Transponder antenna signal
Speedy11(at)aol.com
PostPosted: Fri Jan 14, 2011 8:44 pm    Post subject: Transponder antenna signal Reply with quote
Bob - or other antenna gurus,
I want to streamline my transponder antenna. I have the short (3 inch) stub antenna with the ball on the tip. To streamline it I'm going to make an epoxy resin fiberglass covering that will look like a blade antenna.
Please confirm for me that streamlining with a fiberglass covering will not affect signal performance.
Stan Sutterfield
dsvs(at)ca.rr.com
PostPosted: Fri Jan 14, 2011 9:42 pm    Post subject: Transponder antenna signal Reply with quote
Stan,
Can’t answer your question but check out this site for a streamlined antenna. www.deltapopaviation.com
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Speedy11(at)aol.com
Sent: Friday, January 14, 2011 8:41 PM
Subject: Transponder antenna signal
Stan Sutterfield
kuffel(at)cyberport.net
PostPosted: Fri Jan 14, 2011 11:24 pm    Post subject: Transponder antenna signal Reply with quote
Stan,
<< streamline my transponder antenna... streamlining with a fiberglass covering will not affect signal performance.<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" /> >>
As long as you don't use any paint/ingredients containing metal or carbon there shouldn't be any observable difference.
Tom Kuffel
rparigoris
PostPosted: Sat Jan 15, 2011 3:45 pm    Post subject: Transponder antenna signal Reply with quote
Hi Stan<< streamline my transponder antenna... streamlining with a fiberglass > covering will not affect signal performance. >> I am using an AAE transponder antenna in my plastic Europa. AAE says if you are installing it on the side of a plastic aeroplane that you must stand the antenna off with a supplied piece of Balsa. You could contact them and ask why. I think I did and it was perhaps electrostatic build up?Ron Parigoris [quote][b]
Mauledriver(at)nc.rr.com
PostPosted: Sat Jan 15, 2011 4:36 pm    Post subject: Transponder antenna signal Reply with quote
I like that.
You've been watching:
http://www.youtube.com/watch?v=ftq8jTQ8ANE
(excuse me if I'm being circular here)
Bill "need something to do until it warms up" Watson
On 1/14/2011 11:41 PM, Speedy11(at)aol.com (Speedy11(at)aol.com) wrote: [quote] Bob - or other antenna gurus,
Stan Sutterfield
sportav8r(at)gmail.com
PostPosted: Sat Jan 15, 2011 7:09 pm    Post subject: Transponder antenna signal Reply with quote
I built just such a radome for my XPDR antenna and it worked fine, until a bit of oil collected in it from the belly - that was a different story.  I think it attenuated the signal quite a bit, but I later found I was having other issues with my XPDR tray coax fitting that overshadowed any oil contamination problem inside the radome.
I must say: while it was a fun exercise in making molds and casting a fiberglass part, it did nothing noticeable for my top speed.
Bill B
RV-6A
On Sat, Jan 15, 2011 at 7:30 PM, Bill Watson <Mauledriver(at)nc.rr.com (Mauledriver(at)nc.rr.com)> wrote:
[quote] I like that.
Stan Sutterfield
ist" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List
tp://forums.matronics.com
email(at)jaredyates.com
PostPosted: Sat Jan 15, 2011 7:51 pm    Post subject: Transponder antenna signal Reply with quote
Stan, One of my local chapter members found a shark-fin style unit on ebay for less than $20 shipped.  He stripped the paint off and found it to be made of what appeared to be mostly solid aluminum, so he repainted it and installed it.  You might be able to find something similar, unless you are wanting to enjoy the sport of building up some foam or balsa and coating it with light fiberglass cloth and such.
On Sat, Jan 15, 2011 at 10:05 PM, Bill Boyd <sportav8r(at)gmail.com (sportav8r(at)gmail.com)> wrote:
[quote] I built just such a radome for my XPDR antenna and it worked fine, until a bit of oil collected in it from the belly - that was a different story.  I think it attenuated the signal quite a bit, but I later found I was having other issues with my XPDR tray coax fitting that overshadowed any oil contamination problem inside the radome.
Bill B
RV-6A
I like that.
Stan Sutterfield
BobsV35B(at)aol.com
PostPosted: Sat Jan 15, 2011 8:00 pm    Post subject: Transponder antenna signal Reply with quote
Good Evening Bill B.
I always install the little blade antennas because I have broken so many of the little "wire with a ball" style either when washing the belly or just rolling around under the airplane on a creeper.
Happy Skies,
Old Bob
LL22
Stearman N3977A
In a message dated 1/15/2011 9:10:23 P.M. Central Standard Time, sportav8r(at)gmail.com writes:
Bill B
RV-6A
Speedy11(at)aol.com
PostPosted: Sun Jan 16, 2011 2:02 pm    Post subject: Transponder antenna signal Reply with quote
Great responses from everyone. I appreciate each one. Like Old Bob, I've broken off stub antenna. I'd considered switching to a blade antenna, but didn't want to fit a new antenna. I will reconsider that option, but I'd like to investigate doing my own "antenna fairing."
I've been gradually making streamlining changes to my RV-8A and I now claim the status of "world's fastest RV-8A." Maybe a streamlined transponder antenna will help a tiny bit more. My new target is 200 KIAS in level flight at 1000" MSL. I'm already within reach of that goal.
Thanks again for your responses.
Stan Sutterfield
I like that.
blade antenna.
Stan Sutterfield
JOHN TIPTON
PostPosted: Sun Jan 16, 2011 3:28 pm    Post subject: Transponder antenna signal Reply with quote
200 KIAS at 1000 " (inches) - WOW
Float Flyr
PostPosted: Sun Jan 16, 2011 8:05 pm    Post subject: Transponder antenna signal Reply with quote
I figure that a transponder antenna will have about the same effect on an aircraft that flies less then 150kt/hr as a good wax job. As the speed goes up the fairing of everything becomes more noticeable. Pardon me for stating the obvious.
As for the look of a faired antenna it is, to me, much nicer to look at. If you consider fairing the antenna yourself then I guess you should also consider the cost of the resins, fillers and paint or finish. Then factor in all the time to cast a reasonable fairing and the extra ounces that it will add to your plane. If your plane is less than 200kt I wouldn’t bother... If it’s better than 200 kt I’d be on the lookout for a faired antenna.. Put the bug in to all local avionics shops you’ll be surprised what you can come up with.
Noel
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of JOHN TIPTON
Sent: January 16, 2011 7:55 PM
Subject: Re: Re: Transponder antenna signal
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
rv6awingman(at)gmail.com
PostPosted: Mon Jan 17, 2011 7:12 am    Post subject: Transponder antenna signal Reply with quote
Stan,
Interesting post "world's fastest RV-8A", indeed.  How about sharing some of the tricks you used to achieve this goal.  You maybe onto something here, starting a new trend in "experimenting".
Marty RV-6A N826ME
Time: 02:02:03 PM PST US
Subject: Re: Transponder antenna signal
Stan Sutterfield
JohnInReno
PostPosted: Tue Jan 18, 2011 3:47 pm    Post subject: Transponder antenna signal Reply with quote
I just saw a picture posted re: oil separator that showed a transponder antenna mounted inside the lower cowling. Looked interesting but I'm not sure which group it was.
john
On 1/16/2011 1:57 PM, Speedy11(at)aol.com (Speedy11(at)aol.com) wrote: [quote] Great responses from everyone. I appreciate each one. Like Old Bob, I've broken off stub antenna. I'd considered switching to a blade antenna, but didn't want to fit a new antenna. I will reconsider that option, but I'd like to investigate doing my own "antenna fairing."
Stan Sutterfield
I like that.
> blade antenna.
> Thanks,
> Stan Sutterfield
John Morgensen
RV-9A - Born on July 3, 2013
RV4 - for sale
JOHN TIPTON
PostPosted: Wed Jan 19, 2011 12:48 am    Post subject: Transponder antenna signal Reply with quote
Hi John (Morgensen)
I saw that article, and I checked it out, see below
John (RV9a wings - England)
