		gentryll
				 Posted: Sun Jan 30, 2011 3:13 pm    Post subject: Kitfox IV Stall Speeds |
				I have a Model IV with a Subaru.  It is light for a Subaru at around 630 lbs. During initial testing I am getting power off and up to 2000 rpm, stall speeds of around 50 mph, and  with flaps around 45. I checked airspeed indicator against GPS and speeds are good. I was expecting a lot less.  I have about 38 lbs. on the tailwheel.  Is this normal or have I done something wrong.  I can still land and take off very short.  It just looks bad, when I can fly lower than my indicated stall speed.
  |  | - The Matronics Kitfox-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		Guy Buchanan
				 Posted: Sun Jan 30, 2011 3:50 pm    Post subject: Kitfox IV Stall Speeds |
				On 1/30/2011 3:13 PM, gentryll wrote:
  	  | Quote: | 	 		   I checked airspeed indicator against GPS and speeds are good. I was expecting a lot less.  I have about 38 lbs. on the tailwheel.  Is this normal or have I done something wrong.
 Hi,
      Moderator here again asking you to please include your full name,
 location, and aircraft type / status in your signature. It makes us much
 more friendly.
      Your stall speeds sound about right. I've got a IV with a 582 and
 it stalls 40/45 mph. Your engine is a lot heavier so I'd expect the
 stall to be higher. (My empty weight is about 620# and my CG is at the
 aft limit.)
 Guy Buchanan - List moderator
 Ramona, CA
 Kitfox IV-1200 / 592-C / Warp 3cs / 500 hrs. and grounded
Deceased K-IV 1200
A glider pilot too. |
		helili(at)chahtatushka.ne Guest
				 Posted: Sun Jan 30, 2011 3:57 pm    Post subject: Kitfox IV Stall Speeds |
				My KF-IV with a NSI Subaru and prop stalls at around 4o-45 mph indicated
 clean.  I am sure that figure is incorrect because of the high angle of
 attack, which causes some angular airflow across the pitot tube inlet rather
 than directly into it, and the inherent inaccuracy of airspeed indicators at
 low speeds.  Each airspeed indicator installation varies somewhat from
 aircraft to aircraft.  Some of the variables are such things as where the
 static port is located, whether static source is just cabin air and so on.
 I have my static source, which is on the pitot tube, plumbed in to the
 airspeed indicator, VSI, and transponder altitude encoder.
 John Hart
 KF-IV
 Wilburton, OK
		lcfitt(at)sbcglobal.net Guest
				 Posted: Sun Jan 30, 2011 5:10 pm    Post subject: Kitfox IV Stall Speeds |
				My first Model IV stalled at 43.  That is indicated.  I think the mention of
 pitot tube angle might be an error producer - though I logic tells me that
 with an angled pitot, it would likely read low rather than high.  Did you do
 your AIS calibration at speed or in a slow flight configuration mimicking
 the angle you would find near stall?  I calibrated my ASI with a water
 manometer once and found that at 60 mph it was spot on, but fudged upward at
 high speeds - that allowed me to brag about my cruise speeds, and low at
 lower speeds giving the same bragging rights there as well.  Whatever the
 stall speed is, though, at 630 with an auto conversion, you most certainly
 did something right.
 Lowell Fitt
 Kitfox IV-1200 Gone West
 Kitfox IV-1200 Close
 Cameron Park, CA
 Sent: Sunday, January 30, 2011 3:13 PM
 Subject: Kitfox IV Stall Speeds
  http://forums.matronics.com/viewtopic.php?p=329022#329022
		dave
				 Posted: Sun Jan 30, 2011 5:22 pm    Post subject: Re: Kitfox IV Stall Speeds |
				My IV  empty  550 lbs.
 stall  37 - 38 mph
 Check my  videos  I will post in a day or two  doing stalls
  _________________ Realtime Kitfox movies to separate  the internet  chatter from the truth
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
		Av8r3400
  Joined: 22 Sep 2008 Posts: 83 Location: North Central Wisconsin (KRRL)
				 Posted: Sun Jan 30, 2011 6:27 pm    Post subject: Re: Kitfox IV Stall Speeds |
				My IV-1050 is about 635# empty with a 912 on the nose.  Clean stall, solo with half fuel is indicated at ~42 mph, with flaps down around 37 mph.  Your forward CG may add some to your stall speed, along with ASI error.
 But, 630# with a Subaru is just this side of a miracle!  That's great!  You did good!
  _________________ Thanks,
Av8r3400
Kitfox Model IV-1200 W/912UL & IVO
Kitfox Model IV-1050 W/912UL & Warp
YouTube Videos |
		gentryll
				 Posted: Sun Jan 30, 2011 7:11 pm    Post subject: Re: Kitfox IV Stall Speeds |
				 	  | gentryll wrote: | 	 		  | I have a Model IV with a Subaru.  It is light for a Subaru at around 630 lbs. During initial testing I am getting power off and up to 2000 rpm, stall speeds of around 50 mph, and  with flaps around 45. I checked airspeed indicator against GPS and speeds are good. I was expecting a lot less.  I have about 38 lbs. on the tailwheel.  Is this normal or have I done something wrong.  I can still land and take off very short.  It just looks bad, when I can fly lower than my indicated stall speed. |
 Thanks guys, that makes me feel better already.  The GPS corroborates my AIS so the speed is accurate.  I saw the numbers in the operating manual for a 582 and a 912 and noticed mine were much higher , and that made me worry.  Do you guys try to three point with power all the way off or keep it up a bit to keep some air moving across the elevators.  With the NSI gearbox at I think 2.27/1 ratio,  very little air from the prop is moving across the elevators at idle.
 Larry Gentry
 Kitfox IV
 Crawford, ms.
		Guy Buchanan
				 Posted: Sun Jan 30, 2011 11:19 pm    Post subject: Kitfox IV Stall Speeds |
				On 1/30/2011 7:11 PM, gentryll wrote:
  	  | Quote: | 	 		   Do you guys try to three point with power all the way off or keep it up a bit to keep some air moving across the elevators.  With the NSI gearbox at I think 2.27/1 ratio,  very little air from the prop is moving across the elevators at idle.
 Larry,
      Thanks for putting in the signature. It's much nicer calling you by
 name.
      I can three point full flaps at idle, but I had to gap seal the
 elevator to do it. Otherwise I was limited to partial flaps, three
 point, at idle. Of course, I rarely three point anymore.
 Guy Buchanan
 Ramona, CA
Deceased K-IV 1200
		dave
				 Posted: Mon Jan 31, 2011 1:39 am    Post subject: Re: Kitfox IV Stall Speeds |
				Power off stall  -- no flaps  video
 http://www.youtube.com/watch?v=XcAUa5DjxuE
 I would not depend on ASI to give accurate stall speed.
 I know by GPS mine is 37 to 38  mph.
 1/2 Flaps will cut it by about 1 - 2 mph, if that.
 This Kitfox has Vgs which makes the stall almost just a mush.
 Enjoy.
		Tom Jones
  Joined: 12 Mar 2006 Posts: 752 Location: Ellensburg, WA
				 Posted: Mon Jan 31, 2011 5:52 am    Post subject: Re: Kitfox IV Stall Speeds |
				Classic 4.  Gross weight 795 pounds stall full flaps = 36 MPH, Clean = 38 MPH.  Gross weight 1050 stall full flaps 42 MPH, Clean = 46 MPH.
  	  | Quote: | 	 		  | Do you guys try to three point with power all the way off or keep it up a bit to keep some air moving across the elevators. |
 Power off three point full stall landing.  http://vimeo.com/12693781
  _________________ Tom Jones
Classic IV
Ellensburg, WA |
		Fox5flyer Guest
				 Posted: Mon Jan 31, 2011 9:35 am    Post subject: Re: Kitfox IV Stall Speeds |
				That is a very light IV/Soob so you must have been paying very close attention to weight during building.  Good job.  As for the stall speeds, I wouldn't worry too much about what the AS reads as they can be very inaccurate at lower speeds.  Also, comparing it with the GPS is not very helpful as AS reads airspeed and GPS reads ground speed which means that they are rarely the same when flying.  You will hear stall speeds all over the map with some way too low to believe and many others close to what yours is.  The thing to remember is to just know what your AS reads at stall and don't worry about how accurate it is.  The number is all that really matters.
 Good luck,
 Deke Morisse
 S5/NSI/500TT
 NE Michigan
		Fox5flyer Guest
				 Posted: Mon Jan 31, 2011 9:42 am    Post subject: Re: Kitfox IV Stall Speeds |
				 	  | gentryll wrote: | 	 		   	  | gentryll wrote: | 	 		  | I have a Model IV with a Subaru.  It is light for a Subaru at around 630 lbs. During initial testing I am getting power off and up to 2000 rpm, stall speeds of around 50 mph, and  with flaps around 45. I checked airspeed indicator against GPS and speeds are good. I was expecting a lot less.  I have about 38 lbs. on the tailwheel.  Is this normal or have I done something wrong.  I can still land and take off very short.  It just looks bad, when I can fly lower than my indicated stall speed. |
 Larry Gentry
 Kitfox IV
 Crawford, ms. |
 Do you have your battery in the rear above the tailwheel?  The Soob is heavy and unless you added some sort of ballast it is pretty much necessary to put the battery there to keep the CG far enough back to make a decent tail wheel landing.
 Deke Morisse
 S5/NSI Soob /500TT
 NE Michigan
 Big snow on the way
		Lynn Matteson
				 Posted: Mon Jan 31, 2011 2:55 pm    Post subject: Kitfox IV Stall Speeds |
				That's so good I would suspect the scales....and I'm only half
 kidding. This is based on my Jabiru-powered IV weighing in at
 650....with calibrated aircraft scales.
 Lynn Matteson
 Jabiru 2200, #2062
 Sensenich 62"x 55.5 Wood (winter) until the Prince prop arrives
 Rotec TBI-40 injection
 Status: flying...1081 hrs (since 3-27-2006)
 On Jan 30, 2011, at 9:27 PM, Av8r3400 wrote:
     (snip)
  	  | Quote: | 	 		   But, 630# with a Subaru is just this side of a miracle!  That's
  Av8r3400
  _________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
