Yak-52 elevator failure
richard.goode(at)russiana
PostPosted: Thu Mar 24, 2011 9:13 am    Post subject: Yak-52 elevator failure Reply with quote
At the end of last year, the elevator actuators segment on a Russian Yak-52 failed, and the resulting crash was fatal.
The “sector” involved is the plate between the two elevator end plates, underneath the vertical stabiliser. The elevator cables connect to the top and bottom of this plate, and clearly if the plate fails all elevator control is lost.
The current design is made from high tensile aluminium , and it is expected that there will be a formal Service Bulletin requiring a change to steel. In the meantime, all 52 owners are strongly recommended to remove this plate and have it crack-tested.
If you follow this link, http://www.russianaeros.com/Yak-52%20Elevator%20Failure.htm you can see a photograph of the failed item from the crashed aircraft, as well as a photograph showing the plate in place on a 52.
Richard Goode Aerobatics
Rhodds Farm
Lyonshall
Herefordshire
HR5 3LW
United Kingdom
Tel: +44 (0) 1544 340120
Fax: +44 (0) 1544 340129
tigeryak18t
PostPosted: Thu Mar 24, 2011 2:16 pm    Post subject: Yak-52 elevator failure Reply with quote
Rich
Will that concern also The 18T???
Will you provide the steel plate for the 52?
Thanks and best regards
Didier Blouzard+33(0)6 2424 3672
Le 24 mars 2011 à 18:10, "Richard Goode" <richard.goode(at)russianaeros.com (richard.goode(at)russianaeros.com)> a écrit :
Rhodds Farm
Lyonshall
Herefordshire
HR5 3LW
United Kingdom
ef="http://www.matronics.com/Navigator?Yak-List">http://www.matronics.com/Navigator?Yak-List
ums.matronics.com">http://forums.matronics.com
http://www.matronics.com/contribution">http://www.matronics.com/contribution
Didier Tiger YAK18T
Member of Commemorative Air Force
French Wing
PostPosted: Fri Mar 25, 2011 9:45 am    Post subject: Yak-52 elevator failure Reply with quote
To answer the queries of several people who have written to me directly:
<![if !supportLists]> <![endif]>I have passed on all that I know today – but it seemed to me that this is a critical issue that any sensible owner would want to check on their own aircraft.
<![if !supportLists]> <![endif]>I understand from Yakovlev themselves that they will issue a formal Service Bulletin (AD).
<![if !supportLists]> <![endif]>Again I understand that this will be made out of steel rather than aluminium alloy.
<![if !supportLists]> <![endif]>However I do not know any more details of when/where the plate might be made etc.
<![if !supportLists]> <![endif]>I have no idea if there would be a potential similar problem with the 18T/50 etc, which have a similar design.
Rhodds Farm
Lyonshall
Herefordshire
HR5 3LW
United Kingdom
pilko2(at)btinternet.com
PostPosted: Sat Mar 26, 2011 4:35 am    Post subject: Yak-52 elevator failure Reply with quote
Trawling the website of Yak UK reveals this to be a well known gotcha.
http://www.yakuk.com/2000-004.doc
MPD: 2000-004
Subject: Crack in elevator control system pulley.
Applicability: Yakovlev/ Aerostar or a SA Y B AK 52 aircraft.
Reason: A 19 mm crack has been discovered in the elevator actuation part number 5251 or 00-80-3 (referred to as “lever” in the Romanian parts catalogue). The failure of this component could result in loss of the elevator control.
Compliance: Within 50 hours from the effective date of this MPD, inspect elevator actuation pulley parts number 525100-80-34 cracking on its periphery below the attachment for the balance weight bracket, at the point where the section reduces from a 10 mm to 7 mm. Inspect using dye penetrant techniques. if the component is cracked, replace it before Further Flight. Repeat this inspection annually at renewal of the permit to fly.
 Filesize:  11.13 KB
 Viewed:  12024 Time(s)
wlannon(at)persona.ca
PostPosted: Sat Mar 26, 2011 3:03 pm    Post subject: Yak-52 elevator failure Reply with quote
Interesting!
How much weight is attached to this part? And for what purpose?
Walt
 Filesize:  11.13 KB
 Viewed:  11998 Time(s)
William Halverson
PostPosted: Sat Mar 26, 2011 3:27 pm    Post subject: Yak-52 elevator failure Reply with quote
Well, the part is cracking on the upper side ... would it be due to aggressive pull back forces on the stick?
PostPosted: Sat Mar 26, 2011 7:20 pm    Post subject: Yak-52 elevator failure Reply with quote
Possibly. The crack is originating at the section change where loads would
tend to concentrate but it may also be subject to bending loads from the
balance weight attached to the upper, heavier, section.
Possibly rudder induced transverse loading?
I don't understand the use of a balance weight in this location.
Walt
PostPosted: Sun Mar 27, 2011 2:14 pm    Post subject: Yak-52 elevator failure Reply with quote
Hi Cliff;
Thanks for your reply. There seems to be a bit of confusion re this part.
It is not a control balance arm which would typically extend well forward of the control surface hinge line.
This is the elevator control cable drive sector (bellcrank).
It appears to have weight mounted on it directly above the hinge centre line.
That would have absolutely zero effect on elevator balance if the weight is mounted where the attachment holes are located.
But, I am beginning to get the picture!!!!!!! Is this the mounting location for the balance ARM?
If so that takes my concern to a whole new level. That would be the absolutely dumbest place you could possibly imagine to attach a balance arm.
Not only does the sector have to handle the balance weight the effect is severely magnified by the length of the arm.
The cause of this cracking I believe is a direct result of that installation.
Any asymmetrical rudder loads will induce horizontal loading of the ELEVATOR balance weight which will in turn
induce a twisting moment in the elevator sector.
Over (who knows how) many cycles this will result in a fatigue failure at the most likely focal point. Barring a severe nick or other mechanical damage that point is the section change.
Now I begin to understand why they are suggesting a STEEL replacement.
Walt
PS:
talew(at)bellsouth.net
PostPosted: Sun Mar 27, 2011 5:46 pm    Post subject: Yak-52 elevator failure Reply with quote
Hi Walt ,
That is a very incisive analysis of why this part might fail . I think you may have
shed some light on this problem .
Terry
To: yak-list(at)matronics.com
Sent: Sun, March 27, 2011 5:47:35 PM
Subject: Re: Yak-52 elevator failure
Hi Cliff;
Over (who knows how) many cycles this will result in a fatigue failure at the most likely focalpoint. Barring a severe nick or other mechanical damage that point is the section change.
Walt
PS:
dsavarese0812(at)bellsout
PostPosted: Sun Mar 27, 2011 6:50 pm    Post subject: Yak-52 elevator failure Reply with quote
Hi Walt,
Yes, the 4 mounting holes are for the mounting arm as you suggest which
extends forward and has a significant weight on the end. I will take
some photos of the counterweight arm as mounted on the bellcrank
tomorrow and post them on the list.
Dennis
On 3/27/2011 8:17 PM, T A LEWIS wrote:
[quote] Hi Walt ,
you may have
Terry
*To:* yak-list(at)matronics.com
*Sent:* Sun, March 27, 2011 5:47:35 PM
*Subject:* Re: Yak-52 elevator failure
Hi Cliff;
centre line.
balance arm.
installation.
Walt
PS:
mark.bitterlich(at)navy.m
PostPosted: Mon Mar 28, 2011 8:23 am    Post subject: Yak-52 elevator failure Reply with quote
Cliff, what you are saying here makes perfect sense. Thanks for writing it.
Inspecting the part makes sense, but in my mind it is MUCH more important to determine why it cracked in the first place.
Mark Bitterlich
PostPosted: Mon Mar 28, 2011 9:36 am    Post subject: Yak-52 elevator failure Reply with quote
Since the cause of the crack in the bellcrank has not been determined
(or published), as Cliff points out, it is also very important to make
certain your airplane is configured/rigged properly. ie: Elevator
travel is set to specs; rudder travel is set to specs; aileron travel is
set to specs; cable tensions are set to specs and the elevator counter
weight bolts and nuts are 100% tight.
Last but not least as Cliff points out, the elevator bellcrank bearing
CAN and WILL wear. It is a 6x19x6 mm self aligning bearing and they are
used in several places on the airplane. The ones used on the control
surfaces are open face bearings (not sealed) and are prone to collecting
dirt and grit which causes premature wear of the bearing. The elevator
bellcrank bearing is one of these bearings that can easily be degraded
because of dirt and grit migrating to the inside of the bearing.
Another one of these self aligning bearings is the inboard aileron
bearing. This one is the worst of all for collecting dirt because of
its proximity to the main wheel tires which flick the dirt upward during
ground operations.
Dennis
On 3/28/2011 10:47 AM, Bitterlich, Mark G CIV Det Cherry Point, MALS-14
Mark Bitterlich
PostPosted: Mon Mar 28, 2011 1:52 pm    Post subject: Yak-52 elevator failure Reply with quote
Hi Cliff;
The self-aligning bearing is there to compensate for any minor mis-alignment in the assembly of the sector to the rear spar attach fitting with the left & right elevators attached
to the sector.
It will have no effect whatever on the any twisting/bending moments induced in the upper (thicker) part of the sector. Those loads are transmitted to the thinner (7mm) section which is firmly bolted to both elevators through the attachment plates.
These plates are substantial and very effectively increase the bending resistance of the sector in the area just below the section change. This of course further defines the focal point for cracking at the section change by eliminating any flexure below that point.
For the universal bearing to have any effect the entire elevator assembly would have to translate laterally.
Sorry. I think it is a very poor design and probably dictated by a lack of space in that area.
The CJ is quite different. The balance arm is attached to the primary structure of the elevator assy.
I would expect the CJ system is a direct copy of the earlier Russian systems.
Jump in Doug -- how is the Yak 18 done?
Anyone know the Yak 50, Yak18A systems?
Cheers;
Walt
PostPosted: Mon Mar 28, 2011 2:31 pm    Post subject: Yak-52 elevator failure Reply with quote
Yak 50 bellcrank and counterweight is the same design as the 52.
Dennis
On 3/28/2011 4:18 PM, Walter Lannon wrote:
[quote] Hi Cliff;
to the sector.
systems.
Cheers;
Walt
dougsappllc(at)gmail.com
PostPosted: Mon Mar 28, 2011 3:16 pm    Post subject: Yak-52 elevator failure Reply with quote
Walt,The elevator on the 18 attaches just like the CJ6. Don't know about the 50, and have never seen a 52 elevator, so I'm afraid I can't be of much help here.
Doug
On Mon, Mar 28, 2011 at 2:18 PM, Walter Lannon <wlannon(at)persona.ca (wlannon(at)persona.ca)> wrote:
[quote] Hi Cliff;
to the sector.
It will have no effect whateveron the any twisting/bending moments induced in the upper (thicker) part of the sector. Those loads are transmitted to the thinner (7mm) section which is firmly bolted to both elevators through the attachment plates.
Cheers;
Walt
alikatz(at)mbay.net
PostPosted: Thu Mar 31, 2011 9:47 am    Post subject: Yak-52 elevator failure Reply with quote
Watching the Weather Channel, Florida is getting pounded, noticed a CJ
sitting off the Field backed into a small ditch of water in Lakeland,
praying for everyones safety...
Direct TV CH:202
