l filler flap
flyboy3847(at)onecommail.
PostPosted: Thu Feb 10, 2011 10:05 am    Post subject: l filler flap Reply with quote
We used a flat aluminum extruded hinge and put it on the under side if the cowl and the flap. We used simple Dzus fasteners to hold it down.
Leroy Wheeler
601HD plans built been flying 150+ hours. With a Subaru EA-81.
From: owner-zenith601-list-server(at)matronics.com [mailto:owner-zenith601-list-server(at)matronics.com] On Behalf Of K Dilks
Sent: Thursday, February 10, 2011 11:46 AM
Subject: l filler flap
--> Zenith601-List message posted by: "K Dilks" <kevindilks(at)btinernet.com>
Can any one who has used the comlet molded cowls for a Rotax engined XL tell me what they did to hinge and fit a catch for the oil filler flap.
The cowl only comes with a prepared hole, i have made a aluminium flap but cannot find a hing or catch suitable.
Kevin
UK
Back home .................
http://forums.matronics.com/viewtopic.php?p=330458#330458
Zenith601-List Email Forum -
href="http://www.matronics.com/Navigator?Zenith601-List">http://www.matronics.com/Navigator?Zenith601-List
bsp; - MATRONICS WEB FORUMS -
bsp; - List Contribution Web Site -
bsp;   -Matt Dralle, List Admin.
Checked by AVG - www.avg.com
02/09/11
Terry Phillips
PostPosted: Thu Feb 10, 2011 11:58 am    Post subject: l filler flap Reply with quote
Hi Kevin
'Good to hear from you again! It sounds like you are making good
progress--I wish I could say the same. I'm moving slowly, but, at least,
I'm moving.
I'm sure there are many solutions to this. You might take a look at Larry
McFarland's approach
http://macsmachine.com/
Click the Cowling link, and you'll find some photos that pretty clearly
show what Larry did. There are other approaches using hinges that appear to
be similar to invisible cabinet hinges.
I'll also attach a couple of photos that I took at Zenair's Open Hangar
Days 2007. They do not show the mechanism, but both appear to use simple
piano hinges and Dzus type fasteners for the closure. 'Sorry, but I do not
know who owned those 601's.
Terry
Kevin
UK
Terry Phillips
ttp44~at~rkymtn.net
Corvallis MT
ZU-601XL/Jab 3300 s .. l .. o .. o .. w build kit - Tail & flaps are done;
Upgrading wings & ailerons per the AMD Safety Directive
http://www.mykitlog.com/N47TP/
 Filesize:  49.59 KB
 Viewed:  3151 Time(s)
 Filesize:  44.06 KB
Terry Phillips
Corvallis, MT
ttp44<at>rkymtn.net
Zenith 601XL/Jab 3300 slow build kit - Tail feathers done; working on the wings.
