kitfox(at)ida.net Guest
Posted: Wed Mar 02, 2011 9:37 pm Post subject: Hirth F30 thoughts |
Hello all
Here is a question. What is the opinion of a Hirth F30 110 hp. in a model 5TD? I have an NSI 140T with CAP prop. Do not like it. Throw ideas, thoughts or experience to me.
Albert Smith
MudLake, Idaho
5TD NSI 140T CAP prop. 10 hrs.
MHastedt
Joined: 27 Aug 2006 Posts: 14 Location: College Station, TX
Posted: Thu Mar 03, 2011 6:17 am Post subject: Hirth F30 thoughts |
Hi Albert,
I am in the process of installing a Jabiru 3300 (120 HP) in my Classic IV. I retired my semi-NSI Subaru after too many problems to list. I'm looking forward to 50% more horsepower and over 90 less pounds.
Margaret Hastedt
College Station TX
Classic IV, 3300 -soon!
| Quote: | >> "Albert" <kitfox(at)ida.net> 3/2/2011 11:34 PM >>>
Hello all
Albert Smith
MudLake, Idaho
Aerobatics(at)aol.com Guest
Posted: Thu Mar 03, 2011 6:56 am Post subject: Hirth F30 thoughts |
No personal exp with Hirth but know of ........... lots of problems... over heating etc . all rumors to be frank.
However lots of exp with Jab 3300. Its a Beautiful engine. A jewel to look at, very smooth and powerful. But we have 3 slsa in a training environment that was a nightmare. Maybe as a Hobby aircraft engine it will be fine... The 912S has proven itself to us over and over to be more complex but very very reliable We have flown over 2,500 hours with Jab and 3,000 with 912S
Even on a cold day.. less than 45 F the Jab was very difficult to start, the 912S was like a car didn't care....
In spite of its price, the Rotax dominates the market. We now understand why.
Its all good enjoy!
Dave
In a message dated 3/3/2011 8:18:16 A.M. Central Standard Time, hastedt(at)iodp.tamu.edu writes:
| Quote: | --> Kitfox-LisHowever lots of exp with Jab 3300t message posted by: "Margaret Hastedt" <hastedt(at)iodp.tamu.edu>
Hi Albert,
Margaret Hastedt
College Station TX
Hello all
Albert Smith
MudLake, Idaho
5TD NSI 140T CAP prop. 10 ========================; the ties Day ================================================ - MATRONICS WEB FORUMS ================================================ - List Contribution Web Site sp; ===================================================
jose_m_toro(at)yahoo.com Guest
Posted: Thu Mar 03, 2011 8:12 am Post subject: Hirth F30 thoughts |
Albert:
A friend of mine, despite of my recommendations, decided to use a 65 hp, 2 cylinders, air cooled Hirth engine. After three engines failures, and the corresponding aircraft repairs, decided to switch to the well known Rotax 582. No more problems. I have read about Hirth engine problems for the last 18 years. I DO NOT RECOMMEND HIRTH ENGINES!!!
Jose Toro
ex-owner Kitfox II/582
Sent: Thu, March 3, 2011 1:34:03 AM
Subject: Hirth F30 thoughts
Hello all
Albert Smith
MudLake, Idaho
[quote][b][b]
Posted: Thu Mar 03, 2011 8:38 am Post subject: Hirth F30 thoughts |
I would like to add I personally have a KF2 with a 582 E box IVO around 500 hours.... perfect
In a message dated 3/3/2011 10:12:50 A.M. Central Standard Time, jose_m_toro(at)yahoo.com writes:
| Quote: | Albert:
Jose Toro
Subject: Kitfox-List: Hirth F30 thoughts
Hello all
Albert Smith
MudLake, Idaho
michael.logan1(at)verizon Guest
Posted: Thu Mar 03, 2011 3:09 pm Post subject: Hirth F30 thoughts |
Keep the basic engine, get rid of the dry sump system and gearbox. Put an autoflight or SPG-4 gearbox on it and keep the CAP. Ron at RAM Performance can redo the engine for you and really increase the power and smoothness, he also sells the autoflights on his engine and can put you in touch with the New Zealand factory if you want to buy it outright. When you are finished upgrading, you will have a smooth running engine, lots of power and will have spent a lot less than buying a Rotax or Hirth. The CAP was the only worthwhile thing that Lance had at NSI and I think he actually took the design from a German company.
Mike Logan
Series 5 RAM EA-81 140 CAP
Fredericksburg, VA
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Albert
Sent: Thursday, March 03, 2011 12:34 AM
Hello all
Albert Smith
MudLake, Idaho
sp; - The Kitfox-List Email Forum utilities such as List Photoshare, and much much --> http://www.matron===================[/b]< - content also available via the Web --> http://forums.matronics.com - List Contribution Web generous nbsp; --> http://www.matronics.com/c=[/b] [/quote]
Lynn Matteson
Posted: Fri Mar 04, 2011 3:53 am Post subject: Hirth F30 thoughts |
Part of the Rotax dominance is that it has been around longer. I
suspect that once Jabiru settles down and decides how it wants to
build engines, and then leaves them alone, it will see a greater
share of the market.
Lynn Matteson
Jabiru 2200, #2062
Prince prop (64 x 30, P-tip)
Rotec TBI-40 injection (sleeved to 35mm)
Status: flying...1083 hrs (since 3-27-2006)
On Mar 3, 2011, at 11:18 AM, Aerobatics(at)aol.com wrote:
| Quote: | I would like to add I personally have a KF2 with a 582 E box IVO
Albert:
HIRTH ENGINES!!!
Jose Toro
Hello all
Albert Smith
MudLake, Idaho
Naviga========================.matronics.com/ href="http://
forums.matronics.com/">http://
forums.matron========================= --> http://www.matronics.com/
contribution
www.matronics.com/contribution _-
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
Pat Reilly
Posted: Fri Mar 04, 2011 8:55 am Post subject: Hirth F30 thoughts |
Has anyone had experience with the Rotax 670 engine? Rotax Rick sells them on Barnstormers. From his ads he appears to be experienced in providing rebuilt Rotax engines. I thought the 670, if setup properly, might be the way to go for added power. My limited experience with my 582 leads me to recommend Rotax as a very reliable 65 HP engine. Remember this thread's question was for powering a mod 5 with 100 HP.
Pat Reilly
Mod 3 582 Rebuilt
Rockford, IL
On Fri, Mar 4, 2011 at 5:50 AM, Lynn Matteson <lynnmatt(at)jps.net (lynnmatt(at)jps.net)> wrote:
[quote]--> Kitfox-List message posted by: Lynn Matteson <lynnmatt(at)jps.net (lynnmatt(at)jps.net)>
Part of the Rotax dominance is that it has been around longer. I suspect that once Jabiru settles down and decides how it wants to build engines, and then leaves them alone, it will see a greater share of the market.
Lynn Matteson
Jabiru 2200, #2062
On Mar 3, 2011, at 11:18 AM, Aerobatics(at)aol.com (Aerobatics(at)aol.com) wrote:
| Quote: | I would like to add I personally have a KF2 with a 582 E box IVO around 500 hours.... perfect
In a message dated 3/3/2011 10:12:50 A.M. Central Standard Time, jose_m_toro(at)yahoo.com (jose_m_toro(at)yahoo.com) writes:
Albert:
Jose Toro
From: Albert <kitfox(at)ida.net (kitfox(at)ida.net)>
To: kitfox-list(at)matronics.com (kitfox-list(at)matronics.com)
Hello all
Albert Smith
MudLake, Idaho
http://www.matronics.com/Naviga========================.matronics.com/ href="http://forums.matronics.com/">http://forums.matron========================= --> http://www.matronics.com/contribution
www.mat====================
http:=====
http://forums.mle, List Admin.
Pat Reilly
Mod 3 582 Rebuild
Rockford,IL
aerobatics(at)aol.com Guest
Posted: Fri Mar 04, 2011 9:57 am Post subject: Hirth F30 thoughts |
Hi Pat
Have you flown you 3 with a 582
Dave
Posted: Fri Mar 04, 2011 11:06 am Post subject: Hirth F30 thoughts |
The claimed HP is actually 110 hp. The weight is give or take 135 complete with fans. And it is Fuel Injected.
Albert Smith
5TD NSI 140T
MudLake Idaho
Sent: Friday, March 04, 2011 9:53 AM
Subject: Re: Hirth F30 thoughts
Pat Reilly
Mod 3 582 Rebuilt
Rockford, IL
| Quote: | --> Kitfox-List message posted by: Lynn Matteson <lynnmatt(at)jps.net (lynnmatt(at)jps.net)>
Lynn Matteson
Jabiru 2200, #2062
Albert:
Jose Toro
Hello all
Albert Smith
MudLake, Idaho
y Browse, Chat, FAQ,
="http://www.matronics.com/Navigator?Kitfox-List" target="_blank">http:=====
Pat Reilly
Mod 3 582 Rebuild
Rockford,IL
href="http://www.matronics.com/Navigator?Kitfox-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.com
Posted: Fri Mar 04, 2011 11:14 am Post subject: Hirth F30 thoughts |
Might want to get Rotax's opinion re these engines mods... they have the biggest data base and designed them...
In a message dated 3/4/2011 1:06:37 P.M. Central Standard Time, kitfox(at)ida.net writes:
| Quote: | The claimed HP is actually 110 hp. The weight is give or take 135 complete with fans. And it is Fuel Injected.
Albert Smith
5TD NSI 140T
MudLake Idaho
Pat Reilly
Mod 3 582 Rebuilt
Rockford, IL
Lynn Matteson
Jabiru 2200, #2062
Albert:
Jose Toro
Hello all
Albert Smith
MudLake, Idaho
Pat Reilly
Mod 3 582 Rebuild
Rockford,IL
href="http://www.matronics.com/Navigator?Kitfox-List">http://www.matron====================================
ms.matronics.com/">http://forums.matronics.com
tp://www.matronics.com/contribution">http://www.matronics.com/contribution
Posted: Fri Mar 04, 2011 11:10 pm Post subject: Hirth F30 thoughts |
I had a 65 hp in a Challenger 2. Flew it year round for 2 yrs. No problems. With that, the hp, and weight reduction. Major weight reduction. It sounded kind of interesting. Selling the NSI Cheap.
Albert Smith
5TD NSI 140T
MudLake, Idaho
Sent: Friday, March 04, 2011 12:03 PM
Albert Smith
5TD NSI 140T
MudLake Idaho
Pat Reilly
Mod 3 582 Rebuilt
Rockford, IL
Lynn Matteson
Jabiru 2200, #2062
Albert:
Jose Toro
Hello all
Albert Smith
MudLake, Idaho
Pat Reilly
Mod 3 582 Rebuild
Rockford,IL
Pat Reilly
Posted: Sat Mar 05, 2011 1:39 pm Post subject: Hirth F30 thoughts |
Dave, Most certain. I have flown it about 20 hours or so. I am an old 2 stroke dirtbike racer and am very comfortable with 2 stroke engines. Bought the engine used FWF with a C box with 100 hours on everything. It was pulled from a kitfox for a larger engine install. The engine had sat for a year before I bought it, and another year and a half before I installed it and fired it up. I have a Warp Drive ground adjustable prop that came with the engine. It is rated at 65 HP. Don't forget this thread started with questions about a 100 HP engine.
On Fri, Mar 4, 2011 at 11:55 AM, <aerobatics(at)aol.com (aerobatics(at)aol.com)> wrote:
[quote]Hi Pat
Dave
Posted: Sat Mar 05, 2011 2:49 pm Post subject: Hirth F30 thoughts |
My point is isn't the 582 enough on a kf 2-3? .... I raced skidoo so I understand the tweaking a 2 strokes too .... that's easy but the life of a aviation engine is totally different. Totally. One is a highly tweaked sprinter vs cruising at 70% for long periods.
If you go to youtube and search. Kitfox short field take off and see a tan model 2 that all stock w a 582 bluehead ....
Dave
dave
Posted: Sun Mar 06, 2011 5:27 am Post subject: Re: Hirth F30 thoughts |
Rotax 582 - great engine in Kitfox - the exhaust was cut to fit in the cowl on Kitfoxes and you will see about 58 HP only. This helps the Kitfox 582s to last longer.
583 and 670 are good engines but power band will not be a good cruiser at 5800. Power band starts over 6200 rpm and will fall off pipe under that.
Hirth-- Time bomb for the most part.
Rotax 670 talk
http://rotaxaircraft.com/forum/viewforum.php?f=16
Bob Widmer is all over you tube, great performance engine but not for cruising and dependability.
I got hundreds of Kitfox 582 and some 912 movies on you tube.
Best tip is build them light to get good performance. The later model and current at close to 1000 lbs empty. Early ones started at 400lbs or so.
The early Avid A would climb at 2200 fpm plus !!
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
Pat Reilly
Posted: Sun Mar 06, 2011 4:34 pm Post subject: Hirth F30 thoughts |
Dave, I haven't "tweaked" my 582 . Just attempted to set up and maintain properly. I don't want to reduce life or reliabilty. My opinion is that a 582 is just about right for a Mod 2 or 3. But, I haven't flown a 912. I might like it.
Pat Reilly
Mod 3 582 Rebuilt
Rockford, IL
On Sat, Mar 5, 2011 at 4:46 PM, <aerobatics(at)aol.com (aerobatics(at)aol.com)> wrote:
[quote]My point is isn't the 582 enough on a kf 2-3? .... I raced skidoo so I understand the tweaking a 2 strokes too .... that's easy but the life of a aviation engine is totally different. Totally. One is a highly tweaked sprinter vs cruising at 70% for long periods.
Dave
Posted: Mon Mar 07, 2011 6:26 am Post subject: Hirth F30 thoughts |
912 is a fabulous engine.... Im lucky to have flown about 1,000 hours behind one... but power to weight of the 582 is ... in my opinion the perfect engine for the KF 2 3
enjoy
Dave
In a message dated 3/6/2011 6:34:46 P.M. Central Standard Time, patreilly43(at)gmail.com writes:
[quote] Dave, I haven't "tweaked" my 582 . Just attempted to set up and maintain properly. I don't want to reduce life or reliabilty. My opinion is that a 582 is just about right for a Mod 2 or 3. But, I haven't flown a 912. I might like it.
Pat Reilly
Mod 3 582 Rebuilt
Rockford, IL
Dave
-----Original Message-----
From: patreilly43(at)gmail.com (patreilly43(at)gmail.com)
Sent: Sat, Mar 5, 2011 3:24 pm
Subject: Re: Re: Hirth F30 thoughts
[quote]Hi Pat
Dave
Pat Reilly
Posted: Mon Mar 07, 2011 4:06 pm Post subject: Hirth F30 thoughts |
Dave, I also thought the 582 was light enough to make it the ideal mod 3 engine. The price difference was also very attractive.
Pat Reilly
Mod 3 582 Rebuilt
Rockford, IL
On Mon, Mar 7, 2011 at 8:23 AM, <Aerobatics(at)aol.com (Aerobatics(at)aol.com)> wrote:
[quote] 912 is a fabulous engine.... Im lucky to have flown about 1,000 hours behind one... but power to weight of the 582 is ... in my opinion the perfect engine for the KF 2 3
enjoy
Dave
In a message dated 3/6/2011 6:34:46 P.M. Central Standard Time, patreilly43(at)gmail.com (patreilly43(at)gmail.com) writes:
Pat Reilly
Mod 3 582 Rebuilt
Rockford, IL
Dave
