Posted: Wed Jan 26, 2011 8:47 pm Post subject: lan tracer |
At 10:01 PM 1/26/2011, you wrote:
Quote: | hi all,
anyone have any experience with a wire tracer that they can recommend one? under $ 60 i hope.
bob noffs |
How about these?
http://tinyurl.com/49bj2pa
http://tinyurl.com/4hnlvvh
Bob . . . [quote][b]
icubob(at)gmail.com Guest
Posted: Thu Jan 27, 2011 5:02 am Post subject: lan tracer |
thanks bob,
anyone have a tracer they can recommend? one of the trackers on this wedsite is the one i bought [one with long black antenna] from harbour freight. purely worthless. when i called the tech guy to make arrangements to ship it back he ''checked something'' then came back on the phone and said just toss it and he would give me credit. on my card. also, the gb i have been looking at is on one of these sites at a great price but i have read that it works and that it doesn't. any feedback from a trusted aerolectric follower would be appreciated.
bob noffs
On Wed, Jan 26, 2011 at 9:42 PM, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
[quote] At 10:01 PM 1/26/2011, you wrote:
bob noffs |
How about these?
Bob . . . Quote: |
ist" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List
ttp://forums.matronics.com
Posted: Thu Jan 27, 2011 7:12 am Post subject: lan tracer |
that it doesn't.
You could build one. They function based on the
simple-ideas that drive the occasional need for
shielded wire. Electro-Static Coupling.
The 'transmitter' is usually a two-transistor
multi-vibrator or perhaps an IC audio amplifier
set up as an oscillator. The goal is to generate
a square-wave at about 400-1000 hz that has
VERY fast rise and fall times. In other words,
very high harmonic content. A 9v battery, two
transistors, 4 resistors and 4 capacitors would
do the trick.
The receiver is nothing more than a high gain
audio amplifier with a capacitive probe . . .
a metallic tip that can be placed in close
proximity to the wire ends being explored
for 'continuity'.
Capacitive coupling through the insulation
of the excited wire will come across as the
400-1000 Hz audio note. In fact, your probe is
really detecting the much higher frequency
harmonics that couple across the insulation
modulated at the audio rate.
Failure to function for any such product can
be a combination of factors. Edges of the
square wave are too slow. Amplifier in probe
is too low in gain. Receiver electronics poorly
shielded for the effects of other noises not
impressed through the probe.
These things appear really easy to make work
and they are. But it's a bit like learning
to make biscuits. Just having the ingredients
and a rough notion of how they go together
is not a recipe for success. There are
subtle but critical design goals to be
met.
I've seen some chatter on the DIY sites
suggesting that a transistor AM pocket radio
can be jeeped into a really good detector.
The transistor oscillator isn't a big deal
either.
jonlaury
Posted: Fri Jan 28, 2011 8:39 am Post subject: Re: lan tracer |
Try www.allelectroincs.com , cat#28, $12
Bob McC
Posted: Fri Jan 28, 2011 10:41 am Post subject: lan tracer |
John;
Check the link you posted. It leads to a website phishing for cell phone
numbers.
I suspect that when you wrote "allelectroincs" you might have meant
"allelectronics", but catalogue #28 does not appear to exist on their
website and all of their part numbers appear to consist of an alpha prefix
followed by a dash and then a number. There do not appear to be any numbers
fitting your posting.
Please clarify.
Bob McC
[quote] --
_________________ Bob McC
Falco #908
(just starting) |
jonlaury
Posted: Sat Jan 29, 2011 8:08 am Post subject: Re: lan tracer |
Quote: |
PostPosted: Fri Jan 28, 2011 10:41 am Post subject: lan tracer
John;
numbers. |
After fixing my typo "allelectroIncs", http://www.allelectronics.com/ pops the website right up for me. Sorry about the Part #... should have been CT-28. I put it in the search box and it goes right to it ready to buy and check out.
Do not Archive
Bob McC
Posted: Sat Jan 29, 2011 8:55 am Post subject: lan tracer |
Thanks John;
The missing "CT" was the last part of the puzzle. The URL typo was fairly
easy to surmise.
Bob McC
[quote] --
Falco #908
(just starting) |
