RayStL
Posted: Wed Feb 09, 2011 11:12 am Post subject: Re: Battery box being demanded |
To answer Raymond's question:
An MDRA inspector is not a civil servant. He is a volunteer. In my case he is also an AME whose livelihood depends on keeping this same DOT inspector happy.
I have no doubt that this will eventually be resolved in my favor. If I can find an STC for a similar configuration, it will be done in 2 days. Otherwise I will have to make a full blown presentation before a tribunal that in a process I expect will take at least another 2 months.
_________________ Ray St-Laurent
701/Pegastol wings/Suzuki engine |
raymondj(at)frontiernet.n Guest
Posted: Wed Feb 09, 2011 12:21 pm Post subject: Battery box being demanded |
I hope you are able to resolve it with an STC.
Raymond Julian
Kettle River, MN
On 02/09/2011 01:12 PM, RayStL wrote:
Ray St-Laurent
http://forums.matronics.com/viewtopic.php?p=330315#330315
ronr(at)advanceddesign.co Guest
Posted: Wed Feb 09, 2011 12:31 pm Post subject: Battery box being demanded |
Sure sounds easier to build a box and be done with it.
Ron Raby
Float Flyr
Posted: Thu Feb 10, 2011 6:16 am Post subject: Battery box being demanded |
Sorry Guys but because of the original reverence ot CAR I thought the plane was Canadian... That accounts for the difference in what is in the reg.
Noel
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
Float Flyr
Posted: Thu Feb 10, 2011 6:28 am Post subject: Battery box being demanded |
Ray try contacting Gary Wolfe president of the RAA. He may be able to help
you as all the Canadian inspectors actually are RAA.
There is also a yahoo group canultra.com which you may be able to contact
him.
Noel
I'm now assuming the plane is here in Canada.
Kitfox III-A
Float Flyr
Posted: Thu Feb 10, 2011 6:38 am Post subject: Battery box being demanded |
Just for the Americans reading this it is actually TC (Transport Canada)
which does the licensing. An AME is not an Aviation Medical Examiner but an
Aircraft Maintenance Engineer. The inspections of homebuilt aircraft have
been removed form TC in an attempt to free up their inspectors time for
larger aircraft. The Inspectors are actually appointed members of the
Canadian RAA ( Recreational Aircraft Association)
Noel
I've gone back to my original idea that the plane is Canadian so there is a
fool up in the part the inspector quoted.
Kitfox III-A
Float Flyr
That would be difficult as home built aircraft are not certified there fore
STCs do not apply. However you can have a look through AC43... The FAA
circular which is the also the Canadian bible on aircraft standards...
Hmmm I wonder if the part he quoted is not in CARs but
AC43. I'll check it out.
for ideas on how to install the battery.
Noel
Kitfox III-A
Float Flyr
Posted: Thu Feb 10, 2011 6:53 am Post subject: Battery box being demanded |
Just checked AC43.13-2a PP79 - 80 it gives all the requirements for the
battery box or tie down. It is possible the inspector will be happy with
venting that would allow any hydrogen gas he thinks may be produced to
safely be removed. Humour him.
BTW AC43.13 1b/2a is available online from the FAA in pdf format free. If
you make changes for the inspector I'd print the pages from the AC so you
can tell him these are the exact standards you used.
Noel
Kitfox III-A
deej(at)deej.net Guest
Posted: Thu Feb 10, 2011 7:51 am Post subject: Battery box being demanded |
On 02/09/2011 10:42 AM, n801bh(at)netzero.com wrote:
| Quote: | In my experimental I used the group 24 box shown here.
<http://www.westmarine.com/webapp/wcs/stores/servlet/ProductDisplay?productId=102091&catalogId=10001&langId=-1&storeId=11151&storeNum=10109&subdeptNum=10548&classNum=10551>
For what it is worth, I saw what appeared to be the same battery box at
Walmart last night for $6.94.
-Dj
Dj Merrill - N1JOV
Glastar Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/
Please use Netiquette Guidelines http://tools.ietf.org/html/rfc1855
Kindly TRIM your email replies and post AFTER the relevant text
RayStL
Posted: Thu Feb 10, 2011 10:38 am Post subject: Re: Battery box being demanded |
I just sent my (latest) reply off to the DOT inspector. I found ST02156AK which is an STC for supercubs. It allows for the installation of an underseat sealed battery (Odyssey) to replace the original battery and battery box. That should be enough justification. For the supercub case, considering the shorter and smaller cables it saves 16 pounds.
Thanks for all your ideas and suggestion. I'll let you know what happens.
--ray
sprocket(at)vx-aviation.c Guest
Posted: Thu Feb 10, 2011 12:40 pm Post subject: Battery box being demanded |
Thanks for the hard work on this Ray, it's a great service to a lot of
homebuilders having to face down Transport or the MD-RA.
Vern
RayStL
Posted: Thu Feb 10, 2011 4:26 pm Post subject: Re: Battery box being demanded |
Glad to help. I think it is almost over.
Some things are too silly to live. This was one of them.
--ray
RayStL
rlborger(at)mac.com Guest
Posted: Wed Feb 23, 2011 2:42 pm Post subject: Battery box being demanded |
Ray,
CONGRATS!!
Bob Borger
Europa Kit #A221 N914XL, XS Tri-Gear, Intercooled 914, Airmaster C/S Prop
http://www.europaowners.org/forums/gallery2.php?g2_itemId=60232
http://www.biplaneforumgallery.com/index.php?cat=10046
Europa Flying!
3705 Lynchburg Dr.
Corinth, TX 76208
Home: 940-497-2123
Cel: 817-992-1117
On Feb 23, 2011, at 16:18, RayStL wrote:
Here is an excerpt from an email I received yesterday...
> Hello ray,
> After further review, Transport Canada has no objection that you continue operating aircraft registered C-GJRL in the present configuration.
Yay.
--ray
Ray St-Laurent
n801bh(at)NetZero.com Guest
Posted: Wed Feb 23, 2011 2:48 pm Post subject: Battery box being demanded |
Hmmmm.
Transport Canada must read this list too. <GG>
Ben Haas
N801BH
www.haaspowerair.com
