Posted: Thu Jan 20, 2011 6:08 am Post subject: voltage regulators/alternator |
I thought I was going to mount my alternator this weekend and finish everything up. Again no instruction in the box for the Plane Power alternator, so I looked online and found the installation instructions.
WHere do I purchase the R1224 regulator? I didn't see it on Vans site or ACS.
Silly me to think the gum balls would actually come in the gum ball machine
Kelly McMullen
Posted: Thu Jan 20, 2011 6:43 am Post subject: voltage regulators/alternator |
http://www.plane-power.com/R1224.htm
http://www.plane-power.com/dealers.htm
http://www.aircraftspruce.com/catalog/eppages/planePowerSAL.php
http://www.chiefaircraft.com/airsec/Aircraft/ElectricalSystem/Alternators.html
Airpower has it as well for $150, Chief 155 and the rest of the dealers shown seem to want $168.
On Thu, Jan 20, 2011 at 7:04 AM, John Gonzalez <indigoonlatigo(at)msn.com (indigoonlatigo(at)msn.com)> wrote:
Quote: | I thought I was going to mount my alternator this weekend and finish everything up. Again no instruction in the box for the Plane Power alternator, so I looked online and found the installation instructions.
Silly me to think the gum balls would actually come in the gum ball machine.
Quote: |
tp://forums.matronics.com
#avg_ls_inline_popup{position: absolute;z-index: 9999;padding: 0px 0px;margin-left: 0px;margin-top: 0px;overflow: hidden;word-wrap: break-word;color: black;font-size: 10px;text-align: left;line-height: 130%;} [quote][b]
A&P/IA, EAA Tech Counselor
KCHD |
Tim Olson
Posted: Thu Jan 20, 2011 6:44 am Post subject: voltage regulators/alternator |
What alternator did you get that requires a regulator? Most
of the plane-Power's that people are using are coming
with the built-in regulator and there's very little that
needs to be wired.
Tim Olson - RV-10 N104CD
ACS.
Kelly McMullen
Posted: Thu Jan 20, 2011 7:07 am Post subject: voltage regulators/alternator |
Plane power sells both varieties. Opinions vary about the merits of built-in regulators in an aircraft setting where it is desirable to be able to turn off all alternator output. Depends on your outlook as to who will be fixing any electrical problems after a failure, given that most A&Ps are only familiar with externally regulated alternators that exist on certified planes. The point being internal vs external alternator regulation is to the AeroElectric email list what primer debates are to most OBAM lists like this one.
On Thu, Jan 20, 2011 at 7:41 AM, Tim Olson <Tim(at)myrv10.com (Tim(at)myrv10.com)> wrote:
Quote: | --> RV10-List message posted by: Tim Olson <Tim(at)myrv10.com (Tim(at)myrv10.com)>
needs to be wired.
ACS.
http://forums.matronics.com
le, List Admin.
KCHD |
Kellym
Posted: Thu Jan 20, 2011 7:16 am Post subject: voltage regulators/alternator |
OTOH, Tim maybe correct. Verify which model you have from Plane Power to
see whether it needs external regulator, or if it already has one
built-in. I sorta recall Van's favoring the internally regulated versions.
On 1/20/2011 8:02 AM, Kelly McMullen wrote:
Quote: | Plane power sells both varieties. Opinions vary about the merits of
needs to be wired.
finish
instructions.
Vans site or
ACS.
ball machine.
KCHD |
pilotdds(at)aol.com Guest
Posted: Thu Jan 20, 2011 7:53 am Post subject: voltage regulators/alternator |
The plane power alternator that vans sells is internally regulated and has built in over voltage protection-much simpler wiring,so John, relax.
Strasnuts
Joined: 10 Feb 2009 Posts: 502 Location: Salt Lake City, UT
Posted: Thu Jan 20, 2011 7:54 am Post subject: voltage regulators/alternator |
My planepower from vans has the internal regulator.
On Jan 20, 2011, at 8:14, Kelly McMullen <kellym(at)aviating.com> wrote:
Quote: |
OTOH, Tim maybe correct. Verify which model you have from Plane Power to see whether it needs external regulator, or if it already has one built-in. I sorta recall Van's favoring the internally regulated versions.
> On Thu, Jan 20, 2011 at 7:41 AM, Tim Olson <Tim(at)myrv10.com <mailto:Tim(at)myrv10.com>> wrote:
> needs to be wired.
> do not archive
> finish
> instructions.
> Vans site or
> ACS.
> ball machine.
> John
_________________ 40936
RV-10 SB N801VR Flying
780 Hours
SuperSTOL 60 hours |
Posted: Thu Jan 20, 2011 8:37 am Post subject: voltage regulators/alternator |
You can turn off the Alt Field on the internally regulated alternator just like you would from an externally regulated one, right? If the alternator or regulator fails, you replace it or send it in for repair, or have someone locally repair it if there are still people around that do that. Oh, btw, I use the Akzo Nobel 2-part epoxy primer on all internal parts.
Jesse Saint
Saint Aviation, Inc.
jesse(at)saintaviation.com
C: 352-427-0285
F: 815-377-3694
On Jan 20, 2011, at 10:02 AM, Kelly McMullen wrote:
Quote: | Plane power sells both varieties. Opinions vary about the merits of built-in regulators in an aircraft setting where it is desirable to be able to turn off all alternator output. Depends on your outlook as to who will be fixing any electrical problems after a failure, given that most A&Ps are only familiar with externally regulated alternators that exist on certified planes. The point being internal vs external alternator regulation is to the AeroElectric email list what primer debates are to most OBAM lists like this one.
Posted: Thu Jan 20, 2011 9:07 am Post subject: voltage regulators/alternator |
I am cementing PJC crowns 23-27 and veneer of 22....relax...sho are you kiddding!!!!
Not at home to look at the box, but I do know the alternator has a built in over voltage protection.
Subject: Re: voltage regulators/alternator
Date: Thu, 20 Jan 2011 10:47:49 -0500
dlm34077(at)q.com Guest
Posted: Thu Jan 20, 2011 9:09 am Post subject: voltage regulators/alternator |
yes, I just turn off the W31 5A breaker to shut off the alternator output.
Replacing the integrated diodes,regulator and brushes is a single field
installed part ; cost me about $50. But of course did not solve the problem
in my case.
Tim Olson
Posted: Thu Jan 20, 2011 9:23 am Post subject: voltage regulators/alternator |
If it has built-in OVP, then it's internally regulated. In that
case you don't need a regulator. I understand Kelly's
original statement from that perspective. I was just
basically operating under the understanding that most people
building RV-10's that have Plane-power alternators from Van's,
were getting internally regulated and OVP'd alternators,
and if that were true, you shouldn't have a need to buy
a regulator. The wiring is also dead simple.
The one gotcha I can add....before I did my first flight,
I thought I had an alternator problem. Turns out I didn't
push hard enough on the connector on the rear of the
alternator to click in the connector, and it had come
loose. So, when you connect that connector, make sure you
push it in until you get a definite click.
On 1/20/2011 11:04 AM, John Gonzalez wrote:
[quote] I am cementing PJC crowns 23-27 and veneer of 22....relax...sho are you
kiddding!!!!
Kelly McMullen
Posted: Thu Jan 20, 2011 4:17 pm Post subject: voltage regulators/alternator |
Not on all of them Jesse. Might be okay on Plane Power, don't know for sure. The automotive ones are NOT designed to allow field to be turned off while there is a load on the alternator, and can be substantially damaged by doing so.
There is no such issue or concern on externally regulated, and gives you option of which regulator goes with your choice of primer.
On Thu, Jan 20, 2011 at 9:26 AM, Jesse Saint <jesse(at)saintaviation.com (jesse(at)saintaviation.com)> wrote:
Quote: | --> RV10-List message posted by: Jesse Saint <jesse(at)saintaviation.com (jesse(at)saintaviation.com)>
Jesse Saint
C: 352-427-0285
F: 815-377-3694
le, List Admin.
KCHD |
Posted: Thu Jan 20, 2011 4:47 pm Post subject: voltage regulators/alternator |
I wonder if that's why Van's dropped the automotive alternators from the FWF kit and started using the Plane Power. If you asked them about the earlier alternator, though, they would likely say that they have not heard from any customers about problems with them.
Jesse Saint
C: 352-427-0285
F: 815-377-3694
On Jan 20, 2011, at 7:14 PM, Kelly McMullen wrote:
[quote]Not on all of them Jesse. Might be okay on Plane Power, don't know for sure. The automotive ones are NOT designed to allow field to be turned off while there is a load on the alternator, and can be substantially damaged by doing so.
Jesse Saint
C: 352-427-0285
F: 815-377-3694
le, List Admin.
#avg_ls_inline_popup{position: absolute;z-index: 9999;padding: 0px 0px;margin-left: 0px;margin-top: 0px;overflow: hidden;word-wrap: break-word;color: black;font-size: 10px;text-align: left;line-height: 130%;} [b]
jump2(at)sbcglobal.net Guest
Posted: Thu Jan 20, 2011 5:35 pm Post subject: voltage regulators/alternator |
Mine went out at 67 hrs, bought a plane power and have not looked back. Yes, it did say not to turn the alternator off-on with a load on it. I believe it was in vans info.
Patrick Thyssen
N15PT
--- On Thu, 1/20/11, Jesse Saint <jesse(at)saintaviation.com> wrote:
Date: Thursday, January 20, 2011, 6:45 PM
Jesse Saint
[url=/mc/compose?to=jesse(at)saintaviation.com]jesse(at)saintaviation.com[/url]
C: 352-427-0285
F: 815-377-3694
Quote: | Not on all of them Jesse. Might be okay on Plane Power, don't know for sure. The automotive ones are NOT designed to allow field to be turned off while there is a load on the alternator, and can be substantially damaged by doing so.
On Thu, Jan 20, 2011 at 9:26 AM, Jesse Saint <[url=/mc/compose?to=jesse(at)saintaviation.com]jesse(at)saintaviation.com[/url]> wrote:
Quote: | --> RV10-List message posted by: Jesse Saint <[url=/mc/compose?to=jesse(at)saintaviation.com]jesse(at)saintaviation.com[/url]>
Jesse Saint
C: 352-427-0285
F: 815-377-3694
le, List Admin.
#yiv453473072 #yiv453473072avg_ls_inline_popup{padding:0px 0px;margin-left:0px;margin-top:0px;overflow:hidden;word-wrap:break-word;color:black;font-size:10px;text-align:left;line-height:130%;} D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D |
| [quote][b]
Kellym
Posted: Thu Jan 20, 2011 6:14 pm Post subject: voltage regulators/alternator |
Is there any other script in the tech support room?
On 1/20/2011 5:45 PM, Jesse Saint wrote:
Quote: | ** If you asked them about the earlier alternator, though, they would
with them.
Jesse Saint
jesse(at)saintaviation.com <mailto:jesse(at)saintaviation.com>
C: 352-427-0285
F: 815-377-3694
KCHD |
Tim Olson
Posted: Thu Jan 20, 2011 6:25 pm Post subject: voltage regulators/alternator |
"Just build the plane!"
> ** If you asked them about the earlier alternator, though, they would likely say that they have not heard from any customers about problems with them.
> Jesse Saint
> C: 352-427-0285
> F: 815-377-3694
