themckenneys(at)hotmail.c Guest
Posted: Sat Feb 19, 2011 5:45 am Post subject: Kitfox-List Digest: 4 Msgs - 02/18/11 |
The 2 SLSA that are cheap and legal for instruction, if being rented are the M-Squared Breeze at $25,000 and the Slipstream ultrasport at $35,000 my only complaint is that both are open cockpit. the Breeze has over 600lbs of useable weight, being open with just windscreens they wouldn't be feasible for northern use in summer, but at least someone is trying. Falcon Insurance will cover both for instruction.
> Date: Fri, 18 Feb 2011 23:59:30 -0800
| Quote: | From: kitfox-list(at)matronics.com
To: kitfox-list-digest(at)matronics.com
Subject: Kitfox-List Digest: 4 Msgs - 02/18/11
Today's complete Kitfox-List Digest can also be found in either of the
of the Kitfox-List Digest and can be viewed with a generic text editor
HTML Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter=2011-02-18&Archive=Kitfox
Text Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter=2011-02-18&Archive=Kitfox
Kitfox-List Digest Archive
Total Messages Posted Fri 02/18/11: 4
Today's Message Index:
1. 06:52 AM - Re: Auto oil filter for 912? (Tucsonchris)
2. 09:36 AM - Re: club plane ELSAs (John W. Hart)
3. 02:13 PM - Re: Auto oil filter for 912? (jerrytex)
4. 06:09 PM - Re: Auto oil filter for 912? (Roger Lee)
Time: 06:52:14 AM PST US
Subject: Re: Auto oil filter for 912?
FYI, the Purolator PureOne PL 10241 recommended is too tall to fit under the stock
Kitfox exhaust, Bought one, tried it. I'd have to take the exhaust off each
time and it doesn't look like that would be fun.
Chris G.
Tucson, Arizona
Marana Regional Airport
Kitfox SS
912s
http://forums.matronics.com/viewtopic.php?p=331405#331405
Time: 09:36:33 AM PST US
Subject: RE: club plane ELSAs
Mal,
Well, yes and no.
The Taylorcraft is licensed under CAR 4, dating back to 1939.
http://rgl.faa.gov/Regulatory_and_Guidance_Library%5CrgMakeModel.nsf/0/B3
F7EB59DB30E3DD8625747A006B33C0?OpenDocument
A Type Certificate Data Sheet exists for the Taylorcraft.
http://rgl.faa.gov/Regulatory_and_Guidance_Library/rgMakeModel.nsf/0/f11a
5c945ba842338625747a006b2f74/$FILE/A-696.pdf
The Taylorcraft has a Standard Airworthiness Certificate, not a Light
Sport Category Certificate:
http://www.faa.gov/aircraft/air_cert/airworthiness_certification/sp_awcer
t/light_sport/
It is not licensed in the Light Sport Category, however it may be
operated by Sport Pilot Certificate Holder under Sport Pilot Rules
because it meets all the rules of Light Sport Aircraft:
http://www.faa.gov/aircraft/gen_av/light_sport/media/ExistingModels.pdf
Maintenance, modifications and inspections of the Taylorcraft must be
accomplished under Part 43 rules. By virtue of the Standard
Airworthiness Certificate, maintenance requires a certificated
maintenance technician.
John Hart
KF IV
Wilburton, OK
[mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Malcolm
Brubaker
Sent: Wednesday, February 16, 2011 4:52 PM
Subject: Re: club plane ELSAs
If the grose was less than 1320# it is a lsa mal
Malcolm Brubaker
Michigan Sport
Pilot Repair
LSRM-A, PPC, WS
(989)513-3022
_____
From: Lloyd & Lorrie Cudnohufsky <7suds(at)Chartermi.net>
Sent: Wed, February 16, 2011 5:16:29 PM
I received my tail wheel instruction / endorsement in a Taylorcraft, fun
plane, was not licensed as a LSA though.
Lloyd
[mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Guy
Buchanan
Sent: Tuesday, February 15, 2011 6:50 PM
On 2/15/2011 10:16 AM, Zimmermans wrote:
When I went to Light Sport I sold my Cessna & bought a 7AC Champ. It is
a legal LS plane plus it is an antique. They are there for $25,000 on
up. We have several in this area that are club owned. I will never live
long enough to see a new LS that I consider affordable. My 2 cents
worth.
Good idea Jim. SportAviation had a recent article on a bunch of cheap
certificated LSAs: Chiefs, Champs, Luscombs, Ercoupes, Cessna 120/140,
PA 15/17, Taylorcraft BC-12. All these were claimed to be below $40k and
many were below $30k. Don't know if they'd be insurable for flight
instruction, though.
Guy Buchanan
Scoutmaster =93 Troop 680
760.809.6145
scoutmaster(at)troop680.org
www.troop680.org
Time: 02:13:55 PM PST US
I ran into the same problem with the Purolator being to tall. I went with the Napa
Gold.
http://forums.matronics.com/viewtopic.php?p=331450#331450
________________________________ Message 4 _____________________________________
Time: 06:09:51 PM PST US
The Pure One as the Fram are slightly less 1/2" longer than a stock Rotax filter.
There are a few instances where owners have a stock exhaust that is a little
too close to fit the filter in over the threaded mount. Some with stock Rotax
exhaust don't have this problem and some just have different exhaust. The only
way to find out is buy one and try it. Sorry there is no other way. Don't
put any oil in it and you can take it back if it is a tad too long.
Roger Lee
Tucson, Az.
Light Sport Repairman - Maintenance Rated
Rotax Repair Center
Cell 520-349-7056
http://forums.matronics.com/viewtopic.php?p=331473#331473
[quote] _================
