Icom A210 Wiring Q..
chris Sinfield
PostPosted: Sat Feb 05, 2011 2:37 am    Post subject: Icom A210 Wiring Q.. Reply with quote
Hi everyone.
I am wiring up my 2 seater plane and have a few Q's after reading all the info.
I will just use the internal 2 place hot mic intercom system. The wiring diagram has an external intercom switch. Do I still need it and what is it for?
Also there are 2 options for the rear radio connection. A 30 pin molex or a 15 pin D sub.
What have people been using to connect to? Pros and cons?
I want to use the 3 audio inputs and can not see how I can do this with the D sub and without a separate intercom box.
Also it calls for a 10 Amp CB not a fuse? is this so if you get a hot TX mic you can pull the CB?? the Aero Electric connection guide only a 5 amp fuse for the Icom 200/A210?? Am I missing somthing?
Chris..
mdnanwelch7(at)hotmail.co
PostPosted: Sat Feb 05, 2011 6:08 am    Post subject: Icom A210 Wiring Q.. Reply with quote
 > I will just use the internal 2 place hot mic intercom system. The wiring diagram has an external intercom switch. Do I still need it and what is it for?
Also it calls for a 10 Amp CB not a fuse? is this so if you get a hot TX mic you can pull the CB?? the Aero Electric connection guide only a 5 amp fuse for the Icom 200/A210?? Am I missing something?
Chris..
Hi Chris,
  A few months ago, I asked many of the same questions to this list.  I think it was Bob N.
that suggested the DB15 plug.  I am very pleased with the plug for a connection.
  I also wondered about using the internal intercom in my Icom A200.  Some guys said
they weren't especially thrilled with the internal intercom, and I would be better off with
a separate panel mount one.
  Although I didn't have a panel mount intercom, I did have a portable SoftComm intercom,
and made a rectangular hole for it in my console.  For the most part, it looks like a built-in
model, and what is really nice is, it has all the plug receptacles and so forth already available.
  I simply took it apart and added a few wires for the things I needed to convert it to panel
mount style.  Wires like: positive and negative "hot", so that I didn't need the 9 volt battery,
Icom hookup wires, and I added the Dynon audio alarm signal to one of the "audio in" locations.
(as per the SoftComm tech guy's approval).
  After I got the whole arrangement finished, I'm very pleased with the results!  The DB15 plug
is the perfect choice, the separate intercom allows for more control of intercom functions ( I
believe), and any additional audio requirements like alarms, music, etc. are very easy to add.
  Regarding the circuit breaker, the Icom installaion is not real clear.  One place says 10A,
then another refers to 5A. (or some kind of confusion like that).  I think I called Icom, but in
any event, I went with the 5A breaker.  I think it was in the Icom's specs where it says it's
maximum current was around 2 amps.  I have mine hooked up to a 5A breaker, but I seem to
recall someone on this list said a 10A breaker would hurt.  I'd just go with 5.
  BTW, there are a few intercom companies that I found that have wiring diagrams for
their particular intercom models to hook up to various aircraft comm radios.  Sigtronics
is one that I know of.  I used their wiring diagram to coach me through the SoftComm wiring
points.  Once I felt like I had everything figured out, I called and verified I was on the right path
with SoftComm.  Worked perfect on the initial test!!!
Mike Welch
PostPosted: Sat Feb 05, 2011 7:52 am    Post subject: Icom A210 Wiring Q.. Reply with quote
At 05:37 AM 2/5/2011, you wrote:
<chris_sinfield(at)yahoo.com.au>
and what is it for?
The manuals are not helpful as to the function of this
switch. With a voice activated intercom, you don't need
the press-to-talk button associated with hot-mike intercoms.
However, I would suggest you bring some wires out
for this switch and then explore what it does after
you've got it up and running. It may be a handy way
to turn the intercom function OFF . . . which could
be handy if you're busy talking to controllers and you
don't want inadvertent conversation from the right seat
passenger to go out on the radio.
For all of ICOM's expertise in electronics, their
manuals leave some things to be desired. Perhaps
somebody here on the List has explored the function
of that switch and can advise you.
As Mike pointed out, the D-Sub is much preferred . . . .
but it does not exactly parallel the Molex connnector
for wire functions. If you need ANY of the wires in
the Molex connector for your installation, then
you're pretty much stuck with that connector. It's
not a "bad" connector but the D-sub is much "better".
Aha! you've discovered the missing wires in the D-sub.
If you want to use the internal audio isolation amplifier
you'll need to use the Molex.
No, that 5A fuse call out in my drawings is an artifact
from having produced a wiring diagram for the MicroAir
760. The manuals for the ICOM call out 5A max draw in
transmit, so you need to up size to 7A fuse, or 10A or
what ever. Remember, fuses and breakers protect wires.
A long as they're matched to the wire large enough to
avoid nuisance trips, then you're good to go.
I need go fix that drawing . . . which is about 10
years old. I'm going to up size to 7A fuse. I AM a bit
disappointed that you're the FIRST to have brought it
to my attention. Thanks!
PostPosted: Sat Feb 05, 2011 11:14 am    Post subject: Icom A210 Wiring Q.. Reply with quote
At 11:14 AM 2/5/2011, you wrote:
Hello Chris
I have recently installed a A210 in my Kitfox. I just wired in a
push button switch (like a PTT) to the intercom switch wires. One
push and it either connects or disconnects the intercom. Works great
for a noisy cockpit like mine.
So if I interpret your words correctly, this button
is a push-enable/push-disable control for the intercom.
An when the intercom is enabled, it functions as the
legacy voice-activated intercom with adjustable squelch
levels. Does this sound right?
Thanks! Good data point.
PostPosted: Sat Feb 05, 2011 7:52 pm    Post subject: Icom A210 Wiring Q.. Reply with quote
At 05:13 PM 2/5/2011, you wrote:
Hello Bob
That`s right. First I had a ordinary off/on toggle switch, but I
found that it had to toggled both ways each time in order to
activate or deactivate the intercom. Now I just push the switch
once. I mounted the switch up next to the radio so either side can
activate. For my noisy cockpit I have the intercom shut off always
unless conversing with a passenger.. It is also possible to
connect/disconnect on the radio but this requires finding the
function on the menu. Switch,much more convenient.
Great data point. I which the manual was more
clear on this.
