elleryweld(at)aol.com Guest
Posted: Wed Feb 09, 2011 4:37 pm Post subject: Heavy Passengers |
speaking of passengers I have a friend that wants a ride in my MK3c and he is 350 lbs im not sure I should even attempt it, I am 190 lbs what's your thoughts on giving a heavy guy a ride?
the most I have had with me is 250 lbs and 20 gallons fuel
Ellery Batchelder Jr.
Quote: |
Quote: | I might add, we were on the brink of destruction as soon as my passenger got
on board. |
Dana
Posted: Wed Feb 09, 2011 5:17 pm Post subject: Heavy Passengers |
At 07:19 PM 2/9/2011, Ellery Batchelder Jr wrote:
Quote: | speaking of passengers I have a friend that wants a ride in my MK3c and he is 350 lbs im not sure I should even attempt it, I am 190 lbs what's your thoughts on giving a heavy guy a ride?
It's your plane... what do the weight and balance limits say?
-Dana
Psychiatrists say that one of four people are mentally ill. Check three friends. If they're OK, you're it.
byoungplumbing(at)gmail.c Guest
Posted: Wed Feb 09, 2011 5:43 pm Post subject: Heavy Passengers |
what does your plane weigh,,
say 600 +you at 190 say 5 gal fuel. +30 you are up to 820 lb.. if you have 1000 lb gross,,, minus 820 leaves 180 pound passenger, you are up to gross wt.. maybe your plane weighs less or you could takeoff with less fuel...
my .02 worth
boyd young
mkiii
Posted: Wed Feb 09, 2011 6:00 pm Post subject: Heavy Passengers |
I calculated and if I only used 3 gallons fuel ( A short Flight ) I would still be in the W&B window but I have never flown with that much weight in the MK3C
Richard Pike
Posted: Wed Feb 09, 2011 7:58 pm Post subject: Re: Heavy Passengers |
Run a W & B and you will find out. Assuming that your W & B says it's ok - bear in mind that with full flaps and a forward CG, the MKIII runs out of elevator authority in a hurry in that situation, so NO FLAPS.
Even if the numbers come out right, I would add a strip of tape to the gap between the elevator and stab, and land w/o flaps, and keep the airspeed to 60 or 65 on final. With a LONG runway...
Or just say no. (How would a 350 pound person even fit? That is going to foul your elevator push rod. Not to mention getting them back out of the bucket after the flight is over. Unless they are unusually agile for that weight, you are going to do some serious pulling and tugging)
Richard Pike
MKIII N420P (420ldPoops)
Posted: Wed Feb 09, 2011 8:14 pm Post subject: Heavy Passengers |
is 350 lbs
Ellery B/Kolbers:
Sometimes, especially at Oshkosh and S&F, flying for Kolb Aircraft, we
pushed the limits in order to satisfy customers and bosses. The largest guy
I ever got off the ground in the factory MKIII was a lopper. That means he
lopped over the aileron torque tube between the pilot and passenger. It
takes a big guy or gal to be a lopper, probably over 300 lbs. On take off
to the north out of the UL strip at Oshkosh, it was up hill with a 90 deg
brisk cross wind. I had everything working against me to include my
decision to fly this guy. Finally broke ground about midfield. Soon as we
got airborne the MKIII began drifting right towards the fence and spectator
bleachers. I had full left stick and it was still trying to roll and drift
right. A quick prayer and some luck, it slowly started to roll left and
away from the fence before I hit it. I was able to climb out between and
over the trees at the north end. Flew the traffic pattern at full throttle.
Shot my approach at 75 mph. Did not chop power until the mains touched
down.
The only thing that flight proved was I had made a very stupid, dangerous
decision that could have turned deadly. Sometimes it is hard to say no.
After that incident, I never had a problem turning down a passenger when I
felt the least bit unsure of a safe flight. Since then I have aborted
flights on take off at S&F with extra heavy passengers. Didn't hurt a thing
and the passengers were very happy that I made the decision when I sat them
down and explained my actions.
There's a lot of difference in handling and performance between solo and
flying a normal category passenger. Takes a lot more up elevator trim.
With no up elevator trim there are heavy nose down stick forces. This
situation plays hell with low time MKIII pilots, and is not much fun for
those with lots of experience.
Don't make the same poor decision I did. You may not be as lucky.
350 lbs!!! I wouldn't even talk about flying with him.
_________________ John Hauck
Titus, Alabama |
Posted: Wed Feb 09, 2011 8:27 pm Post subject: Heavy Passengers |
the MK3C
Ellery B/Kolbers:
My max gross is 1,200 lbs. When I make a serious, long cross country, my
take off weight is approximately 1,200 lbs. However, my fuel and most cargo
is behind the bulkhead and I don't have 350 lbs in the front seat beside me.
I have never been able to make the W&B on a MKIII work out for me on paper.
Through experiementation and experience I know how much weight and where it
will fly safely with a very wide margin. If I am going to push the fore or
aft limit, I will push the aft limit. I can't prove that on paper, but I
can in the air. Remember, that is the way I do it. I do not recommend that
anyone else fly their Kolb that way.
Titus, Alabama |
Posted: Thu Feb 10, 2011 3:19 am Post subject: Heavy Passengers |
If I am going to push the fore or aft limit, I will push the aft limit. >>
Thats interesting John. Whats the reasoning? I would have thought that tail
heavy the most dangerous. When the speed comes back ,for landing, and you
are low a heavy tail is asking for a stall. If you are nose heavy at least
when the nose goes down your speed goes up and that gives you more elevator
control. Hopefully.
Your all up weight is way above ours. Not to say that the Kolb wont handle
it but here if you are overweight then you are no longer a `microlight`.
That means that your pilots license is not valid and therefore your
insurance is invalid as well.. You cannot fly legally here without third
party insurance so you are in trouble with the law as well as the CAA.
Pat
Posted: Thu Feb 10, 2011 7:04 am Post subject: Heavy Passengers |
control. Hopefully.
Pat
Patrick L/Gang:
My MKIII is placarded for 1,200 lbs maximum gross weight based on
modifications the manufacturer (me) made during construction to satisfy me,
the FAA, and my insurance company.
I have difficulty making the Kolb paper weight and balance work in actual
flight.
I flew my MKIII with a 12 lb Maule 8" Tundra Tailwheel for several years.
This blows the paper weight and balance away. My airplane is not supposed
to fly on paper, yet it flew quite well. I stalled it in every attitude I
could think of and the nose always dropped.
I don't like the idea of running out of elevator before the wing stalls.
The Kolb's high pusher configuration compounds the forward cg with a heavy
passenger, especially on take off and in the event of a go around.
I have never had the courage to stall a MKIII with a very heavy passenger,
so I really do not know how the aircraft would respond. I don't have to
worry about that anymore because I won't be flying large passengers in my
aircraft, and I don't fly demonstration flights for Kolb anymore.
I have stalled my MKIII with full flaps and a passenger on board. To my
surprise, the elevator stalled when I attempted to recover. That'll get
your attention.
Have no statistics to back me up, but there seem to be many fatal Kolb
crashes while carrying passengers. I don't know how valid that is.
I have always flown with a recovery parachute.
Titus, Alabama |
Frankd
Posted: Thu Feb 10, 2011 8:37 am Post subject: Re: Heavy Passengers & Insurance |
Hi Guys,
responding to Pats comment about weight and insurance, do aircraft in the US require insurance to legally fly??
I know you have to have car insurance but I can't find anything that says you have to have aircraft insurance.
Also, has anyone had luck getting life insurance when you fly an experimental?? (My wife REALLY would like this!) I can get life but only if I fly certified aircraft and no ACRO..
Looking for answers.
FrankD
MkIII Xtra,
Now legally airworthy.
Soon to fly. no more excuses.
Dennis.Kirby(at)kirtland. Guest
Posted: Thu Feb 10, 2011 8:41 am Post subject: Heavy Passengers |
<< speaking of passengers I have a friend that wants a ride in my MK3c and he is 350 lbs im not sure I should even attempt it, … the most I have had with me is 250 lbs and 20 gallons fuel Ellery Batchelder Jr. >>
Ellery –
When I calculated the Weight & Balance for my Mark-3, it came out that the MOST heavy passenger I could “safely” carry was 250 lbs. This was based on my weight of 190 lbs, and minimal fuel (less than a quarter tank). In this configuration, the CG was at its forward-most allowable point, as specified by Homer. It’s not a gross weight limitation – it’s an out-of-CG issue.
I suspect that you are correct – taking a 350 lb passenger in your Mark-3 might be a tad risky. Might even put your Kolb at the brink of destruction.
Dennis Kirby
Mark-III N93DK, “Magic Bike”
New Mexico
racerjerry
Joined: 15 Dec 2009 Posts: 202 Location: Deer Park, NY
Posted: Thu Feb 10, 2011 9:11 am Post subject: Re: Heavy Passengers |
You do not have to say NO. Do him and yourself a great favor and rent a 172 for an hour and take him up. Or give him a present and BUY him a sightseeing flight at your local airport and go with him. Good advice about No flaps and increasing landing speed; but with such a large percentage change in gross weight and CG, even if successful, you will be operating in very unfamiliar and dangerous territory. Flight characteristics will change greatly, at which point you will become a test pilot with a large frightened passenger who is most likely restricting stick movement.
_________________ Jerry King |
Posted: Thu Feb 10, 2011 9:28 am Post subject: Heavy Passengers |
there seem to be many fatal Kolb crashes while carrying passengers. >>
Do you think that by some extraordinary chance that might be telling us that
there is something in weight and balance after all?
Cheers
Pat (off to Tenerife and some sunshine at sparrows tomorrow. See you in a
week)
neilsenrm(at)gmail.com Guest
Posted: Thu Feb 10, 2011 10:09 am Post subject: Heavy Passengers |
I have been flying quite a bit near or slightly over gross weight lately. Yes the plane does fly differently the most concerning is the bad combination of high power and flaps. I use flaps on landing but I tell myself and my passenger that if I have to add power for a go around that all flaps must be retracted.
With that said my personal feeling is that Kolb accidents are mostly caused by passengers panicking on approach to landing. I have had a number of people get excited and later comment that I didn't warn them strongly enough. The normal Kolb approach is a bit unsettling to everyone and even more so to private pilots. The best advice I can give is to make it clear what the approach will look like and to warn you passenger to never never touch the controls without permission. Also be ready to use your elbow as much as necessary to enforce that rule.
Rick Neilsen
Redrive VW Powered MKIIIC
On Thu, Feb 10, 2011 at 12:25 PM, Pat Ladd <pj.ladd(at)btinternet.com (pj.ladd(at)btinternet.com)> wrote:
[quote] --> Kolb-List message posted by: "Pat Ladd" <pj.ladd(at)btinternet.com (pj.ladd(at)btinternet.com)>
Do you think that by some extraordinary chance that might be telling us that there is something in weight and balance after all?
Cheers
Pat (off to Tenerife and some sunshine at sparrows tomorrow. See you in a week)
bscription,
www.matronics.com/Navigator?Kolb-List" target="_blank">http://www.matronics.com/Navigator?Kolb-List
ronics.com/" target="_blank">http://forums.matronics.com
Matt Dralle, List Admin.
Richard Pike
Posted: Thu Feb 10, 2011 10:53 am Post subject: Re: Heavy Passengers |
John Hauck wrote: |
<snip>
your attention.
Titus, Alabama |
You nailed that one.
Several years ago I gap sealed my elevator to the horizontal stab in an effort to eliminate that particular problem. At the same time, added VG's to the underside of the lower forward horizontal stab. Should have done the mods one at a time to see which was the most effective. Not sure which of those 2 things helped the most, but together it has made a huge improvement in elevator authority with flaps and a passenger. (massive forward CG)
Richard Pike
Last edited by Richard Pike on Thu Feb 10, 2011 10:55 am; edited 2 times in total |
Dana
Posted: Thu Feb 10, 2011 10:54 am Post subject: Heavy Passengers |
At 11:37 AM 2/10/2011, Frankd wrote:
Quote: | --> Kolb-List message posted by: "Frankd" <frankd(at)foundrynet.com>
I know you have to have car insurance but I can't find anything that says you have to have aircraft insurance. |
There is no legal requirements for insurance, but many airports require insurance for aircraft based there.
-Dana
I only drink to make other people more interesting.
lcottrell
Posted: Thu Feb 10, 2011 11:11 am Post subject: Heavy Passengers |
"With that said my personal feeling is that Kolb accidents are mostly caused by passengers panicking on approach to landing. I have had a number of people get excited and later comment that I didn't warn them strongly enough. The normal Kolb approach is a bit unsettling to everyone and even more so to private pilots. "
I bought a Mark III when I was taking my P.Pilots training. I talked my young instructor into going around with me to sign off on it so that I could fly it with a Student lic. Every thing was fine and when I lined up for short final at 1000 feet above the ground, I put in full flaps when I was almost over the numbers, brought it back to a bit of a mush and landed on the numbers with no incident other than having to pull my instructor out of the wing gap seal. He did sign me off, but would not fly with me any more. Puss!
Pat attempted to link heavy passengers and crashes with a weight and balance issue. Much too simple an answer, most likely it would be due to not taking into account the different flight requirements with a heavy passenger in the front.
Larry
Note: If you forward this email, please delete the forwarding history, which includes my email address.
Posted: Thu Feb 10, 2011 11:58 am Post subject: Heavy Passengers |
That sounds interesting. -anybody else have stories about passengers invading the flight controls?Personally I have never experienced anything like that and I have given a lot of free rides. I did have one guy get so
distraught at being too far away from mother earth that I immediately turned downwind and landed.
Thankfully he didn't grab anything but the pipes in the windshield.
I think full flaps with a passenger in a MkIII is not necessary and possibly hazardous.
Now, getting on in years, I think I will discourage would be riders.
BB
On 10, Feb 2011, at 1:02 PM, Rick Neilsen wrote:
[quote]I have been flying quite a bit near or slightly over gross weight lately. Yes the plane does fly differently the most concerning is the bad combination of high power and flaps. I use flaps on landing but I tell myself and my passenger that if I have to add power for a go around that all flaps must be retracted.
Rick Neilsen
Quote: | --> Kolb-List message posted by: "Pat Ladd" <pj.ladd(at)btinternet.com (pj.ladd(at)btinternet.com)>
Cheers
bscription,
| [b]
Posted: Thu Feb 10, 2011 12:05 pm Post subject: Heavy Passengers |
the lower forward horizontal stab. Should have done them one at a time to
Richard Pike
Richard P/Kolbers:
Quote: | I have stalled my MKIII with full flaps and a passenger on board. To my
your attention.
Maybe I should correct the above and further explain my maneuver with full
flaps that caused the elevator to stall. I was not performing a full flap
stall, but a dive with full flaps, idle power, and an abrupt pull out when
we reached 85 mph.
Was down at Sun and Fun demonstrating my MKIII to a reporter for an aviation
magazine. We were having a good time wringing out most of the neat little
things a MKIII is capable of doing safely, when I got the idea to try
something I had never done before. That was to pull in full flaps, idle
power, push the nose over and dive to 85 mph. At 85 mph pull out of the
dive abruptly. When I pulled the stick back abruptly the MKIII kept heading
earthward with the elevator fully stalled. Surprise, surprise!
First and only time I have had the elevator stall on my MKIII. I can not
think of a scenario I could get myself into that would result in a replay of
that maneuver.
I normally use full flaps for every landing, unless it is really turbulent
and/or a severe cross wind, and have no issues with elevator authority.
Nope, not ready for VGs under my tail.
Titus, Alabama |
I have calculated this again it has been a while and I agree with you a Fat man was not meant to fly in a small airplane, however if i fill my 20 gallon fuel tank it would help the CG issue but then send the weight over the Gross limit so I will tell him if he wants to fly to leave 100 lbs home or buy a ticket on a Delta Flight
