"Starter Engaged" Warning Light Circuit Refresher
PostPosted: Fri Feb 18, 2011 7:58 am    Post subject: "Starter Engaged" Warning Light Circuit Refresher Reply with quote
At 10:34 PM 2/17/2011, you wrote:
--> AeroElectric-List message posted by: Bob Falstad <bobair(at)me.com>
Bob N.,
I'm putting a "starter engaged" warning light in my new IFR panel. I simply hooked the incandescent bulb from my B&C alternator "low voltage" warning light between a fused wire that runs from the hot side of the starter contactor and ground. (I now have the standby B&C alternator and will use its controller's "standby alternator on" light in lieu of the low voltage light on the primary alternator controller.)
But then I ran across a handwritten sketch that I believe you drew up for this circuit. It has a 470 Ohm - 1 Watt resistor in the wire between the hot side of the starter contactor and the lamp. It also shows a 1N4001 protection diode in parallel with the lamp and ground. It isn't clear from your sketch (and my electrical symbols knowledge is limited) whether the lamp is incandescent or an LED.
This is an incandescent lamp
[img]cid:7.1.0.9.0.20110218094700.01d98650(at)aeroelectric.com.0[/img]
This is an Light Emitting Diode
[img]cid:7.1.0.9.0.20110218094700.01d98650(at)aeroelectric.com.1[/img]
The resistor used with the LED warning circuit as
sketched serves a dual purpose. It protects the wire
that runs from starter to lamp by limiting the maximum
current that could flow in a faulted wire. At the same
time, it SETS the current intended to illuminate the
LED.
For an incandescent warning light, the resistor is
replaced with a fuse and the incandescent lamp is
substituted for the LED. No reverse current diode
is needed.
 Filesize:  8.64 KB
 Viewed:  2186 Time(s)
 Filesize:  8.05 KB
PostPosted: Fri Feb 18, 2011 3:06 pm    Post subject: "Starter Engaged" Warning Light Circuit Refresher Reply with quote
At 05:43 PM 2/18/2011, you wrote:
Bob N., Is the drawing for this circuit in the Aeroelectric archives? I think I'd like to add it to my very bare bones system.
http://aeroelectric.com/Pictures/Schematics/Starter_Engaged_Warning_Lt.pdf
Bob N.,
[img]cid:7.1.0.9.0.20110218170144.01fc2908(at)aeroelectric.com.2[/img]
[img]cid:7.1.0.9.0.20110218170144.01fc2908(at)aeroelectric.com.3[/img]
LED.
is needed.
 Filesize:  8.64 KB
 Viewed:  2176 Time(s)
 Filesize:  8.05 KB
