Michael Wynn
Joined: 10 Jan 2006 Posts: 148 Location: San Ramon, CA
Posted: Wed Mar 16, 2011 10:02 pm Post subject: Current draw for lighting Buss |
Hi all,
I am wiring my panel. It includes a PMA 8000 audio panel, SL30, Garmin 430W and 327 transponder. Each has a pin to control the brightness on a separate lighting buss. I was going to use B&C's dimmer circuit. What I can't seem to find is what the current draw for lighting is likely to be. The specific question is, which B&C dimmer do I need.
Anyone know the answer?
Michael Wynn
RV 8 Wiring
San Ramon, CA
_________________ Michael Wynn
RV 8
San Ramon, CA |
Posted: Thu Mar 17, 2011 3:44 am Post subject: Current draw for lighting Buss |
I'd like to piggy back on this question by asking how people have set these 3 units up for dimming? I have a Perihelion dimmer in place but no plan for applying it to these 3 units. I just couldn't figure out what to do.
Bill "praying to the spring gods of warm painting weather" Watson
[quote] Hi all,
Michael Wynn
RV 8 Wiring
San Ramon, CA
Tim Olson
Posted: Thu Mar 17, 2011 5:03 am Post subject: Current draw for lighting Buss |
Aren't all or most of those auto-dimming? I think you should verify that feature and only manual dim the ones that can't.
Most things can.
On Mar 17, 2011, at 6:37 AM, Bill Watson <Mauledriver(at)nc.rr.com (Mauledriver(at)nc.rr.com)> wrote:
[quote] I'd like to piggy back on this question by asking how people have set these 3 units up for dimming? I have a Perihelion dimmer in place but no plan for applying it to these 3 units. I just couldn't figure out what to do.
| Quote: | Hi all,
Michael Wynn
RV 8 Wiring
San Ramon, CA
Posted: Thu Mar 17, 2011 6:42 am Post subject: Current draw for lighting Buss |
That's what I was sort of thinking but didn't finish the investigation. Autodimming is good and I won't mind have an unused dimmer. Right now, I'm just dimming my Honeywell lit rockers and indicators.
I assume that for autodimming, no physical installation action is required? Just turn it on (configure it) and it figures out what to do.
[quote] Aren't all or most of those auto-dimming? I think you should verify that feature and only manual dim the ones that can't.
Most things can.
| Quote: | I'd like to piggy back on this question by asking how people have set these 3 units up for dimming? I have a Perihelion dimmer in place but no plan for applying it to these 3 units. I just couldn't figure out what to do.
| Quote: | Hi all,
| [b]
At 01:58 AM 3/17/2011, you wrote:
| Quote: | Hi all,
Anyone know the answer? |
In days of yore, the dimmer input line to a panel mounted
accessory was a direct power supply to incandescent lamps
scattered about the panel of the accessory. The dimmer
input did indeed have a small but significant POWER
requirement. It was this lighting philosophy that gave rise
to dimmer products designed to handle power . . . the largest
of the B&C dimmers would handle a panel full of post lights
and a center stack stuffed with radios. The 1960 Cessna
310 had two (count 'em) TWO fat rheostats on the center
console for panel dimming. Under some lighting conditions
these were so hot that you could not touch the panel
around the knob that controlled the rheostat.
Modern lighting technologies are all over the map. Florescent,
electro-luminescent, LED, gas discharge, etc . . . To further
complicate matters, they do not all share the same dimming
curves (apparent brightness versus applied voltage). The
transition to mixed technology illumination was well under
way by the 80's. I wrote a specification for the Gates-Piaggio
180 for a 3 channel dimmer controlled by one knob but with
independently adjustable dimming curves to accommodate
a variety of technologies.
The installation manual for each of these accessories should
call out the current draw for the dimmer controls. It may
well be that these control pins do not supply power to
the lighting components but only send a signal to the
internal power supply that services those components.
In this case, the control current may be measured in
a handful of milliamps. Further, the dimming characteristics
may be tailored to the legacy incandescent curve.
Long non-answer. The short answer is you'll have to research
the installation data that should be included in documents
supplied with the accessories. It's a SURE bet that
dimmer inputs of any stripe will not be damaged by
a linearly variable dimmer control input. It probably
won't be damaged by duty-cycle switched dimmers but the
switching frequency of the duty-cycle dimmer might
produce strange behaviors of the dimming function.
You should check this out with the manufacture's
field services folks or some knowledgeable installer.
Has anyone on the List resolved these questions?
Bob . . . [quote][b]
Michael Wynn
Posted: Thu Mar 17, 2011 6:54 am Post subject: Current draw for lighting Buss |
As for autodimming, yes they all do this. A friend with a 430 tells me that it autodims so dim that he can't see it. He goes through the menu to adjust the brightness manually every time he flies at night. Seemed like during construction was the best time to address the issue.
Michael Wynn
RV 8 Wiring
San Ramon, CA
In a message dated 3/17/2011 7:43:14 A.M. Pacific Daylight Time, Mauledriver(at)nc.rr.com writes:
| Quote: | That's what I was sort of thinking but didn't finish the investigation. Autodimming is good and I won't mind have an unused dimmer. Right now, I'm just dimming my Honeywell lit rockers and indicators.
| Quote: | Aren't all or most of those auto-dimming? I think you should verify that feature and only manual dim the ones that can't.
Most things can.
| Quote: | Hi all,
List href="http://www.matronics.com/Navigator?AeroElectric-List">http://www.matronics.com/Navigator?AeroElectric-List
ms.matronics.com/">http://forums.matronics.com
tp://www.matronics.com/contribution">http://www.matronics.com/contribution
RV 8
San Ramon, CA |
Tundra10
Joined: 14 Jun 2010 Posts: 102 Location: Scarborough, Ontario
Posted: Fri Mar 18, 2011 5:47 am Post subject: Current draw for lighting Buss |
Most things can.
My Garmin 430W is autodimming, but the function is adversely affected
in my Cessna 172 by the overhead red light that gently illuminates the
entire panel. It took a lot of playing with the (non-intuitive)
dimming curve to make it work properly. I was unable to truly
simulate in flight at night lighting conditions on the ground, because
the exact level of the overhead light was significant. Having my hand
in front of the unit to press the buttons affected it too. I have it
balanced now, but changing the overhead light level messes it up
On my Tundra, I intend to try to make the manual dimming mode work
with whatever dimmers I choose, which will give me more direct
control. I guess the other option would be to not provide general
illumination for the panel, which would require reverse lighting of
all the switch labels.
Jeff Page
Dream Aircraft Tundra #10
Eric M. Jones
Posted: Fri Mar 18, 2011 9:35 am Post subject: Re: Current draw for lighting Buss |
Two things:
1) It is BUS not BUSS.
2) Because of the low luminous efficiency of incandescent indicator lamps, (maybe a few lumens/watt), the current draw of a panel full of small incandescent lamps is enormous. They are also rarely put in series. So--consider it important to use LEDs in your airplane.
And get rid of those push-to-test lamp buttons. Okay that's three or four things.
www.PerihelionDesign.com
113 Brentwood Drive
Southbridge, MA 01550
(508) 764-2072
emjones(at)charter.net |
Michael Wynn
Posted: Fri Mar 18, 2011 2:27 pm Post subject: Current draw for lighting Buss |
Thanks, Eric
All this time, I though bus was what you drove and buss was where the power was. I guess the real buss is a kiss and kisses, while powerful, don't actually carry current (although they can be electrifying).
I understand the LED advantage and plan to illuminate the panel with an LED strip. I was looking at a lighting bus just for the avionics. It would only carry the current necessary for the four radios. I can't imagine it is more than a amp or two. Do you have any idea?
Michael Wynn
RV 8 Wiring
San Ramon (land of the functionally illiterate)
In a message dated 3/18/2011 10:40:24 A.M. Pacific Daylight Time, emjones(at)charter.net writes:
| Quote: | [img]res://C:\Program Files\Nuance\NaturallySpeaking10\Program\web_ie.dll/QMARK.GIF[/img][img]res://C:\Program Files\Nuance\NaturallySpeaking10\Program\web_ie.dll/ARROW.GIF[/img]--> AeroElectric-List message posted by: "Eric M. Jones" <emjones(at)charter.net>
Two things:
Eric M. Jones
113 Brentwood Drive
(508) 764-2072
http://forums.matronics.com/viewtopic.php?p=334302#334302===============================================
_-= = Use utilities Day ================================================ - MATRONICS WEB FORUMS ================================================ - List Contribution Web Site sp; ===================================================
RV 8
San Ramon, CA |
tim2542(at)sbcglobal.net Guest
Posted: Fri Mar 18, 2011 5:09 pm Post subject: Current draw for lighting Buss |
I'm just guessing here but I imagine at least some of these just use the dimmer input as a reference source. You will have to call the various mfg's to know for sure.
On Mar 18, 2011, at 3:23 PM, MLWynn(at)aol.com (MLWynn(at)aol.com) wrote:
[quote] Thanks, Eric
Michael Wynn
RV 8 Wiring
In a message dated 3/18/2011 10:40:24 A.M. Pacific Daylight Time, emjones(at)charter.net (emjones(at)charter.net) writes:
| Quote: | [img]res://C:\Program Files\Nuance\NaturallySpeaking10\Program\web_ie.dll/QMARK.GIF[/img][img]res://C:\Program Files\Nuance\NaturallySpeaking10\Program\web_ie.dll/ARROW.GIF[/img]--> AeroElectric-List message posted by: "Eric M. Jones" <emjones(at)charter.net (emjones(at)charter.net)>
Two things:
Eric M. Jones
113 Brentwood Drive
(508) 764-2072
Read this topic online = Use utilities Day ================================================ - MATRONICS WEB FORUMS ================================================ - List Contribution Web Site sp; ===================================================
