Ignition switch wiring
Remi Guerner
PostPosted: Mon Feb 07, 2011 2:00 am    Post subject: Ignition switch wiring Reply with quote
Hi all,
Still investigating the kick back problem on my 912S, I have a question for electronic engineers:
The Rotax schematic shows two separate AWG18 shielded wires from the ignition modules to the ignition switches. On my aircraft, I have a twisted pair of wires, probably smaller than AWG18, inside a single braided shielding. Is it possible that this configuration cause interference between the two circuits so that when ignition A is active and ignition B is grounded, ignition B may produce some spark while I am cranking the engine?
Remi
F-PGKL, 820 hours
rlborger(at)mac.com
PostPosted: Mon Feb 07, 2011 6:09 am    Post subject: Ignition switch wiring Reply with quote
Remi,
That is very highly unlikely. The whole purpose of the twisted pair is to reduce noise and interference.
Best regards,
Bob Borger
Europa Kit #A221 N914XL, XS Tri-Gear, Intercooled 914, Airmaster C/S Prop
http://www.europaowners.org/forums/gallery2.php?g2_itemId=60232
http://www.biplaneforumgallery.com/index.php?cat=10046
Europa Flying!
3705 Lynchburg Dr.
Corinth, TX 76208
Home: 940-497-2123
Cel: 817-992-1117
On Feb 7, 2011, at 4:00, Remi Guerner wrote:
Hi all,
Remi
F-PGKL, 820 hours
