Posted: Mon May 08, 2006 8:46 am Post subject: Rotax Relapse |
At 08:36 AM 5/8/06 -0400, you wrote:
| Quote: | Bill did you notice how much up elevator is required for straight and
level ?
Eugene,
It looks like he is climbing. Compare the bottom longerons to the horizon.
Jack B. Hart FF004
Winchester, IN
George Alexander
Posted: Mon May 08, 2006 10:29 am Post subject: Re: Rotax Relapse |
Jack:
Can't let this go on...... Eugene was right... it is a doctored picture I had done. In addition to the up elevator, note the conspicuous absence of a tail wheel and look closely at the mains.... you will see that they are kind of fuzzy looking around the edges. (I'm not that good with an airbrush.) The background is the area that we fly in near Airport Manatee (48X). In fact, if you look directly under Beauford's nose pod, the white patches are tomato fields and the airstrip is just beyond those, with hangars beyond the strip. Tampa Bay is in the background.
Attached is the original picture of Beauford.
level ?
Eugene,
Jack B. Hart FF004
Winchester, IN |
DO NOT ARCHIVE
47.03 KB |
426 Time(s) |
_________________ George Alexander
FS II R503
E-LSA N709FS
http://www.oh2fly.net |
Eugene Zimmerman
Posted: Mon May 08, 2006 2:45 pm Post subject: Rotax Relapse |
On May 8, 2006, at 2:29 PM, George Alexander wrote:
| Quote: | (I'm not that good with an airbrush.)
Hey , but you are actually worse as a liar George.
You did a great job on that pict!
Possum
Posted: Mon May 08, 2006 2:52 pm Post subject: Re: Rotax Relapse |
| George Alexander wrote: | Jack:
You can't belive anything you see on the internet.
69.26 KB |
445 Time(s) |
87.87 KB |
400 Time(s) |
