		ospreysammy
				 Posted: Sun Jan 30, 2011 4:58 am    Post subject: Duckwork HID lights |
				I am currently at the point of finishing up the outboard leading edges and I plan on using the Duckworks HID landing light system. This has led me to two questions; first since they are so bright, is one in each wing needed or would one in the left only work? I am thinking only using one would reduce weight, complexity, electrical load but would add asymmetry. Second question is, do I need to wait to rivet the outboard rib until the light kit is done? I looked through Tim's outstanding writeup of his installation (thank you Tim) and it seems it may be easier to do the light kit with that outboard rib removable. Any insight from experience would be appreciated. Thanks in advance.
  _________________ Sam Clark
Builder # 40972 |
				 Posted: Sun Jan 30, 2011 9:21 am    Post subject: Duckwork HID lights |
				Sam I am a big proponent of dual HID’s and the Wig/Wag function. I have had sooooo many comments from tower controllers & commercial airlines on how visible my -10 is in wig/wag mode that I would not minimize my lighting situation. Furthermore I have each light set up at slightly different angles so I get excellent coverage in most phases of landing/flair.
 As far as electrical load I have dual G900X screens, Back Up Dynon D100, dual 16 Watt Coms, plus the usual Transponder, Audio etc… and a lot of other odds & ends electronics and my 60A total never gets above something like 23 in flight including while running the HID’s.
 Robin
  From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) [mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)] On Behalf Of ospreysammy
  Sent: Sunday, January 30, 2011 4:58 AM
 Subject: Duckwork HID lights
 --> RV10-List message posted by: "ospreysammy" <helosammy(at)gmail.com (helosammy(at)gmail.com)>
 Sam Clark
 Builder # 40972
 http://forums.matronics.com/viewtopic.php?p=328966#328966
   as List Un/Subscription,
  //www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List
  ttp://forums.matronics.com">http://forums.matronics.com
 Checked by AVG - www.avg.com
 Version: 10.0.120
		Tim Olson
				 Posted: Sun Jan 30, 2011 9:46 am    Post subject: Duckwork HID lights |
				Sam, I posted this reply as part of a different thread today
 when I was lazy and just had my iphone handy.
 "The other one is cutting the holes for the Duckworks lights.  You don't
 have to even use lights, but for resale and construction reasons I would
 recommend that basically every builder cut the hole in each wing if they
 think there will EVER be a chance they sell the plane.  Most buyers
 would be used to seeing wing lights and they will want them, and cutting
 them later will wreck the paint.  So just cut them initially and then
 decide later what to put in there.  The wing is still the only location
 that doesn't come with some sort of compromise."
 I'll expand a bit now that I'm at my regular PC.
 I would at LEAST cut the hole on the 2nd wing. Don't skip it and
 then find out after the fact that you aren't 100% happy.  You can
 get OK lighting I'm sure with just 1, but 2 will give very good
 even lighting and even if you only put in 1 for the first couple
 years, I'd be prepared to put in a 2nd light.  You'll be happier
 later.  It's a real simple install to cut the hole, and no
 fiberglass involved.
 Regarding power draw, the total draw is something like 3A per HID
 for me after they start up.  That's WAY less than normal landing
 lights. My old plane had a single 20A light....and you could
 go halogen for 10A.  I can do 2 lights that are 3x as bright
 as the single halogen, and still be at 2/3 the power draw. You
 won't be disappointed in HIDs.  There are some recent LED lights
 that are starting to approach HID's in intensity, however they
 are also starting to approach HID's for power draw as well, and
 they cost more.  Over time, we may see LED's be a good option
 if the price decreases to the point where they are lower
 than HID's for the same brightness.
 With the holes cut, you could install even the mini lamps in
 the wings if you wanted.  You may not get the performance, but
 at least the hole is cut.
 My total panel draw with everything on, including all lights,
 is under 40 or 42A.  So no matter what you do, you're going
 to have it better off than many previous aircraft had it.
 Heck, I think my old Nav Lights had 7A bulbs in them...you
 won't be needing that.
 As for that outer rib, I don't know that it matters a lot
 if you rivet it or not.  I think you could go either
 way.  You're working in the outer bay of the wing, so
 nothing is too hard to get at.
 On 1/30/2011 6:58 AM, ospreysammy wrote:
  Thanks in advance.
  -------- Sam Clark Builder # 40972
		larkrv10(at)yahoo.ca Guest
				 Posted: Sun Jan 30, 2011 7:05 pm    Post subject: Duckwork HID lights |
				Sam, I've only bought and are about to install one Duckworks light, for the left wing.  Having said that I don't like night flying and avoid it when possible, so I don't expect to use it a lot.  Also you can always install another after the aircraft is flying if you plan accordingly.  I do know one will be much brighter than the 2  lights in my Cessna Cardinal.
  Rick
  #40956
  Southampton, Ont
 --- On Sun, 1/30/11, ospreysammy <helosammy(at)gmail.com> wrote:
 Received: Sunday, January 30, 2011, 12:58 PM
 Sam Clark
 Builder #  40972
    --> http://www.matronics.com/Navigator?RV10-List
 great content also available via the Web nbsp;                   -Matt matronics.com/contribution" target=_blank>http://www.matronics.com/contri================
				 Posted: Sun Jan 30, 2011 7:24 pm    Post subject: Duckwork HID lights |
				Again with my Wig/Wag HID’s I get noticed 7 miles out on approach in the day time. Dual flashing HID’s may be one of the best safety vs. cost items on your build. Seeing is avoiding.
 Robin
  From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) [mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)] On Behalf Of Rick Lark
  Sent: Sunday, January 30, 2011 7:03 PM
 Subject: Re: Duckwork HID lights
 Rick
 #40956
 Southampton, Ont
 --- On Sun, 1/30/11, ospreysammy <helosammy(at)gmail.com (helosammy(at)gmail.com)> wrote:
   = the many List utilities such as List Un/Subscription,[/b][/quote][/b][/quote] matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List[/b][/quote] =================[/b][/b][/quote] http://forums.matronics.com[/b][/quote] =================[/b][/b][/quote]                            -Matt Dralle, List Admin.[/b]http://www.matronics.com/contribution[/quote] =======================[/b] [/quote]
 Version:body>  [quote][b]
		Eric_Kallio
  Joined: 29 Jan 2006 Posts: 149 Location: Baton Rouge, LA
				 Posted: Mon Jan 31, 2011 6:39 pm    Post subject: Re: Duckwork HID lights |
				I have 2, although not wig-wags. I installed them after completing the leading edges with no problems. As long as they are off of the airplane I had no issues at all with access.
 Eric Kallio
				 Posted: Mon Jan 31, 2011 7:49 pm    Post subject: Duckwork HID lights |
				Sam, as Robin states, you can't beat the HID's for recognition distance/brightness.
  I'm a little concerned about wig-waging the HID's so I am going to use the wing tip halogen lights as wig/wags.  If they don't perform as I hope, I can always change my lighting configuration.
  I expect this aircraft will evolve as I fly it and I will need something to mess around with when I'm not flying anyway.  As everyone knows, that's the beauty of an experimental......
  Rick
  #40956
  Southampton, Ont
 --- On Tue, 2/1/11, Eric_Kallio <scout019(at)msn.com> wrote:
 Received: Tuesday, February 1, 2011, 2:39 AM
  --> RV10-List message posted by: "Eric_Kallio" <scout019(at)msn.com (scout019(at)msn.com)>
 Eric Kallio
 http://forums.matronics.com/viewtopicht="http://forums.matronics.com/" target=_blank>http://forums.matronics.c                     &nbsf="http://www.matronics.com/contribution" =======
		ospreysammy
				 Posted: Tue Feb 01, 2011 5:49 pm    Post subject: Re: Duckwork HID lights |
				Thanks all for the insight and advice. I went ahead and ordered two, I can't argue with the safety of being seen. I have crossed paths with quite a few light civil aircraft and some were closer than I would like before they were seen. Thanks again.
Builder # 40972 |
		william(at)gbta.net Guest
				 Posted: Tue Feb 01, 2011 6:16 pm    Post subject: Duckwork HID lights |
				While we're talking about Duckworks lights, I know Tim suggests using the
 35W D1S bulbs.  Vans only has the 50w HID's on their website catalog.  Are
 they the D1S style also or do we need to order directly from Duckworks?
 Sent: Tuesday, February 01, 2011 7:49 PM
  Sam Clark
  Builder # 40972
  http://forums.matronics.com/viewtopic.php?p=329252#329252
