Landing gear shake
Goto page Previous  1, 2
Robin(at)PaintTheWeb.com
PostPosted: Mon Feb 07, 2011 3:06 pm    Post subject: Landing gear shake Reply with quote
We balanced all three wheel pants before flying (photos attached).
Somewhat typical for RV's as long as you don't want to make the lightest
RV you can. It sure hurts to add weight without adding function. That
being said I also had a worse than average nose wheel shimmy for some
time. I tried balancing the wheels and adjusting the castle nut on the
nose gear many times to try & reduce the shimmy. I was able to narrow the
speed range but not eliminate it all together. Then we lifted the nose and
felt some significant movement of the nose gear. After further
investigation we found a loose busing as detailed in this extremely
exciting video staring my hand:
http://www.youtube.com/watch?v=EmT38rDenwA
Once I replaced the bushing (with a custom bushing) the shimmy was
completely eliminated and I have not thought about shimmy in the ~200
landing since the correction. I think the shimmy was gone because we had
already optimized the other components (castle nut, balanced wheels,
balanced wheel pants etc...)
Robin
 Filesize:  325.78 KB
 Viewed:  1686 Time(s)
 Filesize:  541.5 KB
philperry9(at)gmail.com
PostPosted: Mon Feb 07, 2011 6:22 pm    Post subject: Landing gear shake Reply with quote
Robin, that's one nice hand.....  Do you use palmolive or or something similar?  Very impressive.  Smile
I'm at that phase of the project right now and getting ready to put it up on the gear on the 26th when I have some help coming to town.  It doesn't look like yours were worn it looks like that's the factory fit.  Mine are new and have equal play.
scottmschmidt(at)yahoo.co
PostPosted: Mon Feb 07, 2011 7:35 pm    Post subject: Landing gear shake Reply with quote
Yup, just chalk that up to a long day. I switched a couple of numbers around in my head.
Scott Schmidt
Sent: Mon, February 7, 2011 3:46:03 PM
Subject: Re: Landing gear shake
Not to be anal, but 8 11/32 - 7.5 (7 16/32) is not more than an inch, but it's not important. It could really depend on how the plane is sitting, loaded, fueled, etc.
Jesse Saint
Saint Aviation, Inc.
C: 352-427-0285
F: 815-377-3694
On Feb 7, 2011, at 5:28 PM, Scott Schmidt wrote:
Mine measured at 8 11/32". Don't know if there is any slop in the rubber discs yet.
Interesting it is over one 1" taller.
Scott Schmidt
From: Jesse Saint <jesse(at)saintaviation.com (jesse(at)saintaviation.com)>
Sent: Mon, February 7, 2011 10:47:58 AM
The spacer came from Van's. It's part # U-1002 on page 46-07. I had someone hold the tail down and then I lifted up on the nose gear to see if it was tight. It moved, so I knew it needed another spacer. You can also tell if the bolt holding the cap on can move freely when you loosen the nut. The distance from the prop to the ground depends on how the engine hangs on the engine mounts and other things, but I'll measure it...7.5".
Jesse Saint
C: 352-427-0285
F: 815-377-3694
On Feb 7, 2011, at 12:16 PM, Scott Schmidt wrote:
Jesse, I really like what you tried and have thought about it. I never had a shake until around 100 - 150 hours. If the front gear settles down slightly it changes the toe-in.
If it is still possible can you measure the distance between the prop and the ground?
Where did you purchase the spacer?
Scott Schmidt
Sent: Mon, February 7, 2011 8:59:26 AM
I just did a condition inspection on N256H. Before the condition it had a fair bit of shimmy in the 25-30 mph range after landing. I added another spacer on the nose gear shock strut and tightened the nose gear pivot nut one flat. Most of the shimmy went away.
Jesse Saint
C: 352-427-0285
F: 815-377-3694
On Feb 6, 2011, at 2:09 AM, Scott Schmidt wrote:
I have posted on this topic before.
Mine does the exact same at the same speeds as does many other RV-10's.
Sometimes balancing the tire fixes/helps, sometimes different tires, pressures, ect.
I have tried most with no success. I have talked with Van about it and he indicated that his personal plane even did it. I have also heard that when people installed the wheel pants it started. It all comes down to a poor gear design. A round gear leg is not the optimal design for a landing gear but is the cheapest shape from a manufacturing point of view.
It is not the caliper either. Even if I slow down with no braking it occurs. I can replicate it on the ground with one wheel jacked up and use my buffer to get the wheel up to 50 mph and when it slows to around 25 mph, it shakes. It is the system hitting a natural frequency.
Van said people have put a block of wood on the backside of other RV models to stop it.
I spent a considerable amount of time re-drilling my gear legs to get the exact toe-in on both sides and it did not change one thing. I have tried two different sets of tires, pressures from 25-60 psi all with no luck. My next plan, when I get to it, is to install the wheel pant spacers from PlaneAround.com and start stiffening the wheel pant to the gear. Then I will start finding a good way change the moment of inertia of the gear leg, stiffening it in the front to back direction.
I've been told by Vans not to worry about it. Just think of it as a massage with every landing.
I will find a way to eliminate it though.
Let me know if you find anything out.
Thanks, Scott
On Jan 23, 2011, at 6:40 PM, "Roger Standley" <taildragon(at)msn.com (taildragon(at)msn.com)> wrote:
Today I was able to have a guy observe the gear up close as I was landing. I have been feeling a shake during roll out below 30 mph. Sometimes not too much but sometimes significant. Applying brakes seems to make it worse but nothing will make it stop until slowing below 20 mph. Speeds above 30 mph are smooth. He said that the left main was shaking and it looked to be rapidly moving forward and back.
Are others noticing this shaking? Is there a fix or a way to minimize the shaking that anyone has discovered?
Thank you,
Roger Standley
N291RV
165 hours
ref="http://www.matronics.com/Navigator?RV10-List%22%3Ehttp://www.matronics.com/Navigator?RV10-List==========
ums.matronics.com">http://forums.matronics.com/==========http://www.matronics.com/contribution%22%3Ehttp://www.matronics.com/contribution==========
href="http://www.matronics.com/Navigator?RV10-List%22%3Ehttp://www.matronics.com/Navigator?RV10-Listhref=%22http://forums.matronics.com/%22%3Ehttp://forums.matronics.com
href="http://www.matronics.com/contribution%22%3Ehttp://www.matronics.com/contribution
href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-Listhref="http://forums.matronics.com/">http://forums.matronics.com
Page 2 of 2
