wdaniell(at)etb.net.co Guest
Posted: Mon Jan 17, 2011 5:23 am Post subject: Main wing bushings |
For the assembled wisdom
I have a little slop in the main spar pins when I put them into each bushing separately – “a little slop” means when I wiggle the spar pins the ends move about 1/32.
There is no slop when the whole thing is assembled and the pins are a light push fit.
Is this normal?
Will
Posted: Mon Jan 17, 2011 8:37 am Post subject: Main wing bushings |
Sounds OK to me William
Graham
Sent: Monday, 17 January, 2011 13:19:05
Subject: Europa-List: Main wing bushings
I have a little slop in the main spar pins when I put them into each bushing separately – “a little slop� means when I wiggle the spar pins the ends move about 1/32.
Is this normal?
Will
[quote]http://www======================
JonSmith
Posted: Mon Jan 17, 2011 10:51 am Post subject: Re: Main wing bushings |
Mine is exactly the same. In fact, I remember before doing the weight increase mod I put one of the brand new bushes on the brand new spar pins and was surprised by how much it wobbled about. But when the spars are rigged together (4 bushes in line) there's no play whatsoever when the pin(s) are through them all. I think it is normal.
_________________ G-TERN
Classic Mono |
Posted: Mon Jan 17, 2011 11:13 am Post subject: Main wing bushings |
First, the (black bolt)pins are undersize, (pip pins are spot on and the bushes pretty good)
The tightness is cause by miss alignment of the bushes, both linear and angular. Poor jigging in the factory using the black bolts.
Avoid using a reamer to line them up, if they are bad warm up the redux and remove the miss aligned ones then rebond using better size pins for jigging.
Just do this with the two wings, forget the bushes in the seat back, they really are better with a loose fit because they increase loads on the wings with G forces. THe glider wing is different isn't it, (not seen one recently)
Graham
Sent: Monday, 17 January, 2011 18:51:28
Subject: Re: Main wing bushings
--> Europa-List message posted by: "JonSmith" <jonsmitheuropa(at)tiscali.co.uk (jonsmitheuropa(at)tiscali.co.uk)>
G-TERN
Classic Mono
http://forums.matronics.com/viewtopic.php?p=327312#327312
Posted: Mon Jan 17, 2011 11:25 am Post subject: Main wing bushings |
Phew
J
I had visions of yet another rework
Will
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of GRAHAM SINGLETON
Sent: 17 January, 2011 14:11
Subject: Re: Re: Main wing bushings
Graham
G-TERN
Classic Mono
_ent also available via the Web -Matt Dralle, List Admin.=======
| Quote: | | http://www.matronics.com/Navigator?Europa-List | 01234567
Posted: Mon Jan 17, 2011 11:36 am Post subject: Main wing bushings |
MY perception is that the bushings are quite soft which seems strange to me
Will
Graham
G-TERN
Classic Mono
peterz(at)zutrasoft.com Guest
Posted: Mon Jan 17, 2011 11:51 am Post subject: Main wing bushings |
At least then they will not "fret"
Cheers,
Pete
A239
On Mon, Jan 17, 2011 at 2:33 PM, William Daniell <wdaniell(at)etb.net.co (wdaniell(at)etb.net.co)> wrote:
Will
Posted: Mon Jan 17, 2011 2:01 pm Post subject: Main wing bushings |
Good point!
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of Peter Zutrauen
Sent: 17 January, 2011 14:48
Cheers,
Pete
A239
Will
Posted: Mon Jan 17, 2011 2:47 pm Post subject: Main wing bushings |
They are, they're aluminium alloy but hard anodized. That's why it's better not to ream them
Graham
Sent: Monday, 17 January, 2011 19:33:34
Subject: RE: Europa-List: Re: Main wing bushings
Will
Graham
G-TERN
Classic Mono
01234567
8
budyerly(at)msn.com Guest
Posted: Mon Jan 17, 2011 6:43 pm Post subject: Main wing bushings |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Will, and others,
The play is because the black pins are undersized about .007 I think. The main pip pin is about .499 so only a tiny amount of play is available.
Normally, the oversized bushes allow what appears to be excessive play when the wings are not rigged. When the plane is rigged, those sloppy bushes get hard to align unless you were superman during the cockpit module build up and got the fuselage and wing bushes just perfect. I only have two aircraft that align so well, the wing pins slide in easily, but that is only at 85 degrees and with the tips held just right. Hotter or colder, or with an untrained assistant, it is tougher to push the pins in. So what to do?
Since none of us is superman, I many times have re-aligned the bushes on final wing rigging by heating my spare tapered black pin until just too hot to touch, but not sizzle (180F), and ram it home. Let it set overnight and the three bushes get aligned. Once in a while, I do have to put my 1/2 inch reamer into the pilot side hole and knock a thousandth off for a nice hand fit of the pip pin because of the tighter tolerances.
Note: There is a good reason for using the pip pin when doing spar alignment, especially on the glider wing retrofit. Unfortunately we don't have the luxury of setting our own bushes with the short wings. If we follow the instructions blindly and use just the bolts, you won't quite get perfect alignment. So just heat the pin and help the bushes align.
Please do not overheat your existing wing pin and destroy the heat treating. At 6 Gs, you would not believe the shear load on that pin.
So don't rip everything out just yet, try a bit of heat and patience. It's worth it.
Bud Yerly
Posted: Tue Jan 18, 2011 12:16 am Post subject: Main wing bushings |
Thanks Bud,
now why didn't I think of that!
regards
Graham
Sent: Tuesday, 18 January, 2011 2:39:04
_filtered { font-family:Calibri;} _filtered { font-family:Consolas;} _filtered {margin:1.0in 1.0in 1.0in 1.0in;} P.MsoNormal { MARGIN:0in 0in 0pt;FONT-FAMILY:"serif";FONT-SIZE:12pt;} LI.MsoNormal { MARGIN:0in 0in 0pt;FONT-FAMILY:"serif";FONT-SIZE:12pt;} DIV.MsoNormal { MARGIN:0in 0in 0pt;FONT-FAMILY:"serif";FONT-SIZE:12pt;} A:link { COLOR:blue;TEXT-DECORATION:underline;} SPAN.MsoHyperlink { COLOR:blue;TEXT-DECORATION:underline;} A:visited { COLOR:purple;TEXT-DECORATION:underline;} SPAN.MsoHyperlinkFollowed { COLOR:purple;TEXT-DECORATION:underline;} PRE { MARGIN:0in 0in 0pt;FONT-FAMILY:"Courier New";FONT-SIZE:10pt;} SPAN.HTMLPreformattedChar { FONT-FAMILY:Consolas;} SPAN.apple-style-span { } SPAN.EmailStyle20 { FONT-FAMILY:"sans-serif";COLOR:#1f497d;} SPAN.EmailStyle21 { FONT-FAMILY:"sans-serif";COLOR:#1f497d;} .MsoChpDefault { FONT-SIZE:10pt;} DIV.WordSection1 { } Will, and others,
Bud Yerly
Posted: Tue Jan 18, 2011 4:36 am Post subject: Main wing bushings |
Thanks Bud
Will
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of Bud Yerly
Sent: 17 January, 2011 21:39
Will, and others,
Bud Yerly
kheindl(at)msn.com Guest
Posted: Tue Jan 18, 2011 6:16 am Post subject: Main wing bushings |
When I have help with the rigging then it is quite easy to locate the pins in my case, although the glider wings are quite a handful or two. But on my own it is more difficult. A couple of years ago I inherited a tapered 1/2 inch pin from an aircraft engineer and that works just fine. I tap it in carefully with a plastic hammer, and can then insert the pip pin into the other hole with ease. I don't now where one would buy such a tool.
Karl
Date: Mon, 17 Jan 2011 21:39:04 -0500
(at)page WordSection1 {size:8.5in 11.0in;} .ExternalClass P.ecxMsoNormal {font-family:'Times New Roman','serif';font-size:12pt;} .ExternalClass LI.ecxMsoNormal {font-family:'Times New Roman','serif';font-size:12pt;} .ExternalClass DIV.ecxMsoNormal {font-family:'Times New Roman','serif';font-size:12pt;} .ExternalClass A:link {color:blue;text-decoration:underline;} .ExternalClass SPAN.ecxMsoHyperlink {color:blue;text-decoration:underline;} .ExternalClass A:visited {color:purple;text-decoration:underline;} .ExternalClass SPAN.ecxMsoHyperlinkFollowed {color:purple;text-decoration:underline;} .ExternalClass PRE {font-family:'Courier New';font-size:10pt;} .ExternalClass SPAN.ecxHTMLPreformattedChar {font-family:Consolas;} .ExternalClass SPAN.ecxapple-style-span {;} .ExternalClass SPAN.ecxEmailStyle20 {font-family:'Calibri','sans-serif';color:#1f497d;} .ExternalClass SPAN.ecxEmailStyle21 {font-family:'Calibri','sans-serif';color:#1f497d;} .ExternalClass .ecxMsoChpDefault {font-size:10pt;} .ExternalClass DIV.ecxWordSection1 {page:WordSection1;} Will, and others,
Bud Yerly
kingsnjan(at)westnet.com. Guest
Posted: Wed Jan 19, 2011 1:30 am Post subject: Main wing bushings |
Graham,
You said "Just do this with the two wings, forget the bushes in the seat back, they really are better with a loose fit because they increase loads on the wings with G forces."
I am heartened to see you feel like I do about the bushes in the seat back. For the life of me, I have never been able to understand the purpose of them except that they may prohibit relative movement between the wings and the fuselage in the span direction. In this case one bush would be sufficient and would not load up the cockpit module/spars as I suspect it does now with the two bushes when under high G loads.
Just my 2c worth.
Regarding the slop between the pins and the bushes, I did the AUW increase mod and had to replace all original 3/8" bushes with the 1/2" ones. In doing the setting up, I purchased two 1/2" HT bolts and spray painted them with several coats of paint until they were a neat fit. Probably not the smartest idea around but with the limited resources I had it worked and my wing pins are a delight to install and remove.
Weather seems to be settling down a bit here now, we have had a drought for the last 24 hrs !!
Cheers
Kingsley
Posted: Wed Jan 19, 2011 3:58 am Post subject: Main wing bushings |
KingsleyI don't understand due to my limited knowledge of the engineering.What alternative might there be?WillFrom: Kingsley Hurst <kingsnjan(at)westnet.com.au>
Sender: "owner-europa-list-server(at)matronics.com" <owner-europa-list-server(at)matronics.com>
Date: Wed, 19 Jan 2011 04:26:38 -0500
To: europa-list(at)matronics.com<europa-list(at)matronics.com>
ReplyTo: "europa-list(at)matronics.com" <europa-list(at)matronics.com>
Subject: Re: Europa-List: Re: Main wing bushings
Graham,
Just my 2c worth.
Cheers
Kingsley
Posted: Wed Jan 19, 2011 4:32 am Post subject: Main wing bushings |
I'm trying to visualize the geometry of the high-g loading scenario wrt to the seat-back bushes imparting additional/undesired stress on the spars.
Is this due to the distance between inner and outer spar bushings decreasing when the spars are flexed (due to the arc)? Or is it the twisting moment imparted on the spars due to the one-sided mount (although aren't the lift pins supposed to take the vertical G-loading)?
Cheers,
Pete
A239
On Wed, Jan 19, 2011 at 4:26 AM, Kingsley Hurst <kingsnjan(at)westnet.com.au (kingsnjan(at)westnet.com.au)> wrote:
[quote] Graham,
Just my 2c worth.
Cheers
Kingsley
arget="_blank">http://www.matronics.com/Navigator?Europa-List
Posted: Wed Jan 19, 2011 8:02 am Post subject: Main wing bushings |
Pete
in +ve G the wing (& spar) bends.so the spar pins are trying to push down while the lift pins, designed to take the lift loads, are pushing up. So each of these conflicting tendencies adds to the loading of the other. THe twist is also a problem probably the same reason
I bet Bud has a better way of describing it
Graham
Sent: Wednesday, 19 January, 2011 12:28:02
Cheers,
Pete
A239
[quote] Graham,
Just my 2c worth.
Cheers
Kingsley
http://www.matronics.com/con================
Posted: Wed Jan 19, 2011 8:36 am Post subject: Main wing bushings |
Yes, I see now (since the spar pins are inboard of the lift pins and along the arc of the bending spars).
Thx!
Pete
A239
On Wed, Jan 19, 2011 at 10:57 AM, GRAHAM SINGLETON <grahamsingleton(at)btinternet.com (grahamsingleton(at)btinternet.com)> wrote:
[quote] Pete
I bet Bud has a better way of describing it [img][/img]
Graham
From: Peter Zutrauen <peterz(at)zutrasoft.com (peterz(at)zutrasoft.com)>
To: europa-list(at)matronics.com (europa-list(at)matronics.com)
Cheers,
Pete
A239
| Quote: | Graham,
Just my 2c worth.
Cheers
Kingsley
Posted: Wed Jan 19, 2011 7:40 pm Post subject: Main wing bushings |
Hello Will,
I am not suggesting there is any alternative for us as builders. The design "as is" obviously fits the bill so the old adage, "if it ain't broke, don't fix it" is appropriate.
From a designer's point of view however, if you inspect the various methods employed by sailplane manufacturers, there are possibly better ways of doing it. I have never seen a sailplane with the same set-up as the Europa but that doesn't mean there isn't any. Ivan Shaw did get some ideas from sailplanes so maybe he found one . . . . I dunno!
Cheers
Kingsley
Posted: Thu Jan 20, 2011 12:56 am Post subject: Main wing bushings |
Kingsley
Ivan didn't do the stress calcs. As I understand it, (I'm not a stress man either) you could leave out the bushes in the seat back.
The motor glider has been redesigned and the spar tangs have been stiffened. I don't know if the seat back bushes were deleted. I just asked Ivan and he doesn't know either (or chose not to remember )
I guess Bud might tell us?
Graham
Sent: Thursday, 20 January, 2011 3:33:19
 DIV { MARGIN:0px;} Hello Will,
Cheers
Kingsley
