Exhaust Pipe Temps
partner14
PostPosted: Thu Feb 10, 2011 9:13 pm    Post subject: Exhaust Pipe Temps Reply with quote
Has anyone measured the temperature of the exhaust PIPES either as they exit the bottom cowl, or closer to the tips? Not the egt, but the pipes themselves.
Thanks, Don McDonald
Don A. McDonald
40636
martinaerodrome(at)gmail.
PostPosted: Fri Feb 11, 2011 6:54 am    Post subject: Exhaust Pipe Temps Reply with quote
I had my exhaust pipes ceramic coated inside and out.  This resulted in a dramatic reduction in radiated heaat.
Dick Martin
RV8 N233M
the fast one
On Thu, Feb 10, 2011 at 11:13 PM, partner14 <building_partner(at)yahoo.com (building_partner(at)yahoo.com)> wrote:
[quote]--> RV10-List message posted by: "partner14" <building_partner(at)yahoo.com (building_partner(at)yahoo.com)>
Don A. McDonald
40636
http://forums.matronics.com/viewtopic.php?p=330555#330555
ption,
www.matronics.com/Navigator?RV10-List" target="_blank">http://www.matronics.com/Navigator?RV10-List
ronics.com/" target="_blank">http://forums.matronics.com
Matt Dralle, List Admin.
Kellym
PostPosted: Fri Feb 11, 2011 7:00 am    Post subject: Exhaust Pipe Temps Reply with quote
The downside to such coatings is that once coated they can never be weld
repaired. Just one of the trade-offs we have to weigh and make our choices.
Dick Martin
RV8 N233M
the fast one
<building_partner(at)yahoo.com <mailto:building_partner(at)yahoo.com>> wrote:
Don A. McDonald
40636
ption,
Kelly McMullen
KCHD
Lew Gallagher
PostPosted: Sat Feb 19, 2011 10:59 am    Post subject: Re: Exhaust Pipe Temps Reply with quote
Hey Don,
I never saw a reply on your question re exhaust pipe temp, so today I aimed an infrared sensor at the exhaust pipes just as they clear the cowling. 250 F and it's 65 outside. He had just landed and I took it as he stopped after taxi with the engine still running. The numbers bounced around a bit (wind?) but 250 seemed about average.
I'm curious what you'll do with this number? If it's about protecting the fiberglass from heat, I've thought of using the same type of heat shield that is on motorcycle headers -- a strap clamp around the pipe that holds a metal shield off with an air gap in between. But if the adhesive reflective tape works just as well, that may do the trick.
Later, - Lew
non-pilot
crazy about building
NOW OFICIALLY BUILDER #40549
Fly off completed !
