		cjhukill(at)cox.net Guest
				 Posted: Sun Mar 20, 2011 6:04 am    Post subject: engine cables |
				Does anyone have the part numbers for the proper  length cables from Cablecraft, for knobs, not quadrant. I dont have an engine to  measure, but am installing stuff in the  panel, and would like to get them  coming.
  Chris Hukill
		sean(at)stephensville.com Guest
				 Posted: Sun Mar 20, 2011 6:54 am    Post subject: engine cables |
				Check out Ivan's post and the entire thread from the archives.  Not
 Cablecraft part numbers, but ACS.  He also gives lengths.
 http://forums.matronics.com/viewtopic.php?p=322015#322015
 -Sean #40303
 On 3/20/11 8:59 AM, Chris Hukill wrote:
  	  | Quote: | 	 		   Does anyone have the part numbers for the proper length cables from
  Chris Hukill
		rv10flyer
				 Posted: Sun Mar 20, 2011 10:20 am    Post subject: Re: engine cables |
				I ordered RV-7 throttle cable from Van's. The remaining two from ACS per Ivan's information. It took 9 weeks to get them, so order early! They cost twice as much. They appear to be a little better quality with a larger hole needed at cockpit bracket than Van's. Won't install them for another two to three months.
  _________________ Wayne G. |
		rleffler
				 Posted: Wed Mar 23, 2011 6:42 am    Post subject: Re: engine cables |
				For those with quadrants:
 Per Dave Saylor:
 I replaced the stock cables with 47" for the prop, 51" for mixture and 72"
 for the prop. I got the cables from a local cablecraft distributor. Also,
 ask for the highest temp rating you can get. The green cables from Vans
 aren't the best. A set of replacement cables should be $200 or less.
 The vendor is California Push-Pull in Chico, CA. Talk to Frank.
 http://www.push-pull.com/
 176-VTT-2-51
 176-VTT-2-47
 176-VTT-2-72
 These are for the mixture, throttle and prop respectively.
 Ask for Frank if you need a live person. He knows what they're going on.
 The cable tags will say "not for use on aircraft", which usually means they know you're using it on an aircraft
 Hope this helps!
 bob
  _________________ Bob Leffler
N410BL - Phase I
		Strasnuts
  Joined: 10 Feb 2009 Posts: 502 Location: Salt Lake City, UT
				 Posted: Wed Mar 23, 2011 7:04 am    Post subject: engine cables |
				I was wondering if vans changed cable lengths before my serial number. I had no issues using the supplied cables with my Aerosport lower console and throttle quadrant. Kit number 40936.
 On Mar 23, 2011, at 8:42, "rleffler" <rv(at)thelefflers.com> wrote:
  Per Dave Saylor:
  176-VTT-2-51
  176-VTT-2-47
  176-VTT-2-72
  Hope this helps!
  bob
  Bob Leffler
  N410BL - FWF
  RV-10 #40684
  http://forums.matronics.com/viewtopic.php?p=334767#334767
  _________________ 40936
RV-10 SB N801VR Flying
780 Hours
SuperSTOL 60 hours |
		rleffler
				 Posted: Wed Mar 23, 2011 9:46 am    Post subject: engine cables |
				Were your lengths the same as the ones I listed from Dave Saylor?
 I've got to order mine, but I'm planning on taking some measurements this weekend.
 I've got the aerosport panel / throttle quadrant too, but my fm-200 is in a non-standard location to accommodate the rod bower ram air mod.  Its horizontal, not vertical. It may need a couple extra inches.
 On Mar 23, 2011, at 11:01 AM, Seano <sean(at)braunandco.com> wrote:
 > Per Dave Saylor:
 > 176-VTT-2-51
 > 176-VTT-2-47
 > 176-VTT-2-72
 > Hope this helps!
 > bob
 > Bob Leffler
 > N410BL - FWF
 > RV-10 #40684
N410BL - Phase I
		Strasnuts
				 Posted: Wed Mar 23, 2011 7:04 pm    Post subject: engine cables |
				I'll have to look at my part numbers tomorrow and maybe you can cross
 reference them.  It may be easier to route little longer cables than stock
 ones, mine went in easy and I was able to set all my controls to end even at
 the top and bottom while hitting the stops.
780 Hours
