krhooper(at)gmail.com Guest
Posted: Wed Jan 19, 2011 7:49 am Post subject: sticking brake |
Check that the pressure plate is free to move on the pins. some times they get rusty and bind.
Yes I'd check this before next flight.
On Wed, Jan 19, 2011 at 9:23 AM, thomas sargent <sarg314(at)gmail.com (sarg314(at)gmail.com)> wrote:
| Quote: | Taxiiing out after my last landing the right brake on my RV-6A was sticking. (I've only got about 30 hours on the plane.) Full left rudder wouldn't overcome it. I had to keep tapping the left brake. Back in the hangar the right wheel fairing was pretty warm.
I've assumed that with new brakes, that sticking would take care of itself after a bit as the pad wears down.
Is there anything I can do to fix this?
Is ther anytjhing I should check before I fly again.
Tom Sargent
t="_blank">http://www.matronics.com/Navigator?RV-List
ttp://forums.matronics.com
Randy Hooper
tsneidin(at)wisc.edu Guest
I had the same issue even with additional springs added to the brake cylinder. Turned out that I had over tightened the bolts connecting the brake pedals to the rudder weldment. It doesn't take much binding to cause the brakes to hangup and generate a lot of heat.
Todd Neidinger
RV-9
On 1/19/2011 9:23 AM, thomas sargent wrote: | Quote: | Taxiiing out after my last landing the right brake on my RV-6A was sticking. (I've only got about 30 hours on the plane.) Full left rudder wouldn't overcome it. I had to keep tapping the left brake. Back in the hangar the right wheel fairing was pretty warm.
I've assumed that with new brakes, that sticking would take care of itself after a bit as the pad wears down.Â
Tom Sargent
Painless
Joined: 10 Jan 2006 Posts: 40 Location: Peshtigo, Wisconsin
Posted: Wed Jan 19, 2011 8:01 am Post subject: sticking brake |
Tom:
This is very common with the Matco master cylinders provided with the kit.
Two things you can do include installing an additional external spring at the top of each brake cylinder, as well as installing a single, long bolt where each brake pedal pivots. If you visit vansairforce.net and search the subject, you should be able to find some pictures. Was discussed at rivetbangers.com as well.
I found that installing the extra springs did the trick for me.
Jeff Orear
RV6A N782P
Peshtigo, WI
Sent from my iPad
On Jan 19, 2011, at 9:23 AM, thomas sargent <sarg314(at)gmail.com (sarg314(at)gmail.com)> wrote:
[quote]Taxiiing out after my last landing the right brake on my RV-6A was sticking. (I've only got about 30 hours on the plane.) Full left rudder wouldn't overcome it. I had to keep tapping the left brake. Back in the hangar the right wheel fairing was pretty warm.
Tom Sargent
_________________ Jeff Orear
RV6A N782P
Peshtigo, WI |
bob194bn(at)verizon.net Guest
Posted: Wed Jan 19, 2011 11:48 am Post subject: sticking brake |
Better to fix before next flight always,harder to fix away from home,and safer at home.
To: rv-list <rv-list(at)matronics.com>
Sent: Wed, January 19, 2011 7:23:33 AM
Subject: sticking brake
Tom Sargent
[quote][b][b]
Posted: Wed Jan 19, 2011 12:21 pm Post subject: sticking brake |
On 1/19/2011 10:23 AM, thomas sargent wrote: | Quote: | Taxiiing out after my last landing the right brake on my RV-6A was sticking. (I've only got about 30 hours on the plane.) Full left rudder wouldn't overcome it. I had to keep tapping the left brake. Back in the hangar the right wheel fairing was pretty warm.
I've assumed that with new brakes, that sticking would take care of itself after a bit as the pad wears down. | The problem may be the brake puck isn't relaxing when the brake pedal is released
Or it may be the O-ring on the brake puck is old and hardened.
| Quote: | Â
| First, check that the master cylinder piston rod is coming all the way out. It only needs to be in a little bit to block the fluid from coming back.
If that doesn't solve the problem, check the brake cylinder.
Remove the puck in the brake cylinder.
clean the brake cylinder on the inside.
Replace the O-ring on the puck.
Is ther anytjhing I should check before I fly again. | Well, bleed the brakes again.
Linn
Tom Sargent
om/Navigator?RV-List">http://www.matronics.com/Navigator?RV-List
s.com">http://forums.matronics.com
om/contribution">http://www.matronics.com/contribution
| [b]
