		richard.goode(at)russiana Guest
				 Posted: Wed Jan 19, 2011 1:40 am    Post subject: GT Propellors |
				From everything I have heard I suspect that the GT  blades do give a good advantage over the V-530 blades.But then the V-530 is a  50+ year old design,so a new blade really SHOULD perform a lot  better!
  But when is someone going to produce proper  scientific performance figures comparing these different props,including  MT,rather than saying that"acceleration is much better",or similar subjective  assesments??
  Richard Goode Aerobatics
 Rhodds Farm
 Lyonshall
 Hereford
 HR5 3LW
 United Kingdom
  Tel:   +44 (0) 1544 340120
 Fax:   +44 (0) 1544 340129
 www.russianaeros.com
 I’m currently in  Sri Lanka but this Mail is working,and my local phone is +94 779 132  160.
  |  | - The Matronics Yak-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		ssssskippy
				 Posted: Wed Jan 19, 2011 2:45 am    Post subject: GT Propellors |
				I found something not so good about the GT Prop: http://gtpropellers.com/
 [/url]Of course a problem is always a possibility but the AAIB's conclusions are very bad:
  [url=http://www.aaib.gov.uk/publications/bulletins/september_2009/speedtwin_st2__g_stdl.cfm]http://www.aaib.gov.uk/publications/bulletins/september_2009/speedtwin_st2__g_stdl.cfm
 [/url]Olivier
 2011/1/19 Richard.Goode <richard.goode(at)russianaeros.com (richard.goode(at)russianaeros.com)>
 [quote]        From everything I have heard I suspect that the GT  blades do give a good advantage over the V-530 blades.But then the V-530 is a  50+ year old design,so a new blade really SHOULD perform a lot  better!
 Rhodds Farm
 Lyonshall
 Hereford
 HR5 3LW
 United Kingdom
 [url=http://www.russianaeros.com]www.russianaeros.com
 et="_blank">http://www.matronics.com/Navigator?Yak-List
 tp://forums.matronics.com
		radiopicture
				 Posted: Wed Jan 19, 2011 2:57 am    Post subject: GT Propellors |
				That isn't this model of GT propeller, and I have never known GT to be anything less than responsive. This is not some company that just popped up overnight, and they make propellers for a pretty large range of aircraft including historic warbirds like Spitfires. As you know, anything can be put on the internet.
 On Jan 19, 2011, at 5:42 AM, Olivier Vigneron wrote:
 [quote]I found something not so good about the GT Prop: http://gtpropellers.com/
 [/url]Olivier
  	  | Quote: | 	 		          From everything I have heard I suspect that the GT  blades do give a good advantage over the V-530 blades.But then the V-530 is a  50+ year old design,so a new blade really SHOULD perform a lot  better!
 Rhodds Farm
 Lyonshall
 Hereford
 HR5 3LW
 United Kingdom
 [url=http://www.russianaeros.com/]www.russianaeros.com
 href="http://www.matronics.com/Navigator?Yak-List">http://www.matronics.com/Navigator?Yak-List
  | 	  [b]
		radiopicture
				 Posted: Wed Jan 19, 2011 2:58 am    Post subject: GT Propellors |
				Richard:
 I did find this data from Rick Volker, which I realize is anecdotal, but I think still useful and coming from someone who knows what he's doing:
  	  | Quote: | 	 		  Max level speed: mtv3=gt= v530=330kph
 Mtv9 slower by 10 kph
 Max cruise: mtv3=gt=v530=305kph
 Mtv9 slower by 8 kph
 Full power stall speed: V530=65 mph,mtv3=60 kph
 Gt=50kph , MTV 9= < 50 kph(hovering possible)-below measurable airspeed
 Vertical penetration from 6G pull,330kph:
 V530=1600', mtv3=1700', GT=1700',Mtv9=2000'
 Time on vertical line: v530=17 second. Mtv3=20 second. GT=20 seconds.MTV 9= >30 second (hovering).
 Time to climb 1000' to 2000': v530=20 second.
 GT= 20 second., mtv3=17 second, mtv9=17 seconds.
 Level acceleration full power, 200kph to 300kph:
 V530= 17sec. GT= 17sec. Mtv3=15 sec.mtv9=16 second.
 Descent rate at idle with prop at 100%rpm:
 Mtv9 =15 sec/1000',GT=32sec/1000',v530=35sec/1000',mtv3= 40sec/1000'
 Note: the MTV 9 has longer blades and was optimized for static thrust. It stays much flatter power off, is significantly slower in speed, but will hover this weight aircraft.
 The GT has more static thrust than the MTV3 and more thrust from 0 to 120kph. It loses to the mtv3 at 170kph Vy climb and at 200-300kph acceleration, but has same top speed and cruise speed. The GT power off descent rate is high, suggesting the blades stay very flat at power off .
 The GT was only static balanced and was much lower vibration than the v530 which had been dynamic balanced. The MTV3 and MTV9 had been dynamic balanced and were by far the smoothest props. It would be conceivable that the GT would be smoother if dynamic balanced. The GT may need a spinner with backing plate to allow dynamic balancing to the same level as a three blade prop.  GT is developing a carbon fiber spinner that is 46 cm wide for the V530 hub.
 Vertical penetration and time on vertical line upwards were equal with mtv3 vs GT.
 From these tests, the GT is as good as the mtv3-250 three blade prop during aerobatics and may be as good an all around prop for aerobatics, travel, and short field take offs. The mtv9-260-29 has been optimized for aerobatics and air shows at the expense of slower cruise, max speed, and poor glide characteristics. It would be advisable to test the GT against the MTV9-250 with both the-27 and -29 blades.
 The GT is superior to the v530 in static thrust, vertical penetration, power on stall, and vibration. It is equal in climb, midspeed acceration,cruise,and top speed. The GT has a slightly worse power off glide than the v530.  There is also more propeller braking with the GT than with the V530 on roll out after landing.
 Rhodds Farm
 Lyonshall
 Hereford
 HR5 3LW
 United Kingdom
				 Posted: Wed Jan 19, 2011 7:09 am    Post subject: GT Propellors |
				You know for the majority of us that are using our YAKs and CJs for weekend attitude adjustment the superiority
 Of which blade beats the other by 3 seconds is academic. Blades separating at the hub, serviceability,static vs
 Dynamic balance out of the box and overall safety of the blades are of great interest. Expense of replacement
 In this down turned economy is of greater interest. For those that need to replace blades, cost,reliability, and serviceability are big issues. How much damage to the M-14 do these new composite carbon fiber blades do to the M-14 when landed gear up at idle throttle? The reliable v530 turns to saw dust without generally destroying the engine necessitating an expensive engine replacement. Any data out there on that?
 We YAK and CJ'ers are a cheap bunch you know?
 doc
 On Jan 19, 2011, at 4:56 AM, Eric Wobschall <eric(at)buffaloskyline.com (eric(at)buffaloskyline.com)> wrote:
 [quote]Richard:
 Mtv9 slower by 8 kph lia
 Rhodds Farm
 Lyonshall
 Hereford
 HR5 3LW
 United Kingdom
 ums.matronics.com">http://forums.matronics.com
 http://www.matronics.com/contribution">http://www.matronics.com/contribution
				 Posted: Wed Jan 19, 2011 7:38 am    Post subject: GT Propellors |
				Now THAT's clearly one of the most intelligent comments on the subject
 of prop blades I've heard.  Thanks Doc for bringing me and probably some
 other folks on the list back down to earth.
 Dennis
 A. Dennis Savarese
 334-285-6263
 334-546-8182 (cell)
 Skype: Yakguy1
 www.yak-52.com
 On 1/19/2011 9:06 AM, Roger Kemp M.D. wrote:
  	  | Quote: | 	 		   You know for the majority of us that are using our YAKs and CJs for
  doc
  <mailto:eric(at)buffaloskyline.com>> wrote:
 > Richard:
 > doing:
 >> V530=1600', mtv3=1700', GT=1700',Mtv9 00'
 >> Time on vertical line: v530=17 second. Mtv3  second. GT
 >> Time to climb 1000' to 2000': v530  second.
 >> power off .
 >> with mtv3 vs GT.
 >> -29 blades.
 >> assesments??
 >> Rhodds Farm
 >> Lyonshall
 >> Hereford
 >> HR5 3LW
 >> United Kingdom
 >> <http://www.russianaeros.com>www.russianaeros.com
 >> href="http://forums.matronics.com">http://forums.matronics.com
 >> href="http://www.matronics.com/contribution">http://www.matronics.com/contribution
		radiopicture
				 Posted: Wed Jan 19, 2011 8:35 am    Post subject: GT Propellors |
				No doubt of it. As Jill stated this need arose primarily due to a dearth of replacement blades, and not so much responding to a need for better performance. Having said this, the new offerings seem to be a step up in terms of balance and finish quality. I would also point out that performance of the props (including the three-blade MT) are surprisingly similar.
 On Jan 19, 2011, at 10:36 AM, A. Dennis Savarese wrote:
  Now THAT's clearly one of the most intelligent comments on the subject of prop blades I've heard.  Thanks Doc for bringing me and probably some other folks on the list back down to earth.
  Dennis
  A. Dennis Savarese
  334-285-6263
  334-546-8182 (cell)
  Skype: Yakguy1
  www.yak-52.com
 > doc
 > Sent from my iPad
 >> Richard:
 >> doing:
 >>> power off .
 >>> with mtv3 vs GT.
 >>> -29 blades.
 >>> assesments??
 >>> Rhodds Farm
 >>> Lyonshall
 >>> Hereford
 >>> HR5 3LW
 >>> United Kingdom
		wise(at)txc.net.au Guest
				 Posted: Wed Jan 19, 2011 12:09 pm    Post subject: GT Propellors |
				Strong rumour suggests that this was the result of a birdstrike???
 Chris.
 From: owner-yak-list-server(at)matronics.com [mailto:owner-yak-list-server(at)matronics.com] On Behalf Of Olivier Vigneron
 Sent: Wednesday, 19 January 2011 9:13 PM
 To: yak-list(at)matronics.com
 Subject: Re: GT Propellors
 Olivier
 Rhodds Farm
 Lyonshall
 Hereford
 HR5 3LW
 United Kingdom
  	  | Quote: | 	 		  |   et="_blank">http://www.matronics.com/Navigator?Yak-Listtp://forums.matronics.com_blank">http://www.matronics.com/contribution  |
 0123456789 	  | Quote: | 	 		  | et="_blank">http://www.matronics.com/Navigator?Yak-List | 	  0 	  | Quote: | 	 		  | et="_blank">http://www.matronics.com/Navigator?Yak-List | 	  1 	  | Quote: | 	 		  | et="_blank">http://www.matronics.com/Navigator?Yak-List | 	  2 	  | Quote: | 	 		  | et="_blank">http://www.matronics.com/Navigator?Yak-List | 	  3
		rick(at)rvairshows.com Guest
				 Posted: Wed Jan 19, 2011 12:48 pm    Post subject: GT Propellors |
				How about using less fuel at a given airspeed, better resistance to stones and rain, smoother balance out of the box, utility of using the original hub, or saving brakes due to better prop braking, increased safety in shorter take off roll? Throw in ease of repair. The GT prop does all these things better to appeal to those light in the wallet. Better Climb and cruise performance yields economy.  I agree that the MT prop is overkill for most Yak/CJ owners.Rick VOLKER
 Sent from my Verizon Wireless BlackBerryFrom:  "Roger Kemp M.D." <viperdoc(at)mindspring.com>
 Sender:  owner-yak-list-server(at)matronics.com
 Date: Wed, 19 Jan 2011 09:06:17 -0600
 To: yak-list(at)matronics.com<yak-list(at)matronics.com>
 ReplyTo:  yak-list(at)matronics.com
 Subject: Re: Yak-List: GT Propellors
 You know for the majority of us that ar= e using our YAKs and CJs for weekend attitude adjustment the superiorityOf which blade beats the other by 3 seconds is academic. Blades separ= ating at the hub, serviceability,static vs
 Dynamic balance o= ut of the box and overall safety of the blades are of great interest. Expens= e of replacement
 In this down turned economy is of greater interes= t. For those that need to replace blades, cost,reliability, and serviceabili= ty are big issues. How much damage to the M-14 do these new composite carbon=  fiber blades do to the M-14 when landed gear up at idle throttle? The relia= ble v530 turns to saw dust without generally destroying the engine necessita= ting an expensive engine replacement. Any data out there on that? We YAK and CJ'ers are a cheap bunch you know?
 doc
 On Jan 19, 2011, at 4:56 AM, Eri= c Wobschall <eric(at)buffaloskyli= ne.com (eric(at)buffaloskyline.com)> wrote:
 [quote]Richard:
 I did find this data from Rick Volker, which I r= ealize is anecdotal, but I think still useful and coming from someone who kn= ows what he's doing:
  	  | Quote: | 	 		  Max=  level speed: mtv3=3Dgt=3D v530=3D330kph
 Mtv9 slower by 10 kph&= nbsp;
 Max cruise: mtv3=3Dgt=3Dv530=3D305kph
 Mtv9 sl= ower by 8 kph lia
 Full power stall speed: V530=3D65 mph,mt= v3=3D60 kph
 Gt=3D50kph , MTV 9=3D < 50 kph(hovering po= ssible)-below measurable airspeed
 Vertical penetration from 6G p= ull,330kph:
 V530=3D1600', mtv3=3D1700', GT=3D1700',Mtv9=3D2000'=
 Time on vertical line: v530=3D17 second. Mtv3=3D20 second. GT=3D= 20 seconds.MTV 9=3D >30 second (hovering).
 Time to climb 100= 0' to 2000': v530=3D20 second.
 GT=3D 20 second., mtv3=3D17 seco= nd, mtv9=3D17 seconds.
 Level acceleration full power, 200kph to=  300kph:
 V530=3D 17sec. GT=3D 17sec. Mtv3=3D15 sec.mtv9=3D16 se= cond.
 Descent rate at idle with prop at 100%rpm:</= div>Mtv9 =3D15 sec/1000',GT=3D32sec/1000',v530=3D35sec/1000',mtv3=3D 40sec/= 1000'
 Note: the MTV 9 has longer blades and was optimized for st= atic thrust. It stays much flatter power off, is significantly slower in spe= ed, but will hover this weight aircraft.
 The GT has more s= tatic thrust than the MTV3 and more thrust from 0 to 120kph. It loses to the=  mtv3 at 170kph Vy climb and at 200-300kph acceleration, but has same top sp= eed and cruise speed. The GT power off descent rate is high, suggesting the b= lades stay very flat at power off .
 The GT was only stati= c balanced and was much lower vibration than the v530 which had been dynamic=  balanced. The MTV3 and MTV9 had been dynamic balanced and were by far the s= moothest props. It would be conceivable that the GT would be smoother if dyn= amic balanced. The GT may need a spinner with backing plate to allow dynamic=  balancing to the same level as a three blade prop.  GT is developing a=  carbon fiber spinner that is 46 cm wide for the V530 hub. Vertical penetration and time on vertical line upwards were equal with mtv3=  vs GT.
 =46rom these tests, the GT is as good as the mtv3-2= 50 three blade prop during aerobatics and may be as good an all around prop f= or aerobatics, travel, and short field take offs. The mtv9-260-29 has been o= ptimized for aerobatics and air shows at the expense of slower cruise, max s= peed, and poor glide characteristics. It would be advisable to test the GT a= gainst the MTV9-250 with both the-27 and -29 blades.
 The GT is su= perior to the v530 in static thrust, vertical penetration, power on stall, a= nd vibration. It is equal in climb, midspeed acceration,cruise,and top speed= . The GT has a slightly worse power off glide than the v530.  There is a= lso more propeller braking with the GT than with the V530 on roll out after l= anding.
 On J= an 19, 2011, at 4:43 AM, Richard.Goode wrote:
  	  | Quote: | 	 		  =46rom everything I have heard I suspect that the GT blades do give a goo= d advantage over the V-530 blades.But then the V-530 is a 50+ year old desig= n,so a new blade really SHOULD perform a lot better!
 But when is someone going to produce proper scienti= fic performance figures comparing these different props,including MT,rather t= han saying that"acceleration is much better",or similar subjective assesment= s??
 Richard Goode Aerobatic= s
 Rhodds Farm
 Lyonshall
 Hereford
 HR5 3LW
 United Kingdom
 = www.russianaeros.com
 I=E2= =80=99m currently in Sri Lanka but this Mail is working,and my local phone i= s +94 779 132 160.
 href=3D"http://www.m=
 href=3D"http://forums.matronics.com<=
 /a>">http://forums.matronics.com<=
 /a>
 href=3D"http://www.matroni=
 /font> |
 =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=
 ef=3D"http://www.matronics.com/Navigator?Yak-List">http://www.matronics.com/=
 Navigator?Yak-List
 http://www.matronics.com/contribution">http://www.matronics.com/contribution=
 /font> |
  | 	  =  [quote][b]
		cpayne(at)joimail.com Guest
				 Posted: Wed Jan 19, 2011 5:05 pm    Post subject: GT Propellors |
				Remarkable! Same sorta experience I had with email to GT propellers rep named  "Humberto". Me no speakee english I guess.
 Craig Payne
