough to mount in the wing root on my plane.http://www.firgelli.com/pdf/L12_datasheet.pdf
Tim Andres
sprocket(at)vx-aviation.c
PostPosted: Wed Apr 06, 2011 8:15 am    Post subject: model airplane servo Reply with quote
I have a visit scheduled for tomorrow at the Firgelli facility. I have
developed a rudder trim system using one of their servos. I'm going to take
some pics and interview the principal of the company, with the aim of
productizing their devices for our market. I've learned a few things along
the way that may be useful for them.
Vern Little
Vx Aviation
Page 2 of 2
