graeme bird
Posted: Sat Mar 19, 2011 2:51 pm Post subject: Old Style Fuel Pipe |
I have the old style rubber long fuel fill pipe in my build though its the later type. I see this was changed for the plastic side filler. Is there anything inherently wrong with the old one (though its heavy ish)?
_________________ Graeme Bird
kit4 (Wagstaff) TBD
Kit 1 G-UMPY - Mono Classic/XS 912S, Woodcomp G(@)gdbmk.co.uk |
Posted: Sat Mar 19, 2011 4:22 pm Post subject: Old Style Fuel Pipe |
Graem
you're right, its too heavy. It does tend to allow the smell to get into the airplane too. Swap it for a solid aluminium one of you can, just use the rubber bends to joint the ally. Or of course buy the plastic "cobra" and use that.
I would also recommend using an solid Al breather pipe and ground it, then it won't behave like a Van De Graaf generator and generate sparks when vapour and drops of fuel rush up the breather while filling.
One refueling fire due to this, G-**DP after a flight on a hot dry day in Germany. I suspect the spark went from the breather metal tube to the metal funnel which was grounded by Jens(at) hand. He got burnt but fortunately not as badly as -DP.
BTW the breather pipe is too small, this is why it takes so long to fill a Classic Europa, the XS isn't a lot better.
Graham
apologies for ranting, my friend makes me cross occasionally. ( I have been known to annoy him too)
Sent: Saturday, 19 March, 2011 22:51:27
Subject: Europa-List: Old Style Fuel Pipe
--> Europa-List message posted by: "graeme bird" <graeme(at)gdbmk.co.uk (graeme(at)gdbmk.co.uk)>
Graeme Bird
G-UMPY
Mono Classic/XS FWFD 912ULS/Warp drive FP
Build nearing completion
http://forums.matronics.com/viewtopic.php?p=334461#334461
http://forums.matronics.  tronics.com/contribution" target="_blank">http://www.matronics.com/contri================
