Posted: Tue Jan 18, 2011 8:46 pm Post subject: bonding thermocouples |
Hi Y'all...
I'm wondering if anyone can recommend a method for attaching the
joined end of a thermocouple to a flat aluminum surface...I've some
situations where clamping is not possible...I expect to have
temperatures in the 150 to 200 deg. F. range...will be measuring
coolant temp at inlet and exit areas of radiators...(non-Rotax
powerplant).
Fred
A194
erichdtrombley(at)juno.co Guest
Posted: Wed Jan 19, 2011 7:40 am Post subject: bonding thermocouples |
Fred,
A couple of ideas come to mind. You could fab an aluminum "P" clamp around the body of the thrermocouple and attached with a screw or pop rivet to the aluminum plate. Alternatley, you can insert the TC into a piece of aluminum tubing which is 1/2" or so longer then body of the TC with an I.D the same as the O.D of the TC. Flatten the extended piece of tubing, drill a hole and mount as above. Good luck.
Erich Trombley
N28ET Classic Mono 914
Banks Forced to Forgive Credit Card Debt
Find Out How Much of Your Debt Can Be Erased.
LowerMyBills.com [quote][b]
