jan_de_jong(at)casema.nl Guest
Posted: Mon Jan 31, 2011 9:48 am Post subject: Shorai LiFePO4 |
Check out "Shorai".
New light weight Japanese LiFePO4 battery with quite enthousiastic
motorcyclist customers.
Works well enough at low temperatures.
Max. charging current 18A (no external shunts). Higher ratings coming.
Has a 5 pin plug that I suspect may give access to the 4 cells.
For our use I might want to monitor max. cell voltage to see <4V or
interrupt charging.
Jan de Jong
klehman(at)albedo.net Guest
Posted: Sun Feb 06, 2011 3:25 pm Post subject: Shorai LiFePO4 |
There is lots of info on how great these things are and little on the
downside. Unfortunately the following link makes the chemistry sound
unsuitable for an airplane.
manuals.hobbico.com/hca/lifesource-manual-v2.pdf
Ken
On 1/31/2011 12:16 PM, Jan de Jong wrote:
<jan_de_jong(at)casema.nl>
Check out "Shorai".
interrupt charging.
Jan de Jong
Posted: Mon Feb 07, 2011 4:31 am Post subject: Shorai LiFePO4 |
Hi Ken,
Re http://manuals.hobbico.com/hca/lifesource-manual-v2.pdf
It sure sounds ominous.
Let me think of some reasons why it may be too ominous.
- the hobbico batteries regularly crash to earth - it is part of their job
(in a real airplane a battery would crash at most once and even then be
more protected as part of a larger object;
thanks to its light weight it may well stay in its designated place too;
if it is not physically damaged there is no danger; the chemistry needs
more than 900 'C to burn)
- the hobbico batteries are composed of random cells of the same manufacture
(the Shorai battery cells may be designed/manufactured/selected to be
part of the same battery)
- the hobby user may be suspected of not appreciating the energy
contained in so light a package
(we do a one-time carefully considered installation with switches and
contactors all around)
- a cya component
My concern is mostly whether in our normal use where we keep our
batteries generally fully charged with something close enough to the
required CC/CV regime the cells of a LFP battery will over time always
converge in state of charge.
It will be interesting to see how the motorcyclists will be doing with that.
Jan de Jong
Posted: Tue Feb 08, 2011 8:17 am Post subject: Shorai LiFePO4 |
thanks Jan
My outstanding concern is what is the worst case risk of rupturing a
cell after extended times (occasionally 8 hour days) at 14.5 volts with
no cell balancing? It sounds like a ruptured cell could be bad news. If
that was not a concern then I'd be willing to experiment with some
equalization and temperature monitoring for long x-country flights if
that substantially extended the service life. My batteries sit between
my rudder pedals. I need electricity to keep the engine running but
aircraft integrity and breathable air to keep me running is even more
important.
I will be watching the motorcycle experience as well. Life expectancy is
not a concern for me to try them but failure modes definitely are.
Please keep posting any further info.
Ken
On 2/7/2011 7:25 AM, Jan de Jong wrote:
Hi Ken,
manufacture
- a cya component
that.
Jan de Jong
Posted: Sun Feb 13, 2011 12:23 pm Post subject: Shorai LiFePO4 |
At 11:16 AM 1/31/2011, you wrote:
Check out "Shorai".
interrupt charging.
Interesting offering. I had some conversation with
my battery guru of more than 30 years (Skip Koss)
last week. He was telling me of a Lithium product
being sold onto come of the smaller bizjets. Amazing
power to weight ratios when warm. But won't deliver
more than 200A at 0C. Operators take the battery
indoors for overnight storage at low temperatures.
He also told me that GM was on their third supplier
of lithium cells for offerings into the all
electric car market. Qualification hoop-jumping levied
by automobile manufacturers on purchased goods is
about 3x the thickness of an FAA qual package. It
does not bode well that a game of musical batteries
has not produced a solid winner so late in the
commitment to field a product. As the King of Siam
might note, "curiouser and curiouser".
Watch this space . . .
