capt_riney(at)yahoo.com Guest
Posted: Mon Mar 21, 2011 7:47 pm Post subject: Icom External Antenna |
I've got an icom A5 and would like to get an external antenna that I can mount on the belly of my Mark3. Anyone out have any good recommendations?
Mark Rinehart
indy M3C
Richard Pike
calvin(at)mlgc.com Guest
Posted: Tue Mar 22, 2011 5:47 am Post subject: Icom External Antenna |
Mark,
I have a simple Bipole antenna that works very well and does not require a
ground plane. Only cost a few bucks to build.
Building instructions here http://chrusion.com/BJ7/InvVeeAntenna4ULs.pdf
Cal Anderson
Fisher 202 Koala
Time: 08:47:15 PM PST US
Subject: Icom External Antenna
mount
Mark Rinehart
indy M3C
rickofudall
Posted: Tue Mar 22, 2011 6:38 am Post subject: Icom External Antenna |
If you want to go cheap, you can buy $15 worth of fittings and a BNC cable at Rat Shack, get a piece of 3/32" brazing rod and make your own. If you want to spend a little more (or maybe less depending on your scrounging ability) get the BNC cable and see what your local avionics shop has in the way of an antenna for a 121.5 ELT.
Rick Girard
On Mon, Mar 21, 2011 at 10:44 PM, Mark Rinehart <capt_riney(at)yahoo.com (capt_riney(at)yahoo.com)> wrote:
| Quote: | --> Kolb-List message posted by: Mark Rinehart <capt_riney(at)yahoo.com (capt_riney(at)yahoo.com)>
Mark Rinehart
indy M3C
http://forums.matronics.com
le, List Admin.
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
- Groucho Marx
Dana
Posted: Tue Mar 22, 2011 9:01 am Post subject: Icom External Antenna |
At 11:44 PM 3/21/2011, Mark Rinehart wrote:
| Quote: | --> Kolb-List message posted by: Mark Rinehart <capt_riney(at)yahoo.com>
I've got an icom A5 and would like to get an external antenna that I can mount on the belly of my Mark3. Anyone out have any good recommendations? |
I just use the original rubber duck antenna on the end of an extension cable. Works fine.
-Dana
Come to think of it, there already are a million monkeys at a million typewriters, and the Internet is _NOTHING_ like Shakespeare!
byoungplumbing(at)gmail.c Guest
Posted: Tue Mar 22, 2011 10:57 am Post subject: Icom External Antenna |
[img]cid:9CAAB524A6684792B3D7A933AF8C6110(at)laptop1[/img]
my dipole center is at the left side bottom of the nose cone, the center wire goes up the left side and accross the top. and the braided wire angels back on about a 45 deg under the floor. the position was selected to give the best swr, and both wires were cut to give the best swr's. way cheep, way easy, and nothing sticking outside to get bumped or bent. one watt radio will talk 150 miles plane to plane. the signal report was good signal but with some background noise. last week i had a hard time talking to another plane (super cub) in the area,,, but one of the fbo's who was further away heard me ok and relayed to the super cub. made me think the radio setup in the cub was not up to par. he could hear the fbo but the fbo is putting out 15 watts.
boyd young
mkiii
21.8 KB |
3074 Time(s) |
