bakerocb
Posted: Wed Feb 09, 2011 5:36 am Post subject: Unvented AGM? |
2/9/2011
Hello Fellow Builders, Ray St-Laurent wrote: "......an unvented AGM ......"
One could debate the difference between a valve and a vent, but it might be
a bit misleading to describe the valve equipped AGM batteries as being
unvented. See here:
http://en.wikipedia.org/wiki/VRLA_battery
'OC' Baker Says: "The best investment we can make is the time and effort to
gather and understand knowledge."
Time: 05:10:25 AM PST US
Subject: Re: Battery box being demanded
An STC of an equivalent installation might be the easiest way to convince. I
think
that would be an unvented AGM inside the cabin. I see there are some under
seat Cub STC's that might do. Does anyone have details. If so then I just
need
to convince him that my battery is equivalent to that specified.
--ray
Ray St-Laurent
701/Pegastol wings/Suzuki engine
Posted: Wed Feb 09, 2011 7:08 am Post subject: Unvented AGM? |
At 08:30 AM 2/9/2011, you wrote:
| Quote: | --> AeroElectric-List message posted by: <bakerocb(at)cox.net>
2/9/2011
Hello Fellow Builders, Ray St-Laurent wrote: "......an unvented AGM ....."
One could debate the difference between a valve and a vent, but it might be a bit misleading to describe the valve equipped AGM batteries as being unvented. See here:
http://en.wikipedia.org/wiki/VRLA_battery |
EXCELLENT point. It might also be useful to
note that VLRA batteries (unlike VENTED wet
batteries) are approved for shipment in the
mails and by ordinary commercial air freight
without benefit of extra-ordinary packaging.
I quote here 49 CFR 173.159(d):
(d) A nonspillable wet electric storage battery is excepted from all other requirements of this subchapter under the following conditions: (1) The battery must be protected against short circuits and securely packaged; (2) For batteries manufactured after September 30, 1995, the battery and the outer packaging must be plainly and durably marked NONSPILLABLE or NONSPILLABLE BATTERY; and (3) The battery must be capable of withstanding the following two tests, without leakage of battery fluid from the battery: (i) Vibration test. The battery must be rigidly clamped to the platform of a vibration machine, and a simple harmonic motion having an amplitude of 0.8 mm (0.03 inches), with a 1.6 mm (0.063 inches) maximum total excursion must be applied. The frequency must be varied at the rate of 1 Hz/min between the limits of 10 Hz to 55 Hz. The entire range of frequencies and return must be traversed in 955 minutes for each mounting position (direction of vibrator) of the battery. The battery must be tested in three mutually perpendicular positions (to include testing with fill openings and vents, if any, in an inverted position) for equal time periods.
That's a rather lengthy list of requirements
that the OBAM aircraft builder shouldn't
have to "prove" . . . but it illustrates
the point that cells with no loose liquid
that are not open to atmosphere have been
demonstrated benign for all hazards short
of gross damage.
In normal or even abusive service, they cannot
produce the hazards we used to associate with
their liquid electrolyte ancestors. All of the
legacy hazards calling for extra containment
of gasses/liquids simply went away.
Bob . . . [quote][b]
RayStL
Posted: Wed Feb 09, 2011 9:59 am Post subject: Re: Unvented AGM? |
Thanks for the references guys.
I believe there are some AGM batteries that have a 'vent' port designed to connect to a vent tube from an existing flooded cell battery box. The 'sealed' models with no port are most relevant to my situation.
--ray
_________________ Ray St-Laurent
701/Pegastol wings/Suzuki engine |
Posted: Wed Feb 09, 2011 10:52 am Post subject: Unvented AGM? |
At 12:59 PM 2/9/2011, you wrote:
| Quote: | --> AeroElectric-List message posted by: "RayStL" <raystl(at)nbnet.nb.ca>
I believe there are some AGM batteries that have a 'vent' port designed to connect to a vent tube from an existing flooded cell battery box. The 'sealed' models with no port are most relevant to my situation. |
That 'vent' tube can be misleading. The VRLA
is not a dry or gell battery. Liquid electrolyte
is totally contained by capillary action in the
fiberglas matting. When these batteries are
abused (severe overcharge or discharge) heating
internal to the cells will boil water and over-
pressure the valve such that excess pressure is
allowed to vent. So-called, "sealed" batteries
are sealed only to the extent of the pressure
relief setting of the valves in the vent holes.
The sum total of vented gasses is very small
in comparison with the kind of emissions one could
get from the classic, vented wet battery.
When the battery is abused to a degree that
opens the valves, there is still no liquid
water-acid emitted, only the mix of gasses
disassociated from the small amount of
water in the mat. There is a very tiny risk
for explosion if the battery is mounted in
an airtight container. The risk is not from
BATTERY explosion but ignition of the escaped
gasses not allowed to waft away in the
local breeze.
I think we hand some discussions here on the
List years ago where I related my experience
with a close call for having induced injury
or worse to a customer who was using a design
of mine that contained a VRLA battery. I also
discussed an incident involving a BATTERY
BOX explosion in a GlasAir.
Had EITHER of these batteries been fitted with
a vent-manifold and a tube leading overboard,
it's a certainty that these two events would
not have unfolded so violently. But be aware
that such vent tubes have NOTHING to do with
the conducting corrosive liquids overboard
and everything to do with reduced risk for
explosion. When a VRLA battery is fitted with
a vent-tube fitting, the tube can only serve
to collect all the gasses from cell vents during
an over-pressure event. Functionally, the batteries
are no more "sealed" or "vented" than their
other commercial contemporaries.
Identical risk reduction is achieved by
not wrapping an SLVA battery up in an airtight
enclosure.
See:
http://tinyurl.com/5v7f9gl
RayStL
Posted: Wed Feb 09, 2011 11:44 am Post subject: Re: Unvented AGM? |
Hi Bob
You might find this amusing. It is an excerpt of a message from the DOT inspector where he cherry picks words from the Power Sonic manual. The underlines are his.
| Quote: | Given the right set of circumstances, such as extreme overcharging or shorting of the battery, these gases might vent into the enclosure and create the potential for an explosion when ignited by a spark. Generally, ventilation inherent in most enclosures is sufficient to avoid problems.
Potential hazards are present, as described by the battery Manufacturer, Power-Sonic. These hazards reflects a requirement to enclose the battery in a vented battery box to ensure aviation safety for other than "During normal operation". |
He also knows I have ‘crowbar’ overvoltage protection so extreme overcharging is not possible.
--ray
Posted: Thu Feb 10, 2011 7:22 am Post subject: Unvented AGM? |
Hi Bob
. . . the corollary to the last statement is that
you can't get any better ventilation than to have
no enclosure whatsoever.
Some months ago we were considering this particular
example of a 'battery failure'.
http://aeroelectric.com/Pictures/Batteries/Odyssey_OV/Odyssey_OV_1.jpg
Some folks jumped on the swollen case and decided
that what ever value the over-pressure protection
was set for, this photo proved that it was "too low."
The investigator did tests on the un-damaged over-pressure
safety valves and found them well in specification.
The observed swelling was a function of heating plus
swelling of the battery's innards long after the
moisture had departed the battery though the valves.
This failure mode indicates a PROTRACTED exposure to
an overvoltage condition by a power source capable of
considerable energy (60+ amp alternator?). But this
poor puppy was never at risk for root cause of any
sort of 'explosion'.
He is demonstrably oblivious of the finer points of
how this new technology functions . . . and how it
behaves when driven to failure.
I used to have a VERY good working relationship with
a lady who worked at the Navy's battery testing facilities
in Crane, Indiana. I don't recall what her job title
was . . . maybe never knew it. But she had been there
a long time and observed a great deal of the proceedings
in her facility with interest and understanding. Best
yet, she was willing to share.
I can recall conversations that might have lasted
HOURS. She was a encyclopedia of first-hand information
about the past, present and future of battery technologies.
You think the FAA has an inordinate interest in
behaviors of batteries under duress, you should hear
what the Navy expects!
The last time we talked, I had to call her at
home where she was under hospice care for a terminal
bout of cancer. I was glad I could inform her of a very
high stature amongst many of my valued teachers.
It's a disturbing observation that so many individuals
with power over our lives are so ill prepared to
execute those jobs with reason and competence. It
follows that the execution of those duties do not
add value . . . and in fact tax value out of our
willingness and ability to do the best we know how
to do. We all wish you good fortune . . .
