		| Author | Message |
		| wdaniell(at)etb.net.co Guest
				|  Posted: Sun Mar 13, 2011 3:16 pm    Post subject: left wing airleron quick dosconnect - disaster? |   |
				| For the collective wisdom
 In an effort to align the left wing aileron quick connect (reposition page 27/16 in the manual) I inadvertently ground out about 1/4 ‘’ from the upper glass of the spar – that is to say the spar has a ply core with glass upper and lower parts.  I ground away the upper glass part.
 Is this a disaster?
 Will
		| Back to top |  |
		| fklein(at)orcasonline.com Guest
				|  Posted: Sun Mar 13, 2011 4:26 pm    Post subject: left wing airleron quick dosconnect - disaster? |   |
				| On Mar 13, 2011, at 4:12 PM, William Daniell wrote:
  	  | Quote: |  	  | In an effort to align the left wing aileron quick connect (reposition page 27/16 in the manual) I inadvertently ground out about 1/4  from the upper glass of the spar  that is to say the spar has a ply core with glass upper and lower parts.  I ground away the upper glass part. |
 Will,
 A picture would be worth a thousand words.
 Fred
		| Back to top |  |
		| thomas(at)scherer.com Guest
				|  Posted: Sun Mar 13, 2011 11:05 pm    Post subject: left wing airleron quick dosconnect - disaster? |   |
				| Will,
 I second Freds request for a photo. But if it is  what I am afraid it is - then this is some serious structural damage and you  need to involve the company to judge whether repair or raplacement is in  order.
 <Thomas, N81EU>
 [quote]   ---
		| Back to top |  |
		| flyingphil2
				|  Posted: Sun Mar 13, 2011 11:29 pm    Post subject: Re: left wing airleron quick dosconnect - disaster? |   |
				| Hi Will,
 I'd have this conversation with Andy Draper at the LAA if I were you.  As I understand it, the fibre glass is just there as a protective layer for the wood spar.  I don't believe it takes any load.  If so, I'd think that the problem in the photo could be fixed (with an official LAA repair).  But... I'm not an inspector.  Talk to Andy.  Did you cut into the surface of the wood?
 Philp
		| Back to top |  |
		| tonyrenshaw268(at)gmail.c Guest
				|  Posted: Mon Mar 14, 2011 12:37 am    Post subject: left wing airleron quick dosconnect - disaster? |   |
				| Hello Will,
Your wing is like an I beam, a steel girder. The premise is not dissimilar to the way sandwich composite construction works, by having a core material separating two composite sections that oppose each other, one in compression and the other in tension. The factory will be the ones to help you. Good luck sorting it.
 Reg
 Tony R.
 On 14/03/2011, at 10:12 AM, William Daniell wrote:
  	  | Quote: |  	  | For the collective wisdom
 27/16 in the manual) I inadvertently ground out about 1/4 '' from the upper
 glass of the spar - that is to say the spar has a ply core with glass upper
 Is this a disaster?
 Will
		| Back to top |  |
		| jrgowing(at)bigpond.net.a Guest
				|  Posted: Mon Mar 14, 2011 1:59 am    Post subject: left wing airleron quick dosconnect - disaster? |   |
				| William
 Tony R has explained the build of the spar well; but (from the photo I saw) your hole is away from the edge where the most stress hits. So the amount of strength lost may be a lot less than you first imagine.
 Before you do any more I would take your photo again with a ruler set up showing the edge at zero on the rule. This will enable the distance of the edge of the spar to the hole to be read off from the rule. Then pose the question to the factory……………………
 JR (Bob) Gowing Kit 327 in Oz
 From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of Tony Renshaw
 Sent: Monday, 14 March 2011 7:33 PM
 To: William Daniell; europa-list(at)matronics.com
 Subject: Re: left wing airleron quick dosconnect - disaster?
 --> Europa-List message posted by: Tony Renshaw <tonyrenshaw268(at)gmail.com (tonyrenshaw268(at)gmail.com)>
 Hello Will,
 Reg
 Tony R.
 Is this a disaster?
 href="http://www.matronics.com/Navigator?Europa-List">http://www.matron--> http://forums.matronics.com
 _p;         - List Contribution bsp;                    -Matt Dralle, List href="http://www.matronics.com/contribution">http://www.matronics.com/c=================
 Checked by AVG - www.avg.com
 Version: 10.0.1204 / 03/13/11
		| Back to top |  |
				|  Posted: Mon Mar 14, 2011 3:42 am    Post subject: left wing airleron quick dosconnect - disaster? |   |
				| Bud has taken charge of this is his usual calm style - I will confer and report back to the forum.Thanks to all.WillFrom:  JR Gowing <jrgowing(at)bigpond.net.au>
Sender:  "owner-europa-list-server(at)matronics.com" 	<owner-europa-list-server(at)matronics.com>
 Date: Mon, 14 Mar 2011 04:55:32 -0500
 To: europa-list(at)matronics.com<europa-list(at)matronics.com>
 ReplyTo:  "europa-list(at)matronics.com" <europa-list(at)matronics.com>
 Subject: RE: Europa-List: left wing airleron quick dosconnect - disaster?
 William
 Subject: Re: Europa-List: left wing airleron quick dosconnect - disaster?
 Hello Will,
 Reg
 Tony R.
 Is this a disaster?
		| Back to top |  |
