grosseair(at)comcast.net Guest
Posted: Tue Jan 18, 2011 6:36 pm Post subject: Buss Bar |
I know copper is generally used, but is there any reason NOT to use
aluminum to construct a ground buss bar?
John Grosse
Posted: Tue Jan 18, 2011 7:06 pm Post subject: Buss Bar |
At 09:27 PM 1/18/2011, you wrote:
How do you plan to attach wires to it?
The bus bar designs suggested by AeroElectric
Connection and B&C products go to some lengths
to reduce threaded fasteners to a minimum. There
are none on the panel ground bus . . . and only
the fat wires are brought to threaded studs.
Posted: Wed Jan 19, 2011 6:25 am Post subject: Buss Bar |
A combination of threaded studs for the large wires and riveted fast on
connectors for the rest.
Robert L. Nuckolls, III wrote:
<nuckolls.bob(at)aeroelectric.com>
> <grosseair(at)comcast.net>
Float Flyr
Posted: Wed Jan 19, 2011 7:44 am Post subject: Buss Bar |
I was also thinking... you may also be able to find a nicopress crimper the
right size to close the lugs.
Noel
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
Posted: Wed Jan 19, 2011 8:36 am Post subject: Buss Bar |
At 09:15 AM 1/19/2011, you wrote:
| Quote: | --> AeroElectric-List message posted by: John Grosse <grosseair(at)comcast.net>
A combination of threaded studs for the large wires and riveted fast on connectors for the rest. |
Rivets are designed for use in shear, not in tension.
Further, your fast-on lugs are no doubt going to be
of a material dissimilar to the bus bar.
Suggest you go to a hardware store or hobby shop
and get a chunk of sheet brass or better yet copper.
Roofing companies often have scraps of copper flashing
around from which you can get a suitable piece. Also
check around on Ebay.
http://tinyurl.com/5sa26kp
Here's a nice chunk of .062" sheet that you can
shear up for what you need and offer lots of similar
chunks to other builders.
Use copper pop-rivets to fixture the fast-on
lugs and then solder using electronic 63/37
solder.
There are ways to do the best we know how to
do at minimal time and dollars but bolting up
an array of terminals on a piece of aluminum is
not the best we know how to do.
Bob . . . [quote][b]
Posted: Fri Jan 21, 2011 5:10 pm Post subject: Buss Bar |
Bob, I'm not quite sure I understand. Are you saying that aluminum is
unsuitable for some reason or just that copper or brass is better? I'm
not questioning your opinion. I'm just interested in the "why" one works
or doesn't work.
* http://tinyurl.com/5sa26kp*
solder.
Bob McC
Posted: Fri Jan 21, 2011 8:05 pm Post subject: Buss Bar |
Different Bob here, but---
What Bob is saying is that first of all it's very difficult to keep aluminum
clean enough for a good "gas tight" connection as it oxidizes almost
instantly after it is cleaned and aluminium oxide is an excellent insulator.
Secondly the assembly method you are proposing using rivets is unsuitable
because a rivet is not designed to provide the tension in a joint which you
require to get the necessary "gas tight" joint. Rivets are designed to be
loaded in shear. Thirdly the dissimilar metals in your connections will
almost certainly result in galvanic corrosion within the joints when you
join the copper wires/lugs/bolts to the aluminium bars. Where and when
aluminium is used for current carrying purposes great pains are taken to
alleviate the above issues through the use of special compounds within the
joints, such as Burndy's penetrox. (see http://tinyurl.com/4gnx4q7) The
above factors are why the attempt to use aluminium wires for household
wiring in the 60's was such a failure and resulted in many homes burning
down. The difficulties in getting reliable joints are significant whereas
using copper or brass there are no such problems.
Bob McC
[quote] --
_________________ Bob McC
Falco #908
(just starting) |
Posted: Sat Jan 22, 2011 6:45 am Post subject: Buss Bar |
Thanks, Bob. I get it.
Bob McCallum wrote:
Bob McC
aerobubba(at)earthlink.ne Guest
Posted: Sat Jan 22, 2011 7:00 am Post subject: Buss Bar |
Along the same timeframe that aluminum was being tried in house wiring, it
was also being used in some diesel locomotives. In that application, the
failure produced what were likely some of the world's highest wattage arc
lights. Unlike the housing industry, the nature of that beast is such that
the failures caused little collateral damage. Over time, those
installations were replaced with copper.
Glen Matejcek
ftyoder(at)yoderbuilt.com Guest
Posted: Sat Jan 22, 2011 3:11 pm Post subject: Buss Bar |
In the late 60's I was working for Kaiser Aluminum when one of their
engineers successfully bonded copper bar to aluminum bar stock. This was a
great cost saver in the aluminum manufacturing plants when sending the high
voltage from the power plant to the furnace.
I didn't work in that area and I don't know how successful it was in
practice.
Do not archive.
Posted: Sat Jan 22, 2011 3:46 pm Post subject: Buss Bar |
At 06:08 PM 1/22/2011, you wrote:
<ftyoder(at)yoderbuilt.com>
was a great cost saver in the aluminum manufacturing plants when
sending the high voltage from the power plant to the furnace.
I didn't work in that area and I don't know how successful it was in practice.
actually, there's a class of copper clad aluminum
wire used to make up large bundles of high current
conductors. Eric Jones offers some light-weight
alternatives to the 2 and 4 awg all copper choices.
http://www.periheliondesign.com/fatwires.htm
I've played with this stuff and for all practical
purposes it solders and crimps like copper wire
but without the dissimilar metal issues. The
wire is also much finer strands than those wires
used in early attempts to "aluminize" the fat
wires in airplanes. This makes the wire much
more flexible and resistant to stress cranking
under flexure.
I think Hawker Beech is using some copper clad
aluminum on the production line. So yes, I believe
bus bars made primarily of aluminum with copper
connecting surfaces fused to the aluminum would
have been quite practical.
