What training do I need?
DieselsRcool
PostPosted: Mon May 08, 2006 12:59 pm    Post subject: What training do I need? Reply with quote
After about 5+yrs of not flying I have decided to venture forth and find a Kolb of some sort and get back into it. I'm leaning toward the Firestar due to it's conventional controls/construction, simplicity, folding wings, and good looks. I have 1k+ hours in taildraggers, mostly Luscombe, KR2 and Baby Ace. I have no ultralight time and am looking for opinions from Kolb pilots as to what kind of a check-out I should work towards.
Also, I'm currently looking for a non/flying damaged or incomplete project, or complete flying plane for a decent price. Any advise in this would be greatly appreciated.
My current hobby/job is producing Garmin GPS maps of Baja Mexico. I want to add the KOLB to my toolbox for mapping in this area so simplicity,durability and trailerability is a must. I think the FireStar will fill the bill.
Larry
rsanoa
PostPosted: Mon May 08, 2006 2:24 pm    Post subject: What training do I need? Reply with quote
A Luscomb flyer won't have any trouble getting checked out in any of the Kolbs.
DieselsRcool <LarryB(at)LBMaps.com> wrote:
After about 5+yrs of not flying I have decided to venture forth and find a Kolb of some sort and get back into it. I'm leaning toward the Firestar due to it's conventional controls/construction, simplicity, folding wings, and good looks. I have 1k+ hours in taildraggers, mostly Luscome, KR2 and Baby Ace. I have no ultralight time and am looking for opinions from Kolb pilots as to what kind of a check-out I should work towards.
Larry
http://forums.matronics.com/viewtopic.php?p=33482#33482
Yahoo! Messenger with Voice. PC-to-Phone calls for ridiculously low rates.
Ray S.Anderson
biglar
PostPosted: Mon May 08, 2006 5:34 pm    Post subject: What training do I need? Reply with quote
I'd be very interested in seeing some of those Baja maps. I have a Garmin
196 and an eTrex Legend, and I've covered a fair amount of ground in the
Baja. Lar.
Larry Bourne
Palm Springs, CA
Building Kolb Mk IIIC
"Vamoose"
cartejy(at)mtn-state.com
PostPosted: Mon May 08, 2006 5:36 pm    Post subject: What training do I need? Reply with quote
Larry,If you can consider the KXP model and a 503,Works great for me + have
extra power when needed Jay Carter E Liverpool Ohio
John Jung
PostPosted: Tue May 09, 2006 8:06 am    Post subject: Re: What training do I need? Reply with quote
Larry,
I suggest that you get yourself current. A current pilot should be able to make the transition without problems. Being rusty and trying to make adjustments at the same time is not good. Here are a couple of differences in Kolb type aircraft and what you are used to:
Kolbs slow down much quicker, and will stall if you pull off the power to make a flair on landing. Kolbs need so little flair that a lot of pilots say there is none at all. New Kolb pilots are encouraged to keep power on to a few feet of the ground. The other thing is that there is not much of a reference for the attitude or direction that you are used to from the engine cowling. This matters to some and not so much to others.
John Jung
Firestar II N6163J
Surprise, AZ
