greghale
Joined: 10 Jan 2007 Posts: 91 Location: Tulsa, Oklahoma
Posted: Sat Feb 12, 2011 8:29 pm Post subject: oil pressure adjustment |
Hey Guys,
My oil pressure has been running a tad bit high. I wanted to adjust the pressure down. Does anyone know which way (CW CCW) the adjustment screw should be turned to lower the pressure? I could guess, but if I'm wrong, I have to pull the cowling off again. Don't want to chip the new paint.
Greg...
_________________ Greg Hale rv10 -- N210KH
www.nwacaptain.com |
Kellym
Posted: Sat Feb 12, 2011 8:53 pm Post subject: oil pressure adjustment |
I would recommend leaving it alone. Slightly high won't hurt anything.
It likely will come down as soon as warm weather returns.
On 2/12/2011 9:29 PM, greghale wrote:
Hey Guys,
Greg...
www.nwacaptain.com
http://forums.matronics.com/viewtopic.php?p=330849#330849
KCHD |
greghale
Posted: Sun Feb 13, 2011 7:30 am Post subject: Re: oil pressure adjustment |
My oil pressure has been running around 95psi since new. This is during the first start of the day. After the engine has run for awhile, it will go down to 85 psi which is OK for me. I just want to lower it some. The AFS engine monitor becomes a nuisance until the pressure drops below 95 which is where I have the top limit set.
Greg...
Kellym
Posted: Sun Feb 13, 2011 7:45 am Post subject: oil pressure adjustment |
New 172s if I recall correctly have their redline for IO-360 set at 100
psi, and the pickoff is in a location that would give closer to 115 psi
in the old pickoff location. I'd say it would be a lot easier to just
reset your AFS limit to 100. Many planes will go over red line on first
takeoff of the day in cool/cold weather. Nothing to be concerned about
unless you start losing oil outside the engine. IMHO this falls under
don't fix what isn't broke.
Kelly
A&P/IA
On 2/13/2011 8:30 AM, greghale wrote:
Greg...
www.nwacaptain.com
http://forums.matronics.com/viewtopic.php?p=330876#330876
KCHD |
Lew Gallagher
Posted: Sun Feb 13, 2011 7:56 am Post subject: oil pressure adjustment |
Hey Greg,
We had the same issue. As I remember, it is not a screw adjustment. The
way we adjusted the oil pressure on the IO 540 was to cut the safety wire
and unscrew the cap on the oil pressure gizmo on the copilot side of the
engine -- that reveals a steel ball and a pressure spring. On the opposite
end of the spring from the ball are a couple of washers used as spacers to
increase/decrease the tension on the spring -- which regulates the oil
pressure. We took one washer out, and all is well. At first, it doesn't
look like there are spacers down in there, but they are.
Sorry about the lack of technical jargon -- I can take a picture of it later
this PM if needed.
Later, - Lew
_________________ non-pilot
crazy about building
NOW OFICIALLY BUILDER #40549
Fly off completed ! |
Tim Olson
Posted: Sun Feb 13, 2011 8:14 am Post subject: oil pressure adjustment |
I'd agree fully. I was seeing mid-to-high 90's
when cold, and then when summer comes, on roll-out from
landing I'd get an alarm because my alarm was set to
40...which I then set to 35. You're better off just
setting the alarm limit up because you're not way out
of spec or anything and this is still winter.
You just really don't have a problem.
Tim Olson - RV-10 N104CD
On 2/13/2011 9:42 AM, Kelly McMullen wrote:
Kelly
A&P/IA
> Greg...
> www.nwacaptain.com
Lew Gallagher
Posted: Sun Feb 13, 2011 8:58 am Post subject: Re: oil pressure adjustment |
One more thought on high oil pressure. I heard of an oil cooler being blown out due to too high oil pressure on another plane. I don't know how high that would have to be, to be of concern, but I never would have thought of that at all.
Later, - Lew
Tim Olson
Posted: Sun Feb 13, 2011 9:54 am Post subject: oil pressure adjustment |
Probably when it's cold out:
http://www.reiffpreheat.com/Oil%20cooler%20heater.htm
An oil cooler should be able to handle normal situations fine...and
if you were talking high pressure because of no preheat, then
you're talking an extreme situation that wouldn't be fixed by
changing the setting a little lower.
I did run into one RV-10 pilot at one time who didn't calibrate
his oil pressure on the EIS, and never set the proper scale
factor and offset to make it read properly. It read high,
so he just adjusted the engine. Scary....once you set the
proper scale factor and offset, you'd probably find he
reduced it way too low.
So FIRST, verify the reading is all calibrated and set
right, then decide what to do. But, you're not going to
save an oil cooler from blowout due to routine normal
oil pressure extremes, unless it's a bad cooler.
On 2/13/2011 10:58 AM, Lew Gallagher wrote:
Later, - Lew
non-pilot
Fly off completed !
http://forums.matronics.com/viewtopic.php?p=330896#330896
flysrv10(at)gmail.com Guest
Posted: Sun Feb 13, 2011 10:09 am Post subject: oil pressure adjustment |
But if you really want to; counter clockwise will reduce the pressure.
Sent from my iPad
On Feb 13, 2011, at 8:42 AM, Kelly McMullen <kellym(at)aviating.com> wrote:
New 172s if I recall correctly have their redline for IO-360 set at 100 psi, and the pickoff is in a location that would give closer to 115 psi in the old pickoff location. I'd say it would be a lot easier to just reset your AFS limit to 100. Many planes will go over red line on first takeoff of the day in cool/cold weather. Nothing to be concerned about unless you start losing oil outside the engine. IMHO this falls under don't fix what isn't broke.
Kelly
A&P/IA
> Greg...
> www.nwacaptain.com
Posted: Sun Feb 13, 2011 3:11 pm Post subject: oil pressure adjustment |
On some engines, it is a screw. Mine was.
Do not archive.
Sent from my iPad
On Feb 13, 2011, at 8:50 AM, "Lew Gallagher" <lewgall(at)charter.net> wrote:
Hey Greg,
We had the same issue. As I remember, it is not a screw adjustment. The way we adjusted the oil pressure on the IO 540 was to cut the safety wire and unscrew the cap on the oil pressure gizmo on the copilot side of the engine -- that reveals a steel ball and a pressure spring. On the opposite end of the spring from the ball are a couple of washers used as spacers to increase/decrease the tension on the spring -- which regulates the oil pressure. We took one washer out, and all is well. At first, it doesn't look like there are spacers down in there, but they are.
Sorry about the lack of technical jargon -- I can take a picture of it later this PM if needed.
Later, - Lew
greghale
Posted: Sun Feb 13, 2011 4:35 pm Post subject: Re: oil pressure adjustment |
Thanks everyone for the replies. I did find what I wanted on google. I adjusted the pressure by turning the adjustment screw out CCW 1 turn. Pressure now on takeoff 85 instead of the 95 I saw earlier. Alls well and the airplane is flying great. The 14 inches of Oklahoma snow finally melted and the temperature outside was 60 degrees.
EFDsteve(at)aol.com Guest
Posted: Sun Feb 13, 2011 5:59 pm Post subject: oil pressure adjustment |
Please excuse my question, because my plane isn't flying yet so I just don't have this experience, but my engine has a vernatherm, which is a required replacement at overhaul and is supposed to vary the oil flow into the oil cooler, based on the temperature of the oil. When I hear about an oil cooler being "blown" because of high oil pressure, when the oil is cold, how can that happen if there is a temperature compensated valve in the engine limiting the flow to the oil cooler?
Thanks.
Steve Weinstock
40230, finishing kit
In a message dated 2/13/2011 11:54:55 A.M. Central Standard Time, Tim(at)MyRV10.com writes:
| Quote: | --> RV10-List message posted by: Tim Olson <Tim(at)myrv10.com>
| Quote: | --> RV10-List message posted by: "Lew Gallagher"<lewgall(at)charter.net>
Later, - Lew
non-pilot
Fly off completed !
_-========================e ies ay - MATRONICS WEB FORUMS - List Contribution Web Site p;
Bob Turner
Posted: Sun Feb 13, 2011 6:07 pm Post subject: Re: oil pressure adjustment |
Answer to the last question is, I think, that the vernatherm never closes completely, so the oil cooler sees full pressure even with low flow rates thru it.
_________________ Bob Turner
RV-10 QB |
Kelly McMullen
Posted: Sun Feb 13, 2011 6:42 pm Post subject: oil pressure adjustment |
The vernatherm is wide open when cold, allowing oil to bypass the
cooler. It needs to fully close shutting off the bypass when the oil
reaches 180 degrees, forcing the oil through the cooler. IOW your
thinking about how it operates is backwards.
On Sun, Feb 13, 2011 at 7:07 PM, Bob Turner <bobturner(at)alum.rpi.edu> wrote:
A&P/IA, EAA Tech Counselor
KCHD |
Kellym
Posted: Sun Feb 13, 2011 6:49 pm Post subject: oil pressure adjustment |
Of course you really need to know from a calibrated pressure gauge that
the pressure is actually high. Without calibration, 5-10 lbs one way or
the other is meaningless. I'm with Tim. I'd bet that come summer you
will be adjusting it back to where it was.
On 2/13/2011 11:08 AM, Rob Kermanj wrote:
Sent from my iPad
KCHD |
Bob Turner
Posted: Mon Feb 14, 2011 10:24 am Post subject: Re: oil pressure adjustment |
Thanks for the info, Kelly. I tend to think backwards anyway!
RV-10 QB |
