				 Posted: Thu Feb 17, 2011 7:32 am    Post subject: Wiring diagram question for Pitot Heat   On indicator light |
				At 09:07 AM 2/17/2011, you wrote:
 Guys,
 I'm using Bob's pitot heat.pdf schematic as the base for a "Pitot
 Heat ON" amber LED light on my annunicator / warning light panel.
 http://www.aeroelectric.com/PPS/DeIce/Pitot_Heat.pdf
 In comparing this schematic to his article titled "Failure Detection
 and Annunciation I notice a few differences in the two schematics.
 http://www.aeroelectric.com/articles/Failure_Detection_and_Annunciation.pdf
 Questions:
 1.  In pitot_heat.pdf the relay is positioned just before the Pitot
 heater load and after the Reed switch sensor, vs in the second
 article the relay is positioned BEFORE the Reed switch sensor.   Does
 it matter?
     No
 2. The Reed switch current sensor wire layout is different in the two
 articles.  For example, the LED light wire is after the resistor in
 one, -vs- the LED wire is after the Radio Shack 275-232 reed relay in
 the second article.   Does it matter?
     Depends on what you want to display.
     Light ON = "Pitot heat powered up and
     drawing current" (Page 3)
     Light ON = "Pitot heat powered but NOT
     drawing current". (Page 4)
  |  | - The Matronics AeroElectric-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		plevyakh
				 Posted: Thu Feb 17, 2011 7:56 am    Post subject: Re: Wiring diagram question for Pitot Heat   On indicator li |
				Thanks Bob...that helps.
 Can you comment on use of the 18AWG fuselink in the Pitot Heat.pdf schematic in place of a 15amp fuse?
 Why wouldn't I just use a 15amp fuse at the bus to protect my wire?
 Howard
  _________________ Howard Plevyak
GlaStar / Cincinnati, Ohio |
		plevyakh
				 Posted: Thu Feb 17, 2011 7:59 am    Post subject: Re: Wiring diagram question for Pitot Heat   On indicator li |
 Howard
