GT blades for V-530
radiopicture
PostPosted: Tue Jan 18, 2011 5:02 pm    Post subject: GT blades for V-530 Reply with quote
As long as we're talking about propeller options, I think we're overlooking the GT blades for the V-530, which have been in use for several years on dozens of airplanes. The Aerostar factory furnishes them on new Yak-52s as an option (I think they said there was a recent order of 20). We have tested them on the Sukhoi SU-26M and Yak-52 with great results.
 Filesize:  462.05 KB
 Viewed:  4438 Time(s)
 Filesize:  526.05 KB
wise(at)txc.net.au
PostPosted: Wed Jan 19, 2011 1:05 am    Post subject: GT blades for V-530 Reply with quote
G'Day All,
I have been following the blog re the Whirlwind blades and note the email
from Eric re the GT Blades.
Please find the attached photo of my 18T at a Air Show performance.
Since fitting the GT blades, we have a shorter take off distance, a better
climb and cruise performance and as per Chris Sperou states, who is a Air
Display pilot of note in Australia and is cleared for aerobatics to 0 feet,
and has flown this aircraft with the old V-530 at Air Displays and states
that without a doubt, the performance with the GT blades
Is a huge improvement. Chris is of the opinion that it "hangs in" during the
manoeuvres far better than the V-530 Blades.
I have recently done a 2300nm round trip up north and I had absolutely no
bother getting in and out of short strips with full tanks, 3 people and
baggage.
I know of a Culp Special in Perth, Australia, that the owner has recently
fitted GT blades to the M14P and he clearly states that he has a better
performance and far less propeller turbulence from the propeller vortex
around the cockpit area.
So for my 2 bob I would have to say that what we are talking about with
regard to both props, is that they are both of a superior design and both
would offer a higher performance.
Here in Australia, the GT blades have proved to be superior in performance
on Yak 52, 18 and Yak 55 than the old V-530 blades. All round.
In fact, the GT blades fitted to the Australian manufactured Jabiru gives a
all round better performance than the original Jab blades.
This also applies to the rotax engine powered aircfat.
Cheers from Downsouth.
Chris
 Filesize:  201.81 KB
 Viewed:  4427 Time(s)
psb777
PostPosted: Sat Feb 05, 2011 7:51 am    Post subject: Re: GT blades for V-530 Reply with quote
How much? What diameter is the prop with these blades? More or less than original? What are the overhaul hours/years on these blades? Are they legal to fit to EASA (restricted-)CoA certified Yak-18T? Thanks!
Paul Beardsell
G-PYAK http://beardsell.com/flying/g-pyak
Yak-18T http://beardsell.com/flying/yak18t
